Question about Cameras
Memory Card When attempting to take a picture my memory card is readin "card protect". What is going wrong or How do I fix that problem? i try to take a picture or video but every time the screen says card protect so i can't... help me please? -Lacey
  • Anonymous Mar 30, 2014
    Can not take pictures why does card protected how do I fix this
    President:
  • 1,944 Answers
Check to see if the lock tab has been put in the lock position. If yes then slide to the unlock position.
Posted on May 08, 2008
Why am I getting a "memory full" error when my memory card is not full?
Try formatting the card with the camera menu. This is always safer when you buy a new card. If that doesn't work take the card back
Sep 18, 2014 | Fuji FinePix S7000 Digital Camera
Just bought x500 digetal camera and can't figure out why it says write protect on screen will not allow to take pictures the memory card is a PNY optima 4GB with the memory card out it allows 3...
Take the memory card out of your camera and look at it. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 13, 2011 | GE Cameras
Just put a new memory card in the camera but the screen keeps showing internal memory is full
How to switch the camera over to saving pictures directly onto the SD card.
    1. Menu
    2. Cam settings
    3. Chose AUTO or SD card option and Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you still experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
    After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 16, 2010 | Kodak EasyShare C643 Digital Camera
    Screen is saying Memory card is protected (reset switch on memory card) and it won't take pictures.
    if you have tried to set the switch to unlocke on your SD card, and still have this problem, you may need to open your camera to check the SD card slot.
    this tips might help:
    http://www.myfixtips.com/blog/uncategorized/how-to-fix-a-%e2%80%98card-locked%e2%80%99-problem-125.htm
    May 07, 2009 | Kodak EasyShare M1033 - black Digital...
    I cant copy song in memory card its shows card is write protected
    What sort of memory card is it?  can you remove it and install it in a card reader directly on your pc?  What is trhe phone?
    Jan 14, 2009 | Motorola Mobility ROKR E6 Smartphone
    Memory card is stopping my camera working
    Check the memore card. The write protect switch has been moved.
    Jan 04, 2009 | Olympus FE-210 Digital Camera
    Xd memory card
    A card access error may indicate that an xD-Picture Card memory card is in a write-protected condition. xD-Picture Card memory cards have a special protection feature to ensure that your pictures are kept safe. NOTE: During this condition, you can still use the printer for printing and saving photos from the xD-Picture Card to a secure location, such as the computer hard drive. To resolve this error, try the following:
    • Reinsert the xD-Picture Card memory card into your camera and turn on the camera. In most cases, the camera automatically makes the necessary changes.
    • Reformat the xD-Picture Card memory card. See the documentation that came with your camera for instructions on reformatting the memory card. Note that this process erases the pictures currently saved to your memory card. To save these pictures, transfer them to the computer before reformatting the memory card. Once you reformat the memory card, transfer those photos back to the memory card using the computer.
    Jul 29, 2008 | Fuji FinePix Z10fd Digital Camera
    How to unprotect the memory card
    the problem isnt with your camera, its your memory card, and it isnt a problem at all. simple solution- take out your memory card, and on the side there is a tiny switch. all you gotta do is flip the switch. quick and easy. hope that helps anyone.
    May 18, 2008 | Microtek Take-it MV320 Digital Camera
    Memory Card
    I have a similar problem. I pop the card out and back in and that solves it. Kind of annoying, but it works.
    Dec 20, 2007 | Aiptek IS-DV Memory Card Camcorder
    Cameras Logo
    54 people viewed this question
    Top Cameras Experts
    Are you a Camera Expert? Answer questions, earn points and help others
