Question about Texas Instruments TI-84 Plus Calculator
I have a TI-84 plus that will not turn on. Have replaced all batteries
  • 1 more comment
  • kakima Aug 30, 2010
    TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
    Does that do anything?
  • ysnoop03 Aug 30, 2010
    Thanks for responding. That did not do it. Still not working. Any other suggestions?
    Remove all four AAA batteries. Press and hold the ON key. Replace the batteries. Does it turn on now?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Having gone a month without a response to my query about the reset, I assume the suggested reset solved the problem.
Posted on Sep 30, 2010
TI-84 Plus will not turn on. Batteries have been replaced.
Try taking out the backup battery. It is located in the battery compartment, behind a little door that you must take off with a phillips screwdriver. Leave it out for about 10 hours. If this doesn't work, try replacing the backup battery.
Hope this helps.
Jun 11, 2011 | Texas Instruments TI-84 Plus Calculator
My TI-84 plus silver edition calculator is not responding. Whenever I press a button it takes forever to put it up on the screen or it doesn't work at all! I need some serious help with this. I tried...
Hi purzabumafu8,
You need to re-install the Ti 84 Plus OS on both calculators, ASAP!!! You can fix these problems by installing the newest Ti 84 Plus 2.55v. MP OS, operating system. Use fresh batteries.
If you have a friend that has a Ti 84 Plus or, Ti 84 Plus Silver Edition you can connect the two calculators together through the USB or, IO link ports. Then they can send you a copy of their OS, while you receive it on your Ti 84 Plus. Hopefully, your friend will have Ti84 Plus 2.55v. MP OS on their calculator or, it might not work. Link the two calculator together through the USB or, IO link ports with the proper cable. If don't have another reliable calculator to connect too, you'll have to connect the calculator to a computer to download the OS, goto Procedure 5. If your downloading off another calculator goto Procedure 1.
Important Note: Never disconnect a TI Connectivity Cable during a transfer. Lost of power during installation of OS will destroy your calculator.
Procedure1. Procedure to linking to another calculator.
On their calculator press, [2nd][Link][G] [Right-Arrow]. On your calculator press, [2nd] [Link] [Right-Arrow] [Enter] and, then press [ENTER] on their calculator too. Their calculator should say, "TRANSMIT" and, your's will say "Receiving." Then on both calculators once transfer is complete press, [2nd][MODE] to quit and, return to the Home screen. If the OS was transferred then your finished with these procedures. If your calculator won't turn on or, is locked up try the Procedure 2, below.
Procedure 2.
Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display
"Waiting...Please install calculator software now". If calculator did not turn on or, is still locked up goto Procedure 3, unless already did Procedure 3, then goto Procedure 4. If you calculator does come on and is responding and, your connect to another calculator goto Procedure 1. If you calculator does come on and is responding and, your connect to a computer goto Procedure 7.
Procedure 3.
Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary. Goto Procedure 2.
Procedure 4.
If the above process did not work. Try re-doing the Procedure 2, and, this time extend the time in Procedure 3, by 5 minutes to 10 minutes before you put all the batteries back in the calculator. These calculators can be a little stubborn at times so, keep trying Procedure 2.
Procedure 5.
If you can't find a calculator to connect too, you can connect your Ti 84 Plus to a computer that has Ti Connect software on it. If you need to connect your Ti 84 Plus to a computer make sure the Ti Connect software is operating properly. You do not want any hang-ups while installing the Ti 84 Plus OS.
Procedure 6. Procedure to installing the latest Ti84 Plus 2.55v. MP OS. TI OSDownloader does not always install the latest OS.
You can get the latest copy of Ti84 Plus 2.55v. MP OS and, guidebook by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 84 Plus 2.55v. MP OS!" Once your at the Ti site click the Download Item, "Ti84 Plus family operating system". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti84 Plus family operating system will download to you.
Next, click "SAVE" and then a window to a folder will pop up. It is probably a window to a folder that you download too. If so, you may want to change it and, save to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 84 Plus guidebook too, if needed. If your calculator will not turn on or, is locked up goto Procedure 2. Or else goto Procedure 7.
Procedure 7.
Link your computer and, Ti 84 Plus calculator with the USB cable or, Direct Black Link cable that came with the Ti 84 Plus calculator. Next, drag the Ti 84 Plus 2.55v MP OS that you saved earlier in "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Click, "Continue" when the "Erase Warning" pops up and, the new Ti 84 Plus 2.55v MP OS will begin to install. Next, the Ti Device window should pop up and, highlight the port when it finds what your Ti 84 Plus is using, USB1 cable or, Direct Black COM1.
When the Ti Device Explorer finds and, highlights your calculator's information click, "Select." Then click, "Yes" when the next window shows up with your calculator's information and, the OS will continue to download. Upon completion the newest Ti 84 Plus 2.55v. MP OS will be installed.
If you run into any trouble with software or, drivers just comment to what failed at this posting and, I'll be glad to help you.
Jan 17, 2011 | Texas Instruments TI-84 Plus Silver...
My ti 84 plus silver edition wont turn on. I
If that doesn't work, add a comment to this post and we'll go from there.
May 31, 2010 | Texas Instruments TI-84 Plus Silver...
My TI-84 won't turn on. If I replace the
Remove all four AAA batteries. Press and hold down the ON key for at least ten seconds. Replace the batteries. Turn the calculator on.
May 15, 2010 | Texas Instruments TI-84 Plus Silver...
TI-nspire will not turn on
Yes we changed out the batteries on now the TI-84 will not turn on HELP
Nov 23, 2009 | Texas Instruments TI-Nspire Graphic...
TI-84 Plus Silver Edition turns off immediately, all batteries have been replaced, but unit still turns off. I even replaced the memory battery.
You may need to reset calculator. Take ou the batteries and the backup battery. Leave them out for about 8 hours. Then put everything back in. Hopefully this will work.
May 21, 2009 | Texas Instruments TI-84 Plus Silver...
TI-84 Plus Calculator will not turn on, says ram is cleared
Thats because the OS is corrupt. Follow the manual and reload the OS, try the 2.43 OS
Feb 23, 2009 | Texas Instruments TI-84 Plus Calculator
RAM Cleared
This is kinda a weird situation. Because it's usually the other way around. Your ram will clear if your calculator is frozen. So take out all 5 batteries from the back. Even the back up battery. Then reset it again. 2nd then + then 7 then 1 Then 2. Good luck.
Oct 22, 2008 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
