Question about Mabis Health & Beauty
Model # 112-753-000 thermometer need instructions, in particular: switch from degC to degF
What does LL mean on the temp on the wine cooler?
It probably means "low level" ie the lowest level of cooling.
For a wine fridge this should be no cooler than 10 degC or 50 degF
Mar 29, 2017 | Ovens
How to use Rosemary connely Yogurt maker
can't find instructions for this particular device but I think the following instructions will be a similar principle of how to work it.
http://ezinearticles.com/?Instructions-For-Salton-Yogurt-Maker&id=1192702
When Making yogurt the start temperature is critical.
you have to get the temperature to the correct temperature to start the culture.
in step three it states . Let the milk cool to 110-115°F.
or 43 Celsius to 46 Celsius this temperature is critical so you must have a thermometer.
Jul 05, 2016 | Salton Yogurt Maker Model YM9 1 Ea
Can my 1999 Cadillac Seville concourse overheat by mixing too much water with antifreeze??
Theoretically yes. Antifreeze has a higher heat capacity than water. Basically, a liter of antifreeze can hold more heat than a liter of water. I dont think it would be enough to cause an overheat though
May 20, 2015 | 1999 Cadillac Seville
Need instruction manual for equity wireless thermometer
Hi George,
I believe your Equity wireless thermometer is manufactured by LaCrosse Technology. Here is a link to their website:
http://www.lacrossetechnology.com/
From this page, you can search the type of wireless thermometer or weather station you're trying to use. (You didn't specify a model number in your request).
Also notice that there is link on that page for Support; clicking that will take you to the Manuals link. You will need to find your proper model number in the drop-down menu.
Also, there is a Contact link, so you can contact them directly for further assistance if you are unable to find your model's information.
Good luck, George! Hope this helps!
Feb 11, 2012 | La Crosse Wireless Thermometer
My son has your safety 1st Hospitals Choice Fever Light Ear Thermometer and he has lost the instructions. Can I download them somewhere? We need to know how to use the ear thermometer. Thank you
Go to http://www.safety1st.com/usa/eng/Products/Child-Care/Thermometers/?start=0 and find your thermometer. Click on the picture, towards the bottom there is a section you can click on called instructions. Then it will bring up a new menu it will ask you to enter your product type, model, and manufacture date and you can download the instructions from there. I hope this helps.
Jun 21, 2011 | Baby Care
How do I change my Braun ear thermometer back to F from C
You did not provide a model number however the Instruction Manuals for the various Braun Thermometers can be found here:
http://braun.kaz.com/kaz/service/prodResult/
Not sure if this procedure is common to all but this may work otherwise find the manual specific to your model number.
Changing the temperature scale
This thermometer is shipped with the Celsius temperature scale activated. If you wish to switch to Fahrenheit ( °F), proceed as follows:
Turn on the thermometer. ( If it is already turned on, make sure it is not in memory mode.)
Press the /mem button and keep it pressed. Then press and release the activation button to switch over to the «change temperature scale» mode.
By pressing the activation button again, the Fahrenheit scale is activated, «°F» is displayed on the LCD. Each further pressing of the activation button toggles the scale between °C and °F.
Release the /mem button to return to the ready symbol . The temperature stored in memory will automatically be converted to the selected scale when displayed on the LCD.
Apr 24, 2011 | Braun Thermoscan Pro 4000 Ear Thermometer
Need to adjust temp from 45 degrees to 39 degrees
There is a small thermostat inside the end casing, while you are in there it is worth gently cleaning any dust from the condenser, looks like a small car radiator, use a soft brush and a vacuum cleaner.
There are 3 kinds of thermostat fitted to these
1. Looks like a blue or grey box around 2" by 3" with 2 screws on the top, the front shows graduations in degC or degf, alter the screw so that the arrow points to 39 deg f (4 deg C)
2. Small grey or white dial graduated from 0 (off) to 6 (coldest) turn knob about 1/4" anticlockwise
3. small brass shaft with a screwdriver slot in it, turn towards - sign around 1/4"
Hope this helps
Gordon
Apr 11, 2011 | Continental Manufacturing Company KC50-CT...
I need a instrution manual for a ear themoniter model no ET1200
Hi.
  • 1 Consider that most digital thermometers take a temperature in less than 30 seconds, quickening the temperature-taking process for squirmy children.
  • 2 Read the thermometer's instructions carefully. Never throw the instructions away. Keep them near your digital thermometer.
  • 3 Wipe the thermometer probe with a soapy washcloth or a tissue dabbed in isopropyl alcohol or put on a clean probe, depending on your brand of thermometer.
  • 4 Turn the thermometer on.
  • 5 Use a gentle rocking motion as you insert the thermometer into the ear canal or rectum. Never push or cram the probe into the body. Forcing it causes pain, especially if there is swelling in the ear canal or rectum.
  • 6 Listen for the beep.
  • 7 Remove the thermometer.
  • 8 Read the thermometer. If you see "ERR," you did not get good contact with the ear canal or rectum, and will need to take the temperature again.
  • 9 Use the chart insert that comes with your thermometer to see what your normal reading should be.
  • 10 Clean your thermometer probe with a soapy washcloth and/or isopropyl alcohol before storing.
  • Aug 26, 2010 | Health & Beauty
    GE Profile Side by Side is getting too cold on the fridge side.
    the dampener door in the fresh food is more then likely broke . allowing air in to the fresh food.
    Jun 06, 2017 | GE PSS25NGNBB Side by Side Refrigerator
    Health & Beauty Logo
    Top Mabis Health & Beauty Experts
    Md Fazlurrahman
    Md Fazlurrahman
    Level 1 Expert
    Dan Webster
    Dan Webster
    Are you a Mabis Health and Beauty Expert? Answer questions, earn points and help others
