Question about Frigidaire Affinity ATF7000E Front Load Washer
I have a error message e20 how can this be fixed
  • Frigidaire Master
  • 3,740 Answers
Turn off your water connections remove the hoses at the washer connection and check for debris on the inlet screens of the water valve on the back of the unit. (You will must remove the hoses.) Use a small blade or scribe on the OUTSIDE edge of the screens to remove them. The wash them under running water rubbing gently with your fingers.
Reinstall the screens making sure they are seated and reconnect the hoses hot to hot cold to cold. water on..
Test...
If the screens are clean and you still have the problem it can be caused by low water pressure.
Worst case the water valve itself may have failed. Normally only one side of the valve will fail at a time either hot or cold.
Thanks for choosing FixYa.
Kelly
Posted on Aug 30, 2010
How can I fix E20 error on washer
COULD BE EITHER? U HAVE TO CHECK THE HOUSE DRAIN AND THE HOSES AND WATER PUMP FOR OBSTRUCTIONS
Feb 16, 2014 | Frigidaire ATF6000ES Front Load Washer
E20 error message
maybe you should just get a new washing machine
Dec 11, 2013 | Washing Machines
Error message e06 and e20 on rinnai energysaver 403ft
go to www.fitness.manualsonline.com or www. retrevo.com and download your instr.manual for to clear the errors .
God bless you
Jul 21, 2012 | Rinnai Heating & Cooling
Zanussi turbodry 1200 There was a first error message E20, while drying, so i stopped the proccess but now in a new washing cicle, i´ve the same error while filling Whatt is E20? what must i...
Hi
Error code e20 means a clogged drain pump. This might have happened due to small clips, pins, coins, etc being stuck in the pump. Please note that error e20 can also occur when the drain pump is not pumping fast enough or when the pump fails. To fix the issue you'll need to check the drain pump. Tilt the machine on its side and remove the 3 screws and 2 wires that hold the pump in place. Hope this helps... Please post back for any further assistance.
Daniel
Nov 16, 2010 | Washing Machines
E20 message want spin
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
1. Restriction in the drain pump
2. Failed pump
3. Water not pumping out fast enough (crimped drain hose)
4. Too many suds ( too much detergent or wrong kind)
5. Pressure switch (not communicating with control board)
6. Loose wire at pressure switch
7. Loose wire at pump or control board
8. Failed control board
Apr 29, 2010 | Frigidaire ATF6000ES Front Load Washer
Errroe message E20
  • Get the washer laying on it's side and using the access hole on the bottom carefully remove the screw clamp holding the large hole of the rubber housing to the tub drain (it will be obvious all other clips are green compression clips).
  • Carefully work the strainer out of this flexible rubber drain housing through the large hole.Clean it out and replace you will be good to go. Also remove all the hoses and check for a buildup of gunk. Hope this will fix your problem.
Apr 20, 2010 | Frigidaire Affinity ATF7000E Front Load...
I have a 97 Buick Regal and I get a E20 error message:cd player
If the CD is over 60 minutes it will not play on domestic cars
May 29, 2009 | 1997 Buick.5 Regal
It's just an error message. It stands for Error 20. There is no way to fix the problem. It only reads cd's that it wants. But if it does play a cd, then suddenly stops, and says E20 and spits the cd out, it's most likely because the cd player got too hot. My car does that all the time. And it won't play a lot of burned cd's. Hope this helped.
Mar 24, 2009 | 1997 Buick.5 Regal
E20 message
Hi Helenw,
The error message E20, simply means the filter plastic cage which is located behind the trap door bottom right side of the machine is full and needs to be cleaned out.
All the fibres and lint gets trapped in here and prevents the waste water from escaping, hence Error code E20.
Regards,
David
Sep 12, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Frigidaire Affinity ATF7000E Front Load Washer Logo
47 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
