Question about Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED 2 HP 115/230V
My pump is humming but wiil not start - Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED 2 HP 115/230V
    President:
  • Jacuzzi Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
It could be the pump is bound up but it is more likely the motor is failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Aug 31, 2010
Ive got power, hot and cold to my existing pump and shower, but the pump doesn't start, just makes a whirring noise.
Above Ground Pool Pump Won't Start or is Humming & How ...
? 6:16
https://www.youtube.com/watch?v=RH78q36liks
Apr 15, 2014 - Uploaded by Above Ground Pros
Above Ground Pool Pump Won't Start or is Humming & How to Fix It ... Pool Motor - Humming-Loud Noise ...
How to fix your pool pump from humming - YouTube
? 2:43
https://www.youtube.com/watch?v=3v2v6aDDq9A
Mar 25, 2013 - Uploaded by James Hayward
Do you have a pool pump not priming (pumping water) andmaking a humming noise ... not only give a ...
pool pump makes humming noise and does not pump - Trouble F
Dec 08, 2015 | Home
Car not getting gas in line
Brenda I believe that your fuel pump has gone to be with the car gods. You can check by disconnecting the fuel line AFTER the pump and having someone pump the accelerator if there is no fuel out then congrats - you found it!
Aug 28, 2015 | 2002 Cadillac Escalade Ext
Wiil turn over but won't crank fuel isn't getting to plugs
check fuel pump fuses ,relay.wires and connections if good possible fuel filter didnt give vehicle information so if filter is in tank incorporated with fuel pump need to change both or an external one
Jul 27, 2015 | Cars & Trucks
1988 subaru GL 10. It wont start after it has ran a while. The humming noise that I assume is the fuel pump coming on just before I start to crank does not hum on those occassions when it wont start. If...
Most likely a bad fuel pump, try turning the engine over while someone bangs on the fuel pump, located under the car about the right rear passenger seat area, if it starts you have a bad pump & it needs to be replaced.
Jan 15, 2011 | 1988 Subaru GL-10
I have a '96 cavalier that makes a humming noise in the gas tank within 5 seconds of starting. I have tried two fuel pumps but the noise is still there!!!
Your fuel pump is supposed to hum, when you turn the key it primes the system and it will hum. When the car is running the fuel pump is running and it will hum. If the noise is excessive then try a higher quality fuel pump, it may be less noisy. You will hear the fuel pump on a lot of vehicles tho when you are sitting at a stop light with your radio off and everything quiet in the car.
Apr 08, 2010 | 1996 Chevrolet Cavalier
Pump just hums but wont start
Sounds like its frozen and causing a very heavy load on your circuit. If the motor gets hot within seconds, its shot and needs replacing. Have you attempted to turn the motor over by hand ?
Jun 22, 2009 | AO Smith SQ1202 Pool Pump Motor
Car wiil not start. turns over for a second or two than stops.
battery is too dead to crank the starter, starter has a dead spot, starter solenoid is shot, bendix solenoid is shot, neutral safety switch is shot, could be any of the above.
Jun 18, 2009 | 1995 Lincoln Continental
Pump will not start and it just hums. When I
if it has been sitting since last year, some rust could have kept the shaft from turning. Get some pump pliers and try to rock the shaft. after you get it freed up, turn it back on.
David
May 09, 2009 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED 2 HP 115/230V Logo
343 people viewed this question
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
Mike
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
