Question about Whirlpool Washing Machines
What functions do the thimbal like screens in the water supply intake ports have? We removed them to increase the water flow during the rinse cycle ( which seemed to have really increased in time to complete ) but I think we outsmarted the timer and it dosen't shut the fill cycle down untill an over flow has oiccured. This problem is on a Whirlpool LTE6234AW2 Thin Twin
  • tootsies Aug 31, 2010
    Thanks, I'll check these items and get back to you.
  • 10,865 Answers
Hi. those are filter screens. they prevent debris as large or larger than the screen openings from entering the washer. you really should buy a new set, at any appliance store and insert them. the overfill problem is a separate matter. Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch. J.
Posted on Aug 31, 2010
    President:
  • 1,554 Answers
Those are actually filters to prevent debris from getting into the machine and block or clog the water inlet valve as may have happened here. The water inlet valves may have been stuck in the open position causing the overflow. Unplug the machine during fill cycle or when the overflow happens. The valves are indeed stuck in the open position and need to be replaced if water continues to flow in even with the machine unplugged.
The second possible reason is the pressure switch being stuck in the empty position. Blow air into the pressure switch diaphragm to release the contacts and prevent overflow; otherwise, you have to replace the pressure switch.
Feel free to update us about the development of the troubleshooting and repair. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Aug 30, 2010
Whirlpool AAA Class Dishwasher
FA - Aquastop error
Check water supply. Low water pressure? Does the machine fill up with water in under 1 min? If not, thats your problem. If this happens during wash cycle, it could be the intake valve for the rinse cycle that is your problem, if you hava doubble/tripple intake valve that is.
Feb 17, 2016 | Washing Machines
My whirlpool cabrio washer shows LF code
Verify inlet water valve is functioning correctly by selecting each temp while machine is running. Usually COLD temps will run just
ever-so-slightly faster than HOT temp and WARM temp will run faster than both temps separately. Rinse cycle is usually COLD water so i'd suspect the COLD side is malfunctioning. Hope this helps. If not let me know.
Jan 23, 2013 | Whirlpool Washing Machines
During a normal wash cycle, the error code FH occurs. The owners manual says inlet problem. All water pressure is good and inlet screens are clear. Drain function appears to work well. Repair guy came...
If the flow meter does not register 10 and 1/2 gallons of water in 8 minutes the FH code appears.
Could be a bad flow meter, sensor, wiring harness is loose or a bad CCU Central Control Unit.
At the RINSE cycle if water enters the machine you must time the water fill for 8 minutes or less.
If water does not enter the machine suspect the CCU as bad.
Jan 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Rinse cycle water flow slow
This problem is commonly attributed to a water inlet valve (also known as a "mixing valve") that is going bad. The water may appear to flow better during the intial fill cycle, because BOTH solenoids (HOT and COLD) are typically used during the initial FILL cycle. However, nearly all washers use a cold water RINSE. This means only one solenoid is energeized during the rinse cycle which reduces the water volume even more.
If you live in an area that has hard water, or if you use well water, the inlet valve and/or fill hose sediment screens can become clogged with sediment, calcified deposits and rust resulting in a restriction of water flow. You can try cleaning the sediment screens and the water inlet valve in a 50/50 solution of distilled vinegar and hot water to see if you can dissolve any sediment or deposits. Removing the valve from the washer and allowing it to soak in the solution for about 30 minutes, then flushing it with clean water can sometimes return an inlet valve to normal operation. If cleaning the valve does not work, however, you will need to replace it. The following link explains how:
http://www.fixya.com/support/r3575881-replacing_water_inlet_valve_on_whirlpool
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices will vary between sites so shop and compare. The first three sites on the list have helpful exploded view diagrams to assist you with locating and properly identifing any parts you may need. If the model number you listed this question under is correct, the Water Inlet Valve number is 285805 and is listed as item 18 under the "Controls and Rear Panel" parts listing. The average price is less than $20.
If you have any questions, or if your model number is different, please post back and let me know. I hope this helps you.
Jul 14, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a Miele W1918 washer which has worked perfectly for a decade. Now there is not enough water to fill the tub during the first 'rinse' phase of normal cycles or the 'separate rinse' cycle. The machine...
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
Jun 04, 2010 | Miele Novotronic W1918A Front Load Washer
My whirlpool washer fills up with hot / warm water (cold doesn't work) pretty quick for the washing cycle but it takes forever when filling the rinse cycle....help
The amount of water on the rinse is lower becaus it's using cooler water. You stated that the cold water isn't working.
Shut the water supplies off. Take the hoses loose from the hose bibs. There should be screen washers in the end of the hose. These are to catch the sediment that normally flows through the water supply pipes in our homes... Take the washer screens out and clean them with an old toothbrush.
Reinstall and while you're at it clean the hot side too.
Then take the machine end of the hoses off and check that it's all clear there as well.
Re install and run your machine on a cycle and monitor it to see if there is better flow on the cold wash cycle AND the rinse portions of your cycles...
If there is no screen washers in the hose, chances are you'll need to clean the water supply valves in the machine... real fun.. HOPE There's washers in your machine..
K
Jul 24, 2009 | Whirlpool Washing Machines
Washing machine has low flow and stops in middle of cycle
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside where you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!
Feb 24, 2009 | Kenmore 24032\24036 Top Load Washer
Water barely trickles out for rinse cycle
It sounds like you have some buildup in the cold water valve screen. Where the hose connects to the washer there should be a screen inside the valve. Remove the cold water hose from the washer and clear any debri on the valve screen.
If this doesn't fix the slow cold water flow then you will have to replace the whole water valve assembly. The water valve is the piece that the hoses connect too and supply water to the washer.
If you have anymore questions about this please ask. I will be more than happy to help you out.
Thanks
Jan 10, 2009 | Kenmore 24032\24036 Top Load Washer
Asko Quattro 6661 water inlet fault
I had the same problem with my unit. The manual tells you to disconnect the water intake at the machine and clean the screen. This wasn't my problem because as you said the problem doesn't occur until the Rinse cycle which means there is water supply to start the Wash cycle.
From the back of the unit, remove the three screws and take of the lid. You'll notice that there are three separate motors do pump water inside the machine at the water intake. When standing in front of the machine, the motor on the right controls the rinse cycle. I connected an AC volt meter to that pump and started the rinse cycle. 240v showed up at the pump, but the water flow was poor. I simply squished up and down the rubber hose connecting this motor to the detergent unit and was unable to free the clog and water began to flow.
Jan 07, 2009 | Asko W6661 Front Load Washer
Just a trickle of water during rinse cycle
HI thanks for your question. the cold water valve either has a clogged screen or a faulty water valve. remove the cold water hose and clean out the screen, try again. could be all you have to do. if its acting the same. replace the water valve. thanks the appliance doc. please rate my answer. thanks.
Oct 12, 2008 | Kenmore 24902 Top Load Washer
Washing Machines Logo
Sal De
Gerry Harvey
Gerry Harvey
