Question about Thomson CS186 Shelf System
I cannot open the cd door. The Thompson CS186 won't even start. The only thing I see is a red light on the upper left; pressing any button does not help.
2 Suggested Answers
Soulvisitor
  • 1113 Answers
SOURCE: CD Door will not open
Hi
I'd say the child lock is on or it is a faulty unit
Link to user manual
Child lock
There is a lock on the back you may have bumped.
from manual...
To avoid accidental key activation, slide the key
lock switch on the back of the unit to the
LOCK position.
The Lock icon can be seen on display.
• Slide to the switch to the OFF position
to unlock keys.
Posted on Jan 26, 2008
I cant set the time on my adidas duramo watch. It says 'offset' and below it says '1H'
This has already been posted on Fixya, so I take no credit for it. I've put the original reply below :-
Directions for setting the time on the adidas duramo / furano / uraha / paruko watch 1. press and hold the SET/LIGHT button (upper left) until "light on" or "light off" is displayed 2. press the MODE button (lower left) until "hour" is displayed and the hour digits are flashing 3. use the START/STOP (upper right) button to increase the hour, and use the LAP/RESET (lower right) button to decrease the hour 4. press the MODE (lower left) button again and "minute" is displayed and the minute digits are flashing 5. use the START/STOP (upper right) button to increase the minute, and use the LAP/RESET (lower right) button to decrease the minute 6. press the MODE (lower left) button again and "second" is displayed and the second digits are flashing 7. use the START/STOP (upper right) button or the LAP/RESET (lower right) button to set the seconds to "00" 8. press the SET/LIGHT (upper left) button to accept the changes
Aug 31, 2017 | Adidas Watches
Bang & Olufsen Beosound 3200 CD Door won't open
Could be the PCB9 light and motor control have the problem its on the upper left side of the player.
Feb 25, 2013 | Audio Players & Recorders
A small blinking light on the left upper corner of panel after a power outage and I can't do any command. The interior lights don't even come on when opening door. I already reset the breaker
Unplug the microwave oven for 10 minutes in a attempt to reset the microprocessor ic, press and hold the start button for the same time and release. Now plug everything back in hopes it will restart, if no change! the keypad control board will need to be replaced along with other unknown parts, due to the nature of damage far cheaper to replace.
May 09, 2012 | Microwave Ovens
Maytag maxima door locked
Similar problem here - pump was set for a 58 minute normal cycle, I look in and see it is now showing 67. Hmm. Attempt to shut it off because it is just sitting there pumping and pumping. Power shuts off but pump keeps running and add garment light flashing red. Cannot open door (to add garment or not) Unplug the unit and the door will not open. Anybody got a clue what's up? I have a wash in, service is closed due to a storm today. Just bugs me that it is 6 months old and seems to act up a fair bit electronically.
Dec 09, 2011 | Maytag Washing Machines
I bought a 1996 Subaru Impreza L 4dr 5speed AWD that runs and starts fine but when I was installing fog lights i noticed that there appears to be an alarm hooked up (it says "code alarm elite DM...
Battery Constant 12v+ Positive Wire (+): Black/Yellow
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Blue/Red
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Red
Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Red/Yellow
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Red
Parking Light Positive Wire Location: Low In Drivers Kick Panel
Power Door Lock Negative Wire (-): Add Actuator. This vehicle uses a central door locking system. When connecting a keyless entry, you will need to add a door lock actuator and some units will also require (2) extra relays.
Power Door Lock Negative Wire Location: To Drivers Door Only
Power Door Unlock Negative Wire (-): Add Actuator. This vehicle uses a central door locking system. When connecting a keyless entry, you will need to add a door lock actuator and some units will also require (2) extra relays.
Power Door Unlock Negative Wire Location: To Drivers Door Only
Door Trigger Negative Wire (-): Red/White
Door Trigger Negative Wire Location: In Black Plug, Above Hood Release
Domelight Supervision Wire: Use Door Trigger, Requires Relay
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Red/Green
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black/Blue
Tachometer Wire Negative Wire Location: At ECM, Under Drivers Side Dash
Brake Light Positive Wire (+): White/Black
Brake Light Positive Wire Location: At Switch Above Brake Pedal
CODE ALARM SYSTEM
Used on:
Impreza 1996-2001
Legacy 1995-1999
Forester 1998-2000
codealarmremote2.jpgBattery GP-23A
Lock: Left button will lock all doors. Double chirp indicates locked.
Unlock: Right button will unlock driver's door only. Hold unlock button app 6 seconds, it will unlock all doors including rear gate. Single chirp indicated unlock.
If the car chirps or lights flash 4x the alarm was triggered.
Panic. Press both buttons to activate emergency honk and flashing lights.
Valet mode: With optional alarm onlyPress the red alarm button on the left of the steering wheel. The light will quickly double flash. To re-set back to normal mode, press the red alarm light button again
Battery failed and lights flashing?
Parking lights will flash when the vehicle's battery is disconnected and reconnected.
To stop lights from flashing, either:
Press remote transmitter "UNLOCK" button once OR turn the ignition switch to the "ON" position and press programming button for one second (see below).
The vehicle interior (courtesy) light and door open warning light (DOOR AJAR indicator) will then illuminate for 60 seconds when the ignition is turned off, or until the doors are locked with the remote transmitter. Yes, the dashboard instrument panel lights will flash when the parking lights flash.
Programming or Overriding the Alarm when you have lost the remote
Open driver's door.
Turn ignition key to 'On'
Press and *hold programming button* in (see diagram, button under dashboard)
After 15 seconds the the door locks will cycle 3 times. Do not release Programming button.
Press lock (left) button the remotes to be programmed. The door locks will cycle one time. Exit programming mode by releasing Programming button under dashboard and turning key to off.
codealarmremote1.jpgCode Alarm Programming Button is under dashboard on the kick panel by the driver's left knee, left of the steering column. If you can't find it, it might still be tucked up in the wiring harness higher up in that same general area. The botton is recessed in a plastic ring (see diagram).
This button must be pressed while programming remotes or if the battery was disconnected and the lights are flashing.
Jan 05, 2011 | Subaru Impreza Cars & Trucks
The CD Tray won't open on my Sony MHC-GX250
te same thing happened to me know i juat turn the stereo off to where the red light is blinking then turn it back on after the standby message disappears and then i quickly pree the eject button......tr it! and let me know!
Jun 24, 2009 | Sony MHC-GX450 CD Shelf System
Jensen t.v model ts2750j blue screen red lock upper left
My Advent TV did the same thing. Blue Screen with a red lock in the upper left corner. Just press and hold the display button for about 10 seconds. It will clearn
Feb 02, 2009 | Jensen TS2750J TV
GE Spectra XL44 Gas Oven, flashing "Locked Door". Can't use oven or close door
I had the same problem happen tonight. I have an XL44 self-cleaning gas range. We unplugged it for several minutes and pressed 'cancel' a bunch of times--neither worked. We finally lucked out--opened the oven door and pressed a black button on the upper left side of the front of the oven. It turned out the flashing words and unlocked our door. Weird. There was nothing in the manual about this...
Oct 22, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchenaid dishwasher KUDS02SRSS2 start light blinking won't start
I have this same kitchenaid model. It would not start after selecting the wash cycle and pressing start. The light would blink as if the door was open. I did the reset by pushing the sani-rinse, heat dry, sani-rinse, heat-dry and closing the door. You can hear something going on inside. After that stopped (about 3 minutes). I was able to select the wash cycle, press the start, close the door, and it started. Good luck!
Feb 22, 2008 | Dishwashers
Thomson CS186 Shelf System Logo
47 people viewed this question
Top Thomson Audio Players & Recorders Experts
shaun taylor
Shehu Pro
Shehu Pro
 Mikey
Mikey
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
