Question about HP DeskJet 3650 InkJet Printer
HP print spooler problem and error 1068. Want my printer back!!!
My computer closed down and I took it to the computer guys. On getting it back my HP printer would not work I went into my computer and there is no icon for a printer. I cannot add a printer because it says print spooler not working. .I went back to ther "guys" and told them what was going on. they said that it should not have happened and downloaded a thingy that would allow me to use the printer. It downloads but will not work. I have gone into your site and found i can download from HP and have started to do this. I have also recieved an error 1068 while i was looking at ways to correct my computer. Regcure did nothing to help. why does the printer spooler stop working and how can I fix this rotten problem, last exam to do and print out - so frustrating!!! Also computer freezes at times as well.
I recvd a err-1068 also said the dependency service or group failed to start?
  • 4 Answers
Snks
Posted on Jul 10, 2008
Just go to your Server or Desktop PC and enable the RPC service (Remote Procedure Call)
Right click in "My computer" icon, from the manu select "Manage" then go to "Services and Applications" and expand that, after that select "Services" you will find that services in the right pane, just click in "Start"
May 08, 2009 | Sony Office Equipment & Supplies
You need to reinstall drivers, I will give you the link for a new download,
Jul 22, 2008 | HP OfficeJet 4315 All-In-One InkJet...
"Error 1068 Could not start the Printer Spooler on local Computer"
I appreciate the opportunity to help you. Try the following:
Check dependency services on Print Spooler
1.Click "Start", input "services.msc" (without quotation marks) to Start Search bar and press "Enter".
2.Double click the “Print Spooler” service.
3.Choose “Dependencies” Tab and remember the services name.
4.In the service list window, find the dependency services and try to start them.
5.Please try to start the “Print Spooler” service again.
See if this helps. If it does, please fill in the rating of my service to you. Thanks for using Fixya.com
Jan 27, 2009 | Office Equipment & Supplies
to make spooling work its necessary to make it work
this is the procedure .if you do this it will work properly. till it is not done it will just ignore printing
1)click the start in the left sice of your computer screen
2)go to control pannel
3)click performance and maintainence
4)click system
5)click data execution prevention
6)turn on DEP for essential windows program and services only.
7)click the spooling services a tick mark sign will appear beside that means it has enabled.
now your printer will work properly.
Nov 23, 2008 | HP PSC 1610v All-in-One Printer
Microsoft Operating System protocol is to install first and then always have drivers and applications install on top of them. More often than not the drivers are outdated and rendered unusable by many of the operating system updates and then need to be updated themselves by the relevant vendor or have to be uninstalled and then reinstalled. Of recent times this has become more and more of an issue due to complexities in the registry and in the COM fabric of the operating system. The registry often gets clogged up with superfluous entries and needs cleaning out to improve performance just like the HD inside the PC needs defragmenting occasionally. Unfortunately when many of the updates from Microsoft and many other software vendors are applied they leave their old entries in the registry and just write new ones - simply because it is convenient and easier for them to do so.
Uninstall the application and drivers using the HP remove utility. It is not sufficient to use the Operating System uninstall as it does not work that well. The Registry, Application, Folders and drivers need to be totally removed.
A registry clean is recommended. You can do this by downloading a free 30 day use of Ashampoo from www.ashampoo.com and clean up your system of all the unnecessary entries. I have been using it for a few years now with grate success and no problems. You can always restore any deleted entries before binning them forever.
Once completed then reboot the PC then reinstall the HP drivers and application. Make sure these are the latest ones available from HP support for your operating system at
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3300221&lc=en&cc=au&dlc=en&lang=en&cc=au
Aug 09, 2008 | HP PSC 1210 All-In-One InkJet Printer
I hope this work for you, good luck!!!!
Jul 28, 2008 | HP LaserJet 1022 Printer
hi! Print Spooler is actually a service for your Operating system-
Try this
Click on start and click on run
in the open box type in services.msc and your services local window should open, scroll down and look for print spooler, highlight it and do a right click and on the dropdown menu left click on stop and it will go to a process of stopping the service and then right click back and click on start. if you get an error message about print spooling or spooler, then that means you have a problem with the operating system. call or go to microsoft help and support online in that case. and RPC server unavailable error has something to do with a network printer. but i believe you setup the printer locally.
You can email me at dabesderis06@gmail.com
Apr 04, 2008 | Epson CX8400 All-In-One InkJet Printer
There are several ways to resolve printer spooler error, probably because there are many variations of this error. The error caused by faulty software can be resolved by deleting all the information found in the directory. Thereafter, navigate to the Control Panel, click on Administrative Tools and then services icon. Find the service labeled Print Spooler, highlight it and restart the process. If that doesn’t work, the program might be corrupted. Click on start, then Run. Search for the document labeled services.msc, and this will trigger the opening of another window. On this window, scroll down and click “Print Spooler”. Check its setting and turn on automatic mode. Click Okay, and restart the machine. If you’re lucky, this might be all you have to do. Still doesn’t work? Navigate to the Add/Remove Programs screen of the Control Panel. Find the all the software responsible for making the printer run including the drivers, and uninstall them. Be sure to be thorough about it, or the problem may not be solved. Download the latest copy of your printer’s software from the manufacturer and reinstall it. get more information for printer spooler error .Hope this helps you.
Mar 03, 2008 | HP OfficeJet 4255 All-In-One InkJet...
hi,
please click on start-->run, type services.msc and then click ok.
double click print spoolers.
check whether the startup type is automatic, if not select it and then click on start button.
press ok and apply and then try once again
Jan 26, 2008 | HP OfficeJet 4255 All-In-One InkJet...
HP DeskJet 3650 InkJet Printer Logo
111 people viewed this question
Ben Johnson
