Question about GE 18.0 Cu. Ft. Frost-Free Top-Mount Refrigerator - Bisque-on-Bisque
Compressor won't start. hear a clicking sound from solenoid but it won't start.
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 31, 2010
Freezer won t freeze
either mix too rich, torque set too low, shaft spring bent, compressor relay blown, compressor contactor shorted, refrigeration valve solenoid bad, or filter dirty thus reducing air flow. if it's both sides, clean the filter and check the compressor relay (behind right side panel, behind plastic cover on compressor. if you smell burning electric, replace) and the contactor (behind right side panel at the top, tan box with wires. press the tiny button to start compressor. if it doesn't start, replace). if it's only one side, check the valve solenoid (inside left side panel, there are 2 valves. remove plugs from each and retouch to terminals while on. if they click, they work).
Jan 17, 2014 | Bunn Kitchen Appliances - Others
Car wont start
Check the battery. After that check the starter solenoid. The starter itself is ok since you hear 'clicking.'
Apr 26, 2013 | Cars & Trucks
Car won't shift from neutral to park
replacing transmission?????nonsence!!! i can tell this is an automatic trans setup, not standard. lets start here. put car in PARK and turn key on so the dash comes on. do not start car. step on the brake pedal several times slowly and listen for audible sound coming from the shifter area. you should hear clicking sound everytime yo uhit the brake. that is the shift lock solenoid releasing the mechanism indside of the shifter assembly so you can get the car out of park and into gear. you may have an issue with the shifter assembly it self. if no clicking sound is heard, it will need to be diagnosed fruther. the solenoid can not be purhcsed separatelly. shifter assembly only. start with the listening procedure and let me know.
Sep 12, 2012 | 2006 Nissan Altima
Car won't start all lights come on thinking it is a fuse for starter?
When you do turn the ignition switch if you do not hear anything is possible the starter motor solenoid.,check also the battery terminals for miss contact,remove and brush the dirt between , or bad earth.
Aug 26, 2012 | 2008 Ford Focus
2005 Altima won't start, hear clicking sound coming from fuse box,key stuck in ingintion,won;t turn over,tried to jump start.
the clicking that you hear is coming from the starter relay. sounds like your ignition starter switch or ignition lock cylinder is bad.
May 30, 2012 | 2005 Nissan Altima
I have a 1988 bass tracker ingnition switch won't
Hello cainld04,
Sounds Like The Start Solenoid Is Not Working.
When You Turn The Key To Start You Should Hear A Click ,If Not Solenoid Is Probably Bad,If Yes Then Starter Needs Service.
Hope This Helps.
Gordon
May 10, 2012 | Bass Pro Boating
My Maytag MSD2756GES side by side stoped working. The freezer just stays cool around 40 - 50 degrees and won't get any cooler. I turned the temp as low as it gets and no change. I also hear a click...
That is probably the overload on your compressor clicking. Remove the rear panel and listen for it. If thats it unplug ref. and remove compressor cover and remove the starting components. Shake the relay. If it sounds like its in pieces its bad. If not you may have a bad compressor, but I would replace those components first. Check your warranty for compressor.
Sep 27, 2011 | Maytag MSD2756GES Side by Side...
Refrigerator not cooling
the clicking sound you can hear is the relay or clixon as sometimes it is known by trying to start the compressor it may be stuck,first turn off the power to the refridgerator then turn the fridge so that you can see the motor,on the side of the motor you will see a small plastic cover remove it to expose the relaly remove it by pulling it towards you exposing 3 pins in a triangle shape give it a shake to free the solenoid inside the relay relace in the same way you took it off power up the fridge listen to see if you can hear the motor run constanly if it just starts and then goes of its more than likely the compressor is us
May 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Car won.t start makes a clicking sound
this is always the starter solenoid that does this, replace the starter solenoid.
Apr 12, 2009 | 1997 Saab 900
GE 18.0 Cu. Ft. Frost-Free Top-Mount Refrigerator - Bisque-on-Bisque Logo
61 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
