FixYa.com
Tags:
Fisher and Paykel GWL11 Top Load Washer
My F&P GWL11 Toploader won't DRAIN!!!
posted by estilljs on May 08, 2008
My machine won't drain all of a sudden..the hose isn't clogged...How do I take it apart to see if there is a clog between the bucket and the hose somewhere..? unless you know of a different solution....thanks..
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 09, 2008
Helpful (85)
aborcass
Rank:Guru Guru
Rating: 88%, 859 votes
unit plug the unit first and foremost!!!!!, theres lotsa live wires underneath the unit.empty as much water as you can by hand. and you can tip unit back there is a pump located o nthe front righth side of the tub.It simply twists into place, so you can simply twist it out to check for clog..if the unit continues to recirculate water(instead of draining) while runnig there might be an issue withe the diverter vavle, which is also locatedbehind the pump assy, shaped liek a "Y"with three hoses attached to it, might be somethin in one of those hoses as well (also check the arm connected the orangish/brown motor to the diveter vavle if its broken youll need to replace the diverter valve
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 16, 2008
Not Rated (0)
scoobyhartma
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
What worked for you, I have the same problem. Thanks!
Can you Help with these Washing Machines problems?
Problem with F&P MW511
Hi team, After filling the... Answer This...
F & P Smart Drive Model...
I was just doing a wash and now... Answer This...
fisher and Paykel
can't change the settings on... Answer This...
fisher paykel gwl10...
Several problems with this... Answer This...
fisher paykel gwl11 won't drain
Thanks for the info. I'll have... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
