Question about Vacuums
Have a White Jeans Machine, Heavy Duty, XL1760, one step buttonhole. Don't have a manuel and don't know how to thread, straight stitch. Its on A which it says zig zag, or straight. Also told it breaks needles.
3 Suggested Answers
wentlanv
  • 710 Answers
SOURCE: Do you happen to have
http://s2.vsmgroup.com/VSM/Pfaff/pfaffmanual.nsf
This is the webpage where you can download the pfaff 118 .pdf manual.
Handie Andie
Posted on Mar 22, 2011
SOURCE: I have a Tacsew T20U73-1
Loses top front left screw this drops lever. Right screw tightens to lock in straight stitch.
Posted on Sep 17, 2011
What is the difference between a sewing machine and a serger?
Well..... A serger (or overlock) sews a different, and usually more complex stitch. Where a sewing machine usually only uses two threads to make the stitch, a serger can use two, three, four or even five threads and will sew around the edges of the work piece, as well as trimming the edge of the work just ahead of the sewing area, or as you feed the work in, the trimming takes place first. Sergers also make a stronger seam, attributable to more thread / stitching in the seam. Sergers are versatile and quick, but one drawback is the fact that sergers make a chain stitch instead of a lock stitch, like a machine with a bobbin, and lock stitches can be pulled out, like the stitching that used to close dog food bags and bags of charcoal. A lock stitch is just what it sounds like, it can't be pulled out. You only get a lock stitch with a machine that uses a bobbin, and sergers don't use bobbins. That fact makes serging desirable for the speed of production. Changing bobbins takes up a lot of time, even if you are using pre-wounds. Hope this helps!
Sep 10, 2011 | Vacuums
I cannot get the thread up from the bobbin from the Mini Multi-purpose crafting & mending sewiing machine
Hi. Are you sure that there is a long enough tail trailing from the bobbin? Are you holding the end of the needle thread while the machine rotates through the stitch then pulling it up after one revolution of the machine? If this is a tiny hand held machine, don't expect the same performance you would get with a full size unit, and it may take some figuring out as to what will make it work.
Sep 09, 2011 | Singer Vacuums
Loose stitches tention loose long stitches, what should the setting be for straight stitches? for a 7318 model janome
Thread tension is more dependent on what you are sewing than machine model. Upper should almost always be tighter than lower, and the thread should pull up into the fabric being sewn.
Aug 18, 2011 | Vacuums
I need a instruction manual for husqvarna viking iris machine
I have an auto buttonhole maker from a more expensive machine, but it plugs right into my Iris. I just don know how to use it, or how to embroider with this machine. I didn't get a manuel when I bought it then Katrina came through and the place is no longer there. Help please.
Oct 26, 2010 | Vacuums
I need a manuel for a white sewing machine model xl1760 anybody know where I can find one?
Found it eventually!
http://homeappliance.manualsonline.com/mdownloads/42d11063-40fe-42be-95f4-c16d2b4d8474.pdf
Click the link and the file will open in a new window. You can then print and/or save it. If you are unable to open the file you will also need to download Adobe Reader:
http://get.adobe.com/reader/
Please rate this solution if you find it helpful. Thank you.
Oct 19, 2010 | Vacuums
Hi I have been lucky to have been given a Huskystar 224 which I am delighted with but the person who had it before me has lost the Overcast foot. Zipper foot. Blind hem foot. Transparent...
Oh yeah, the overcast, zipper, blind hem, and button foot are widely available - as are lots of other fun feet (such as rolled hemmers, roller, teflon, fringe, pintuck, cording, pearls/piping, felling, flower stitching, walking, freemotion quilting, you name it.) You just need to look for low shank attachments - that's what the 224 takes. Congrats on lucking out with such an amazing machine! As for the automatic buttonhole foot, I did see one on Amazon (search 'low shank buttonhole foot") that would probably work, but haven't tried that one so I don't know for sure. Happy sewing. :)
Oct 16, 2010 | Vacuums
Sewing machine needle not moving up and down
Well there are many things to check (causes) -
Upper thread has run out. Presser foot is up.
Bobbin winder shaft was left in winding position.
Buttonhole lever was not lowered when machine was placed in buttonhole mode.
Anyway you may try the steps below to correct this (Solution) -
Replace empty spool and thread machine.
Lower presser foot.
Move bobbin winder shaft back fully to left.
Lower buttonhole lever.
Good Luck!!
Thanks for using FixYa!!
Aug 28, 2010 | Vacuums
Vacuums Logo
165 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
