Question about GE GSS20IEP Side by Side Refrigerator
I can hear it running but the freezer and fridge are not cold. a friend said the compressor needs replacing
    President:
  • 2,702 Answers
They may be right there,,but it may just need a re-gas,,,
Posted on Aug 30, 2010
My KTM3900WB fridge/freezer is not freezing and cooling in the fridge. The light goes and can hear the motor is running.
You are either low on freon refrigerant, or your compressor is frozen (usually due to low freon) or your compressor is bad. the motor will cycle on and off even though the compressor is not working. the refrigerator away from the wall and look compressor will be a nerf football sizedand usually black cylinder. It could be very hot or cold/frozen. can also unplug the refrigerator leave it for a few hours and plug it back in if it work you are low on freon. You need a repairman
Jan 04, 2015 | Refrigerators
Samsung rs2630sh not cooling or freezing
If it has fan to deliver cold air, and it is not working, cold air is stuck on the begining. So your fan could be dead. And I suppose, that compressor is running all the time. Even compressor could stert freezing if fan does not deliver cold air in fridge. The other option is, that there is not enough gas in the compressor. In this case compressor vould not be freezing, but line, going out of compressor has to be hot, if it is not, there is no gas.
Dec 02, 2017 | Samsung RS2630WW Side by Side Refrigerator
There is no cooloing effect
the coolling in a refrigerator occurs when the compressor forces freon thru the system and the expansion of gas in the coils of the freezer takes heat away thus cooling the fridge. if no cooling is happening then the compressor is not running, the freon is to low on the charge, or the small "cap" line from the compressor to the cooling coils is blocked. Unfortunately the compressor is the most expensive part of the refrigerator and if it has stopped this can be a expensive problem. there is a few other things that can make the compressor stop. there is an overheat protection device on the side of the compressor that once in a while opens up thus no electrical power to the compressor and no cooling. the other part that can fail is the cold control thermastat. if this opens up the fridge can't start the compressor because the open condition of the cold control never "calls for cold". the other simple thing that can stop the cooling is a totally frosted up coil condition. the air can't circulate around the coils so no cold gets to the inside of the fridge. simple test step one unplug the fridge for 10 minutes then plug back in. Do you hear the motor in the bottom run? If it runs wait ten more minutes and put your hand into the freezer compartment. Do the sides feel cold? if the motor (compressor) in the bottom runs but freezer doesn't get cold then the system is defective and there will be no easy fix. If the freezer does show cold then the problem could be with the "evaporator" fan that circulates cold. this is an inexpensive part and can be replaced at a reasonable cost.
Apr 22, 2011 | Whirlpool Refrigerators
My Whirlpool side by side fridge and freezer not working
Most likely, if you can hear the compressor running, the fan inside the freezer is not working. When the compressor is running, open the freezer and listen for the fan running. If you don't hear it, locate it and, with a voltmeter, test for voltage across the terminals. If you have voltage present, replace the fan. You can buy replacement fans at a local appliance parts store, internet parts suppliers, even ebay.
Jan 29, 2010 | GE Refrigerators
Freezer is not cold and evaporator fan (inside
ok well... those pipes coming from your compressor one of them should be hot. if not your compressor is not running.
Nov 10, 2009 | Amana Freezers
Fan running but not keeping cold
check to see if the compressor is running, if not you may need a start kit, (relay,overload) If the compressor is running take the back freezer panel off and check to see if there is a frost pattern, might be out of gas if frost pattern has receeded
Nov 08, 2008 | Whirlpool ET1FHTXM Top Freezer...
Fridge and freezer not cold
It happenedn to my performa fridge just yesterday. It was bought in 2005. Now there is humming and clicking sound from the lower back side once in a while and the fridge is not cold. the compressor is hot/warm and it seems to be where the noise is coming from.
Jun 21, 2008 | Maytag Performa PAV2200
Freezer and Refrigirator not cooling
You didn't say if the compressor is running or not. If it is and all other things you stated are running then it has a sealed system problem. The sealed system comes with a 5 yr warranty in most cases (check owners manual). If the compressor is not running then listen for a click at the compressor. If you hear the click then I would replace the relay on the compressor. If you need further help I will need the complete model # off the sticker inside the fridge section.
Nov 09, 2007 | Refrigerators
Indesit fridge freezer (2 years old) not getting cold
if compressor is running, then you are correct in saying no point in replacing stat. by sounds of it you have a faulty compressor fault or a syatem fault - impossible to dignose by remotely. this is not a diy job i'm afraid
Jul 14, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
GE GSS20IEP Side by Side Refrigerator Logo
32 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
