Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
When I copy scan or print it leaves dark black and gray line down the left side of the page. How do I fix this?
  • 31 Answers
SOURCE: Black line when scanning or copying
If the line only appears when the scanner is used & not when printing directly from the computer, you are correct in assuming the problem lies in the scanner assy. There should be mirrors attached to the scanner assy which will gather dust and cause copy/scan problems. Remove the glass & clean the mirrors with a DRY cotton cloth. Do not use any cleaning solution on the mirrors as they are sometimes treated & can be ruined if they come in contact with a cleaning solution. Use the dry cloth to wipe off the lens while you have it apart.Also clean both sides of the copy glass while you have it off. Reinstall glass & test.Cleaning the optics solves the problem most of the time. Good Luck!!
Posted on Jun 25, 2007
  • 39 Answers
SOURCE: HP 2600N dark gray line down the left side
Maybe your transfer belt is damaged. If u have an spare belt replace it for a test. Answer me if it dont work. Maybe i can get an support manual for u. I work in a HP partner company.
Good luck
Posted on Dec 15, 2007
  • 240 Answers
SOURCE: black strip down right side of page when scan or copy
try to align you printer..or print a maintenance pages..
if the problem still persist ...
wipe it on a wet cloth...
Posted on May 15, 2009
j0llyc
  • 8 Answers
SOURCE: Solid black line when scanning or copying from KODAK ESP-3
Get a damp soft cloth and clean the scanner glass. If that doesn't resolve the issue there is a chance the scanning unit itself is damaged.
Let me know.
Cheers, Chris
Posted on Jun 21, 2009
  • 295 Answers
SOURCE: kodak esp-3 prints large black line hen copying
open printer access door,remove cartridges and printhead.go to www.kodak.com/go/printheadsupport on how to remove printhead. click on the 3rd link that says removing or replacing printhead. put the printhead back after one minute,install both cartridges and then from menu choose clean printhead. if problem persists, upgrade the firmware of printer,ur issue will be resplved
Posted on Jul 27, 2009
Copier leaves a black line when printing through the top paper feeder. Ok coping from the flatbed
When copying from the feeder the page is fed across a fixed point at the head of the flatbed. Any dirt etc on the glass at this point can present as a dark line running vertically down the printed page. When copying from the flatbed, the scan head is moved down the page so any dirt on the glass will only appear as specs. Try cleaning the glass, especially at the head of the flatbed where the feeder is loading the page to be copied.
Jan 12, 2014 | Office Equipment & Supplies
Brother MFC-6800 1. Prints with 3/8" blank vertical line down the entire page; 2. Prints with a couple of 1/16" blank vertical lines down the entire page; 3. Prints with some gray shadow...
This solution is unconventional but it worked for me. The black roller on my MFC had irregularities on it and was creating horrible printouts. I pulled out the drum and cartridge and cleaned the large black roller. I used furniture polish to make the roller very smooth. Now it prints really nice.
Nov 29, 2010 | Brother MFC 6800 All-In-One Laser Printer
Blank line down left side of outgoing fax or feeder copy
The most common cause of blank (void) lines on a scanned document is from whiteout on the glass where the page is scanned when using the document feeder.
If there is a clear mylar sheet on the bottom of the document feeder, the whiteout may be there instead.
If there was dirt or a dark smudge on the glass (or mylar), it would show up as a black line, but whiteout is white, and shows up as a void (blank) line.
Mar 11, 2010 | HP Officejet Pro L7680 All-In-One Printer
Black streak down side when making a copy
Hello sir; I believe you need to replace drum cleaning blade.
Mar 12, 2009 | HP Office Equipment & Supplies
Black lines on the right side of every copy
depending on what the lines look like it could be the charge roller or transfer roller.
A defect on the charge roll appears as black areas on the front of the test page, and as light gray areas on the test page.
A defect on the PC drum of the toner cartridge appears as white areas on a dark, full–coverage test print and as black areas on the "text only" test page.
I have also seen a line with a 'ridge' on the paper. This will appear almost like an embossed line. This was caused by the fuser roller being scored by debris.
Jan 12, 2009 | Dell 1710 Laser Printer
Black Lines running down the right side outside of the print area
It may be the fuser. Take it out and inspect the roller on it:
  1. Switch off the device, disconnect the mains plug and wait for 30 minutes before continuing.
  2. Ensure that the bypass tray is closed, or you will not be able to open the front cover.
  3. Open the front cover by pressing the release buttons as shown.
  4. Pull the front cover down towards you.
  5. Disconnect the green plug - squeeze the sides of the plug and pull.
  6. Push the left and right levers outward to unlock the unit.
  7. Pull the unit towards you as shown and lift it clear of the device.
  8. Check the roller for wear marks, If so replace it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 21, 2008 | Ricoh Aficio CL3500N Laser Printer
Dark strip down center of page when coping from tray
There is a small strip of glass on the left side directly under the edge of the scanner, About a half an inch wide. It has something on it.
May be very hard to see, use a strong glass cleaner or some alcohol and a regular piece of paper to clean it with.
May 08, 2008 | Xerox Phaser 3200MFP/N Laser Printer
Good luck
Dec 15, 2007 | HP Color LaserJet 2600n Printer
Scanning document leaves streak down right hand side
Even a single grain of dust or a single strand of hair on the scanning glass will cause the scan head to perceive ink/image where there is none. Deffinetly try cleaning the glass using a good window cleaner, and a cloth that is completely clean, or even a peice of newspaper. If the black line remains, I would suggest taking it into a service center to have the scan head itself cleaned.
Dec 05, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
61 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
