Question about Goodman CLJ48AR49 Air Conditioner
UNIT WAS INSTALL COMPRESOR RUN FOR 2 MIN AND QUIT FAN MOTOR RUNS
  • 32 Answers
Could be a DOA!! but was it installed by a licenced contractor? is so he should be able to fix it othewise call the place you purchased it from
Posted on Aug 30, 2010
YORK OUTSIDE UNIT MODEL # HP036X1021A
You must change the fan motor or you will have more problems
with car temperature!
May 09, 2014 | Canvas Dipped York Brief - Grey
LG model TS-K2430hl .Outside fan stops after a few min.
Should like your unit is working fine unless this is constantly happening. If this is a constant thing then condenser coil if dirty,check thermostat setting
Dec 16, 2017 | LG Heating & Cooling
Hooked up new 4 wire fan 2 condensor with a new 2 cap fan runs fine but no compresor?installed as was told with nothing runnng 2 the new cap but the brown wires but compresor isnt kicking on
The compressor could be bad there is two ways to tell with an ohm meter check each lead off the compressor and to ground for continunity or a megometer . You can always try a hard start kit. It is a super capicator that multiplies starting voltage. Have you checked all connections? There might be a low\ high Pressure switch in the referigent lines if that is bad it won't allow the unit to start. Also is it a heat pump or straight a/c the heat pumps have circut control boards in the unit that control everything
Aug 07, 2011 | Goodman CLQ36AR49 Air Conditioner
Sounds like unit is getting power but fan doesnt come on
Confirm with a volt meter that you are getting the required voltage from the condenser fan motor contactor, load side of the contactor,which should be the same contactor as for the compressor. Is the comprssor coming on. If the compresor is coming on and the fan motor is'nt, than the fan motor or the run capcitor for the fan motor has failed.
Jan 26, 2011 | Coleman Mach III Air Conditioner
I have a lg frige model #lrbn20512ww. it quit cooling both upper and lower yesterday. are there any known problem with the compressor or could it be somthing else. the compresor runs for about min the...
unplug the ref remove the back panel place a fan behind the ref to cool the compressor when you can place your hand on the compressor then you can clean the condenser coil and plug it back up make sure the condenser fan motor is running
Nov 18, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
I have a RUDD Achiever 11. The outside fan only intermittently runs and seems to quit in the evening (overtime for the air condo techs). It won't start again until the morning but when it runs, it blows...
Two possible problems here.
1. you have a bad condenser fan motor. average cost $140.00 for the part plus installation if you can't do it. just buy the motor you most likely will be able to use the existing fan blades.
2. you have a bad run capacitor on that fan. avg cost $5.00 - $35.00 plus installation
In my opinion if you're handy and safe with electicity save some money, if not have it done.
check out grainger.com for the parts they're very reasonable. for the fan you'll need to get specs from the defective unit like amp. voltage rpm. its all on the unit itself. for the run capacitor you'll need the same. all the info u need is on the parts. search the site for run capacitor or condenser fan motor.
good luck hope this helps
Jul 15, 2010 | Ruud UBHC Air Conditioner
My outside unit runs a little while then shuts off.
More likely the out door fan motor has bad bearings and that would cause the out door unit to run for 15 to 20 min but it could be low on freon
when the out door unit runs after 3 to 5 min the larger of the two copper lines going into the unit should be ice cold
If the thermostat you just installed has a time delay that will keep the indoor blower motor running for up to 5 min after the unit shuts off
Sep 01, 2009 | Honeywell Heating & Cooling
The a/c unit cooling fan shuts down shortly after unit kicks on.
If a fan motor quits working during a cycle it usually means that the thermal protector is turning it off. If you had an amp meter on it, you would notice that it is exceeding the listing on the nameplate, Nine times out of ten this is irreversable, the motor needs to be changed. Sometimes if there are oil ports on the motor, you can add a few drops of zoom spout oil and that does the trick. But usually the motor is already damaged. Good luck.
Jul 11, 2009 | Carrier 38CKC036 Air Conditioner
Condenser coil fan not runningon GE pds22scrrss
The fan can rotates freely even if there's no power to it(fan probably burn out).You can check if power is going to the fan motor by folowing the two wires fron the motor picking up power from the compresor connections under a black plastic cover on the side of the compresor.If you nave power going to the fan its needs to be replaced.
Apr 26, 2009 | GE PDS22SCRRSS Bottom Freezer Refrigerator
Goodman CLJ48AR49 Air Conditioner Logo
23 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
