If I unplug the hard drive and plug back in the green light comes on in the back, when I push button to turn hard drive on the light goes out and the hard drive will not turn on.
    Scholar:
  • 97 Answers
Reverse the plug when you install a hd and turn on the computer and the light stays in constant that's a sign if a reversed plug i have don't it myself hope this helps
Posted on Aug 30, 2010
I hav icraig slimbook model CLP288 red light that indicates its chargeing comes on but I push power button green light very brief comes on then off screen never comes on .plz help
Try plugging the charger into a wall outlet if you are currently plugging it in a power strip. If you are not try plugging it in another wall outlet. If that doesn't work you can try a hard reboot if the battery is accessible. To do this turn off the slimbook, unplug it, take out the battery and hold the power button down for 30 seconds. Once done put the battery back in, plug it back in and turn the slimbook back on.
For other IT soultions try visiting: https://www.youtube.com/user/jrlake2414?sub_confirmation=1
Jan 24, 2016 | Computers & Internet
Mitsubishi medallion hd 1080
I would try the reset button in the front. Unplug the set push the reset and plug it back in.
Mar 27, 2014 | Televison & Video
Green light come on when you push on button.It goes off after 4sec.TV will not come on
Try this... unplug the TV. Press and hold the power button for 30 seconds, repeat. Plug it back in and attempt to turn it on.
Unfortunately, if this doesn't work, then the TV will need to be repaired or replaced.
Apr 22, 2011 | Televison & Video
I was removing the video card to tighten a nut. I unplugged the power cord and pushed in the power button to drain excess power, notice the solid green light went to flashing. I then removed video card to...
Open it up again. Take the video card out. Take the Ram out. Unplug the hard drive. Unplug the other drives. Unplug the network card(s). And unplug anything else that is tied to the motherboard. Now plug it all back in snugly.Finally,turn it on. It should be fixed.
Nov 23, 2010 | HP Pavilion a1330n (EL466AA) PC Desktop
Plasma wont turn
unplug it and leave it off for 10 mins
then plug it back in.
Aug 18, 2009 | Televison & Video
RCA D52W20 ( power works, but no picture.)
There are four bad capacitors on the sweep board in the power supply. Pretty hard to do yourself unless you have some experience.
May 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Laptop will not turn on
Unplug the ac adapter from the back of the computer. Make sure it's plugged to an electric outlet. check if the ac adapter light is solid green. if not. then you have to replace it.
If it is solid green, reconnect it to the computer, if the light on the adapter goes out as soon as you plug it in to the system, you need to replace the motherboard. call dell to seek your options for replacement.
Mar 02, 2009 | Dell Latitude D600 Notebook
Replaced 128mb with 512mb in Dell Dimension 4400. Plugged everything back in & turned on. Or at least think it is turned on; there is a green light for both the power button and hard drive lights. ...
If you have replaced the memory on a computer and it does not turn on normally that means that either the memory is defective or it is not compatible. Do you hear beeps when you turn on the computer?
Nov 26, 2008 | Computers & Internet
Power light blinking yellow after sitting a while
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS or something), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on).
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS or something), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it).
Oct 11, 2008 | Dell XPS 200 PC Desktop
Computers & Internet Logo
David Payne
David Payne
