Question about QSC RMX 4050HD 2Channel Amplifier
Whenever i plug in my speaker wire to the upper jack of my amp the sound eventually goes low and you get a distorted or scrathy sound from my speaker. I am using some old wires i received from a friend could it be my wires and not the amp itself.
    Genius:
  • 1,175 Answers
Thats a really nice power amp. Dont use old cable to connect speakers
Posted on Sep 01, 2010
My KLH powered sub maks e a humming sound when i plug it in but it only hums when the speaker is hooked up i tried others but did the same eventually speaker started smoking would wrong fuse do that
Wrap a wire around the outside Metal of your rca jack in back of your radio and ground the other end of that wire to the back of your radio and the noise goes away
May 09, 2015 | KLH Audio Players & Recorders
Scrathy rec audio
older batteries or not fully charged batteries can cause distorted RX. if your batteries are more than 2 yrs old they should be replaced. also dirt or moisture in the radio speaker, or trying to talk beyond their Range can also cause distorted RX. you use most of your power when you transmit.
Mar 13, 2014 | Alinco Radio Communications
Marshall MB4410, with low volume gives no real volume,
Guitar amps have preamp sections (think unpowered audio mixer) and power amp sections (Crown rack-mount amp). An excellent way to isolate audio problems if amp is still producing audio is to check the preamp out (line out). Preamp output distorted = preamp failure. Connect MP3 player to "Power Amp In"...sound distorted = power amp failure. In your case the latter is the case as your "line out" is clean. Also test each speaker for clear sound as speaker cone damage from being overpowered is fairly common. At 300w. I'll assume the failure was not from cranking the volume to loud but a shorted speaker or speaker wiring could zap the power amp in an instant.
Jan 06, 2014 | Marshall MB4410 Bass Combo Amplifier
Speaker produces noice/static/buzzing sound when it is off
That means that if too much power is going to the speaker or extraneous signals are being picked up by the wiring, it can come through the speakers as static. Stopping static requires finding and eliminating that extra electricity from transmitting through your speakers.
If you're still hearing distortion, turn down the volume on your amplifier until the distortion goes away. If the volume is too low to be easily heard, the problem may be that your amplifier produces too much power for your speakers to handle or that your amp and speakers have different impedance ratings.
Apr 04, 2017 | Boston Acoustics Duo-i Horizon Clock Radio
I get no sound at all when I plug in to the input and its not my lead or guitar, how can I fix the amp?
This is probably not a DIY repair. You best take it to a repair shop. Likely the power amp has failed or other common problems are broken connectors/jacks, broken volume pots, and finally circuit board cracks.
Nov 20, 2010 | Fender Frontman 212R 100W 2x12 Guitar...
How to connect bush active subwoofer to tv
is there red and white jack plugs in the back of the sub? if not just th wire only connections you need an amp plus the amp will have a low filter pass so the sub will work at its best, better option by a low end L.G surround sound complete with 4 speakers a sub and amp the quality is realy good
Aug 29, 2009 | Audio Players & Recorders
I thought there was a problem with the speakers or receiver, but after turning off the speakers and listening to the sound from the needle, it appears that the distortion is coming from the turntable. The...
The "needle", now called a "stylus", doesn't produce anything on its own. At the worst, the tip will shear off and it will slide across and damage the vinyl. So probably your "cartridge" is defective. Now, most low rumbling distortion would come from your turntables motor or platter bearings. Also if you unplugged the Phono leads from the preamp ports in the back of your amp and the noise goes away then you have learned that the amplifier is not producing the effect. Does this help?
Jul 03, 2009 | Stanton ST-150 Turntable
Center Channel Low Volume, Tighten Jacks worked for about a week.
Reseated connections inside Amp. so far center channel is working, also plan to replace banana plugs used to connect speaker wires to Amp.
Jan 22, 2009 | NAD T742 Receiver
Very low volume
check the mode button and make sure you are in the right mode, sounds like you have it in the wrong mode.
Sep 16, 2008 | Icom IC-R10 Handheld Scanner
Amp went into protect, but front speakers sound distorted too
If the amp still goes into protect mode, the easiest thing to do is disconnect the RCA cables from the amp and see if still goes into protect mode (after turning off/on). If it does, the issue lies in the amp or the wiring to/from the amp (most likely case). Check to make sure no speaker wires came loose and touched +12V or ground (car body). From the sound of it, my guess is something internal to the amp died and will need repair.
Mar 22, 2008 | Car Audio & Video
QSC RMX 4050HD 2Channel Amplifier Logo
66 people viewed this question
Top QSC Audio Players & Recorders Experts
 Grubhead
Grubhead
Rob Beech
Gil Shultz
Are you a QSC Audio Player and Recorder Expert? Answer questions, earn points and help others
