Question about Frigidaire FGB24S5A Gas Single Oven
My Frigidaire Gall Wall Oven #FGB24S5ASA is not heating properly. Sometimes the oven will heat up, but it heats VERY SLOW and I have to set the temp 25 degrees higher to achieve the appropriate temp. Sometimes, the oven will only heat to 200 degrees and stop. Sometimes it will heat to 300 degrees then fall back to 200 degrees. Broiler seems to work just fine. Any suggestions? Thanks!
  • 145 Answers
SOURCE: Frigidaire Double oven PLEB30T8AC
The best way for you to check is to swap with other element since they use the same one. FRIST turn the breaker off! Then take out the 2 screws on the element. The wires unplug, make sure they don't go back in the holes or the oven may have to come out to find them. You can pull the element out and take it to a parts house to see if they can check it with a ohm meter for you if you don't want to pull both of them out.
Posted on Apr 18, 2008
SOURCE: My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Posted on Dec 08, 2008
  • 530 Answers
SOURCE: Heat elements in oven/broiler do not heat up
I would say to go and reset your curciut breaker first if this is a electric oven. needs 220 volts for both element to work
Posted on Jan 04, 2009
  • 574 Answers
SOURCE: My frigidaire oven won't heat. The burners work
You have two elements turn on the broil and see if the top element comes on if it does replace the bottom element.
Posted on Aug 24, 2009
SOURCE: model FEFL78CBC frigidaire oven bottom (bake)
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Posted on Mar 16, 2010
Bottom oven isn't heating to desired temp. Considering swapping the heating elements to see if one is faulty - thoughts?
try thermostat first. verify heating elements operational, if so check if tstats are same. swap if so, If not jump out tstat and see if higher temp achieved.
Sep 20, 2015 | Thermador PODC302 30" Double Electric Wall...
Have a frigidaire wall oven that won't get to 400 degrees
Hello Bruce Hubley, thanks for your post!
Based off the information you have provided your Frigidaire wall oven will not heat up higher than 400 degrees. It may be a problem with your thermostat or control panel. I would recommend performing a reset on your oven and you can do that by disconnecting power from your oven for roughly ten minutes. If this does not help correct your issue I would suggest having a professional come out to provide the proper repairs on your oven. Best of luck! -Matt
Jan 25, 2015 | Frigidaire Ovens
How to test oven control board on a Frigidaire FEF366DBE?
Hello Shawn Lloyd, thank you for your post!
I see that your Frigidaire range blew the breaker to your home out and now the oven will not heat up properly. There is not information provided in order to test the control panel I would recommend having a professional technician for proper diagnosis and repair. The technician will be able to use appropriate tools in order to verify the control panel is working properly. -Matt
Nov 16, 2014 | Ovens
Frigidaire oven is slow to heat then exceeds set temp set
Normally you should have an appliance spare parts supplier in your area. They generally stock all range of spares for all appliances. You need to pull plug out of the wall and remove the panel covering the wiring to gain access to the oven thermostat. Look carefully on the body of the thermostat and record any numbers you see on a sticker that's present. Then remove knob off in front of thermostat and see if there is a nut attached to the centre which holds the thermostat in position or if there are 2 screws holding the thermostat in place. Use this information to order the thermostat also quoting the oven model number.
Oct 06, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven turn's on, keep's heatings at a higher temp.
This is failed communication between the EOC and the temp sensors located in the oven. i recommend testing the EOC(break point test on the pins) for its operational value and the temp sensors as well. replace any component that doesn't register.
I would also inspect the oven temp sensors for welded harness and fouled housings.
In most cases, this will be a EOC issue.
May 24, 2009 | Frigidaire 30 in. Electric Gallery Series...
Elements do not heat to proper settings
If both elements are not working properly then the problem is either the temperature probe or the control board.
Replace the temp probe first.
May 21, 2009 | Frigidaire 30 in. Electric Gallery Series...
Oven wont heat up to temp set
You will need to have the thermostat looked at or replaced, it may be defective and not reading the correct temp, also try using a manual oven thermometer to check the actual temp in the oven to give you a better idea of what the actual temp is inside
Jan 20, 2009 | Maytag 30" Built-In Single Electric Wall...
Oven doesn't heat
Its are a wall oven or range???
Model number please
May 11, 2008 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire FGB24S5A Gas Single Oven Logo
87 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
