Question about Yamaha YST-MS201 Computer Speakers
Will the woofer work without the other two speakers?
    President:
  • 2,571 Answers
There is no point.
The woofer(sub woofer) just delivers the bass. You usually put the sub woofer out of the way under your desk.
Without the other speakers you would just get the thumping bass and no treble
Posted on Aug 30, 2010
  • Bradley Ovitt
    Bradley Ovitt Jul 22, 2015
    your a jerk. im pretty sure that is the most pretentious answer ive ever seen to some one asking a legitimate question. jerk...wow
  • Bradley Ovitt
    the power switch is located on the right satellite speaker. so as it sits, no....unless your handy with a soldier pen/circuit boards and creative.....it could be bypassed with with a switch from RS but just take care to be safe about it. If unsure about that sorta backyard tinkering i would recommend not attempting that sort of thing and getting a new comparable setup of replacement speakers from Yamaha. Good luck. And don't accept rude patronization from certain parties to remain unnamed.
He power switch is located on the right satellite speaker. so as it sits, no....unless your handy with a soldier pen/circuit boards and creative.....it could be bypassed with with a switch from RS but just take care to be safe about it. If unsure about that sorta backyard tinkering i would recommend not attempting that sort of thing and getting a new comparable setup of replacement speakers from Yamaha. Good luck. And don't accept rude patronization from certain parties to remain unnamed. Yamaha YST MS50 Owner Manual
Posted on Jul 22, 2015
Remote reset
Yes the woofer and tweeter can be replaced but the woofer needs a recone kit to repair as the whole speaker cannot be replaced without replacing half of the speaker enclosure.... call JBL pro or a service center for help.
Oct 08, 2013 | JBL EON15 G2 Main / Stereo Speaker
Do i have to have the sub-woofer in order for my logitech X-230 speakers to work with my computer?
Certainly any large speaker itself cant be used with
very weak computer out signal
The signal should have power amplification in addition to
voltage amplification to energise large speakers
Oct 09, 2012 | Audio Players & Recorders
Can I use my Logitech x-230 speakers without the sub-woofer? My sub-woofer got busted!! Any suggestions?Perfectly good speakers!
i had the same problem with same speaker system. the amp for this system is inside the bass speaker. if your amp is still working but your bass speaker is not you could cut the wires to that speaker making sure the cut wires do not short out. i was quoted more to repair them than it was to buy a new set. but i wont be buying logitech again as ive had two lots fail.
Jan 18, 2012 | Logitech X-230 Computer Speakers
How to hookup
hi,
if u want to hook up the sub with ur av receiver the connect the sub woofer output of ur AVR to any one (left or right) input of ur sub woofer. then connect its power . set the frequency range between 90 and 120Hz. set the volume of sub woofer to 40% of its total. also check the av receives speaker setting. goto speaker setup and make ON the sub woofer out.
if want to connect the sub to a stereo amp without sub out. then connect the amps speaker line to the speaker input of sub woofer and connect the speaker out of sub to left and right speaker ( make sure to connect the red to red and black to black). set the volume and frequency as above
ok
Jan 01, 2011 | Wharfedale PowerCube PC-10 Subwoofer
I recently picked up the THC-c60 system without the supporting amplifier. Can I still use the subwoofer and the speakers without the amp? I note that it also came with a DIN cable, is there some way to...
You can use the sub-woofer and the speakers even without a supporting amplifier. The sub-woofer alone is powered with 167w per channel enough to power all the speakers. The DIN cables used to connect the sub-woofer to any source device like a computer, multi-media projector and others.
Dec 02, 2010 | JVC TH-C60 System
Woofer not working
If you can open the cabinet of your woofer box please check all the wires connected to the woofer and use a multimeter to check the continuity of woofer coil.If shows no continuity replace the woofer
Jul 23, 2009 | Altec Lansing VS3251 Speaker
HTS 6500/37 sub woofer
the reciever should have a "subwoofer level" setting, or a "bass level control" If you cannot find this then try to place the "sub-woofer" away from walls and elevate it from the floor. This will reduce it's loudness/ intensity at annoying frequencies...
Good Luck
Jul 25, 2008 | Philips HTS-6500/37 System
Bose acousticmass 15 sub-woofer making a noise
The sub contains the amp for the other speakers. But it sounds like the amp has a seriously damaged section and will probably have to be serviced by Bose.
Jun 24, 2008 | Bose Acoustimass 15 System
Infinity 3.5c , 2 powered Woofer 5.25" suddenly no sound.,
The woofers on my 3.5c stopped working, but with mine the light was off. I unplugged it and left it for about 24 hours and then plugged it back in and it worked. No idea why. It's happened twice and each time takes at least 12 hours or a day or so before it'll work again, just unplugging it for an hour won't do it.
It seems like both times the problem started when the speaker got unplugged without it being shutoff first, but I can't confirm.
But if your light is still on it's probably a different problem. With my 4.1t towers when the light was on but there was still no sound it equated to numerous fried amp components which cost about $150 for repair.
Oct 31, 2007 | Infinity Intermezzo 3.5C Center Speaker
Yamaha YST-MS201 Computer Speakers Logo
334 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
