Question about HP Photosmart C6280 Printer
Hp photosmart c6280 ink system failure -will not print
  • tnt2258 Aug 31, 2010
    Have junked hp c6280 and replaced with hp officejet 4500. Do not need further assistance.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To resolve this issue you’ll have to reset the printer and if still it won’t work then please click on this link to resolve the issue. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 30, 2010
Oxc19a0023 ink system failure. Called HP Tech, and he advised me to enter the Red Eye Removal, Print Photos both together, it didn't work. Then I found the same directions on Fixya.com, so have done...
Try this solution.
http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-2/
The "ink system failure" is caused by air in the ink nozzles. The clear the error you need to do a full purge of the system and the above procedure with do it.
I hope this helps, if so please rate my solution.
BuddyMc
Aug 28, 2011 | HP Photosmart C6280 Printer
I keept getting photosmart ink system failure code 0xc18a0101 I have tried turning the printer off and even uninstalling and restalling the printer and it keeps giving me the same error code I have a...
Hello;
Try Resetting the printer
* Switch off the device
* Unplug the Power cable of the device and the usb device of the printer
* Wait 30 seconds
* Plug the power cord and usb back
* Try test print
If not solved try servicing your device
Nov 03, 2010 | HP Photosmart C6280 Printer
What to do hp photosmart c1580 series ink system
hat to do hp photosmart c1580 series ink system failure Oxc18a0001
May 01, 2010 | HP Photosmart C6280 Printer
Our HP Photosmart C6280 All in One printer is giving me the Ink System Failure message, I have unplugged everything & taken out the ink cartridges & put them back in, same message...HELP!
Check out our web site at: www.ccl-la.com Click on the printer repair link, we have a section under HP that gives a step by step guide to fix your printer. The problem is caused by air in the ink feed tubes and the guide shows you how to purge the lines. You should be back printing in less than 10 minutes.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Sep 25, 2009 | HP Photosmart C6280 Printer
HP Photosmart C6280 "Ink System Failure"
The ink failure error is caused by air in the ink feed tubes in your printer. This happens when the ink in your cartridge runs out and the printer sucks up air instead of ink. This is a very common problem with this series of printer. We have a step by step repair solution for this error posted on our web site at: www.ccl-la.com click on the printer repair pages and follow the links to your printer series.
I hope this helps, If so pleae rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Aug 26, 2009 | HP Photosmart C6280 Printer
Error message says: ink system has failed. Unable to print. refer to printer documentation. Error: 0xc18a0306. Turn power off then on again.
Hi
Please see this link to solve your issue--
HP Printer ink system Failure
Please do rate the solution as FixYa and Revert for further assistance.
Thanks
Rylee
Jul 04, 2009 | HP Photosmart C6280 Printer
Ink System Failure on a HP Photosmart C6280 All-in One
This is likely a cartridge problem except if the carriage is not moving at all. If you still have some of the used cartridges you can used them to trouble shoot by elimination ok. Or contact a nearby technician who has the cartriges to use them for trouble shooting. I strongly believe the one of the print carts is the culprit. Good luck
Jun 02, 2009 | HP Photosmart C6280 Printer
HP Photosmart C6280 Printer Logo
1,073 people viewed this question
Ben Johnson
