Question about HP Pavilion dv6000z Notebook
Memory Card My SD memory card is stuck in the card slot on my laptop
    President:
  • 1,944 Answers
Did you try pushing it a bit in to see if it ejects out?
Posted on May 08, 2008
How to remove/load sd card stuck in Huawai M860
The SD memory card slot is spring loaded, to insert the memory card insert the card into the SD memory slot with the SD card contacts going in first and gently push it in until it locks in place. NOTE if the SD card does not slide into the slot easily then the SD memory card has been inserted back to front, turn the SD card around and insert it again.
To remove an installed SD memory card, press the SD memory card and it will pop out slightly then you can then pull out the SD memory card.
Mar 12, 2013 | Cameras
My lg pop wont read the memory card , and my other phones all read the memory card, no matter what memory card i insert to the lg it says" format memory card" then i do and still nothing, could...
I had the same problem with an HTC Aspire ( I think that's what it was called :} Anyway I formatted the micro SD card in fat 32 through my laptop using a micro sd to sd adapter and the sd card slot on my laptop. I then stuck the micro sd card back into the HTC and it worked. I heard formatting through another phone works too. Try it and let me know.
Nov 07, 2011 | LG GD510 Cell Phone
How do I put an SD memory card in a hp Paviliion ze2000 notebook? I cant' find the memory card slot anywhere!
Actually your laptop doesn't have SD memory card slot but there is another way you can use that SD memory Card in your Laptop.
You have to get SD Card Adaptor.
Click here to see how it looks like and also you can buy it at the website.
Please let me know if you have any further questions or concerns.
Thanks.
May 03, 2010 | HP Pavilion ze2000 Notebook
Misc card stuck in slot, how do i get it out ?
1. Shut Down The laptop
2. Remove the laptop Battery ( Close the Lid , turn the laptop Up side down, search for a battery Lock tab, move it to Unlock position, You can see a Lock/Unlock mark on the Laptop cover, this will eject the battery from the slot.
3. Get a tweezers carefully pullout the memory card from the card slot, utmost care should be taken not to damage the card slot contacts
4. After taking out the card put back the battery make sure that it is in the locked position
5. Start the computer , try out the system
6. Verify the memory Card reader functionality using a proper card as per the maker guidelines
Jan 31, 2010 | Toshiba Satellite Pro A210-EZ2203X...
Memory card stuck inside Memory card slot.
Your only bet is a pair of tweezers, The SD slot is not "openable" When these fail the whole reader assembly is disconnected from the motherboard and replaced.
I would say try your local beauty supply store or a pharmacy for a longer thinner pair of tweezers.
Should that not work you have to decide which is the lesser of two evils paying for a tech to replace the component or just leaving the card in there and forego the use of the reader.
Another option is to use a heavy gauge sewing needle to try to push the micro sd card towards the front where yo can grab it with the tweezers.
MAKE SURE the battery is pulled out and the laptop does not have power.
Jan 07, 2010 | Computers & Internet
Can i insert this type of memory card into the slot into the computer directly? it says on my laptop that sd, xd and M (symbol for pro duo? )can be inserted. But when i try to insert it, it doesn't appear...
it is advisable to buy a AIO (All in one) card reader, you can use this to many different type of memory card, the built in slot for memory card in your laptop sometimes only suite to a single type or model (ex. SD slot..MMC Slot etc.)
in your case your memory card is not fit to it, don't force it you might damaged your card
Nov 01, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
Memory card stuck in the SD slot
ohh
its a viurs.if is it nt detect virus gard
try to make externel memory card reder and dnt open.1st activate ur hiden fils and folders and go to memericad rigcht clik explor and del all hiden files specialy aoutorun.inf file del. and copy ur doc to pc then good for format ur memory card. tnx
Sep 13, 2009 | Canon PIXMA MP970 InkJet Printer
I have an Acer 9300WSMI laptop. Does it have a card reader and if so where is it? Thanks Fitzy
SD card slot is on the right hand side of the laptop (with it facing towards you) at the front.
SD card slot is #2
Regards.
Jul 28, 2009 | Acer Computers & Internet
Manual says virtually nothing about adding memory
If it's a newer laptop, generally the maximum is 4 Gigs. If it have an SD card slot, it will take SD cards. Most other cards can be made to work with an SD card slot if you buy an adapter. If it doesn't have a card slot, you can buy a multi-card reader for USB for under $20.
Feb 27, 2009 | Toshiba Satellite A105 Notebook
HP Pavilion dv6000z Notebook Logo
87 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
