Question about Waterway 5HP Executive 56 Frame Spa Pump PF502N22C
Need to change out bearings - Waterway 5HP Executive 56 Frame Spa Pump PF502N22C
  • 310 Answers
You will need a 7/16 inch open ended wrench, a bearing puller, a phillips screwriver, a 12" peice of metal electrical conduit, and the bearings.
dismantle wet end of pump down to the impeller. Remove the shaft cap at the back of the motor(small circular cap in back). use 7/16" wrench to hold the shaft under the cap whiile spinning the impeller counter clockwise untill impeller is off. using a 1/4" hex driver remove the 4 through bolt located at the rear of the motor. seperate end caps on motor housing to access the bearings. use puller to remove. use the 3/4" conduit to tap new bearing into place. Reassemble unit.
Make sure you have an o-ring kit for this pump first
Posted on Oct 28, 2010
Change cam bearings 1450 flhx
No, but if your cam shoes have never been replaced, have them checked. In some bikes they go as early as 30,000 miles. I just replaced the shoes in my Fatboy at 32,000. If you do replace the cam shoes or do any other work in the cam cavity, change the stock cam bearings for the Screamin' Eagle bearings. Better bearings and cheap insurance, but there is no need to change them unless you're in there for something else, unless the bearings went bad for some reason.
Sep 09, 2012 | 2006 Harley Davidson FLHX Street Glide
How do you change the main bearings in a 1999 ford taurus? And can you change them without pulling the motor?
if you need bearings, you need a lot more. Yes you could, but its a waste of time, because if the bearings are bad, the crank, rod bearings, oil pump, ect. may also be bad.
Dec 17, 2010 | 1999 Ford Taurus
Need to change hanger bearing on 2006 model toyota
You have to remove the driveshaft (Both halves) then let a pro replace the bearing itself
reinstall and that's all there is to it
Sep 13, 2009 | 2006 Toyota Tundra
1998 mustang squeaking wheel bearing
The wheel bearing need to change.
Grease will only cover the problem for a little while.
If you jack the wheel up a little off the pavement.Then try to shake the wheel back and froward. If it shake then the wheeling bearing is getting bad. There suppose to be no shake on the wheel.
Mar 19, 2009 | 1998 Ford Mustang
DANA 35 BEARING REPLACE
If you are going to change one of the pinion bearings you really need to replace both since you will have the pinion shaft out anyway. At the same time you will need to replace the crush sleeve to set the proper load on the pinion bearings. Your Chrysler dealer should have the crush sleeve in stock. The bearings you can just cross reference to another bearing by using the old numbers off the race and bearing. Good luck.
Mar 07, 2009 | 1998 Jeep Grand Cherokee
Change front wheel bearing
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c1528006f5b5
this is a pretty good guide on bearing replacement for your car
Please take a moment to rate this solution
Feb 02, 2009 | 1995 Mitsubishi Eclipse
Noisy front wheel bearing
It is possible but i do reccomend changing the bearing races in the hub when you do it to prevent any premature wear on your new bearings. A new hub/rotor assembly will come with new races installed if that makes it any easier.
Dec 12, 2008 | 1998 Chevrolet C1500
Waterway 5HP Executive 56 Frame Spa Pump PF502N22C Logo
538 people viewed this question
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ian Kime
Ian Kime
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
