Washing machine does spin does not spin fast enough or sometimes at all to get water out of the clothes. If I manually spin the basket it around 3 or 4 times it seems to tighten up enough to get a poor quality spin at the end of the wash cycle. Is this a worn out belt?
  • Mary Becerra-Parrish
    Mary Becerra-Parrish Aug 13, 2008
    AFter a complete cycle my clothes are still VERY wet
  • ravenc7 Dec 31, 2008
    I have a samsung .. very new ,
    same problem as miss bear ..
    is it maybe detergent ?
    or maybe too much liq. softener ?
    pls help !
    very dissappointed w/ my
    new machine !
May be not the solution but my 700lb has an intermittent wet clothes coming out the pump is clear as I watch the discharge.The onlt two controlls I can see that would be a problem are the drip dry control if it is not functioning correctly (need wiring Dia) or in the main control if the points are not making a clean contact and the timer is forcing it past this setting with no action taking place.
The pressure switch is always a problem but I dont beleive so in this case. The 700 is a good machine it is a shame to toss it for a small fault.
Regards
Brian
Posted on Apr 13, 2010
    Genius:
  • 1,073 Answers
WHAT IS THE MODEL NUMBER
Posted on May 08, 2008
What causes the water not to spin out of the clothes?
Hi, it means that the machine is not spinning fast enough and pumping the water away. If its not spinning enough then you have to get the machine looked at as its not clicking on in the cycle for it to spin fast enough. You also have to have it set to wash cycle that has a fast spin. If it is spinning fast then you have to look at the pump to make sure its pumping the water away.
Mar 18, 2016 | Washing Machines
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
Will not spin clothes fast enough
clutch needs replace,ck around the inside of cabinet if you see oil then the basket drive has been leaking also
Jan 10, 2010 | Kenmore 23822 Top Load Washer
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
On delicate cycle clothes wringing wet when done
check drain hose kink or belt adjustment...worn clutch...basket drive
Aug 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
80 Model will spin sometimes -with help- but never fast
Likely the out of balance sensor is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series, clothes wet after spin
First thing you need to check is the speed of the spin cycle. As long as you are not overloading the machine, it should spin the clothes pretty dry. the basket drive may need to be replaced. If it is spinning very fast, then check the drain hose, make sure the water is coming out nice and fast. If not you may have a water pump problem even lint clogged inside it.
Nov 29, 2007 | Kenmore 22422 Top Load Washer
Kenmore washer
If your washer is not spinning fast enough, or barely spinning at all, this is usually a symptom of any one or all of the following: 1. Bad gearcase (transmission). 2. Bad basket drive, with which the transmission couples to under the agitator. 3. Bad clutch/brake assembly. Which mounts on top of the gearcase under the basket drive. Usually a tell tale sign of a gearcase beginning to fail is the sign of an amber colored oil coated under the washer or inside the casing. I said, "usually". It doesn't always happen, but if you notice any signs of oil, the gearcase is shot. The basket drive and clutch assemblies are harder to diagnose and require some disassembly of the washer and the removal of the gearcase to inspect. Let me know if this helps.
Aug 01, 2007 | Kenmore 22642 Top Load Washer
Washing Machines Logo
253 people viewed this question
Top Washing Machines Experts
