Question about HP Color LaserJet 3500 Printer
Error 59.c0 en una impresora 3505 - HP Color LaserJet 3500 Printer
  • 1,218 Answers
For those users who are having a problem with the printer motor, this C level problem is referred to as 'developing disengaging motor rotation error'. Most likely, this problem points to an issue with the function of the DC controller: either it has failed or it has affected the developing disengaging assembly. The solution is quite simple and the user may fix the error in a matter of few steps. The first step is to reconnect the J16 connectors that are used for the developing disengaging motor to the J1100 connectors that are used for the DC controller PCB (that is the printer circuit board of the DC controller). After connecting these two connectors to each other, the user must replace the developing disengaging drive assembly directly. The final step is to replace the DC controller PCB, after which the printer is to be recalibrated. for more help
http://www.fixya.com/support/t1517115-error_code_59_c0_in_hplaserjet
Posted on Sep 17, 2010
Codigo de erro 3807 como resolver?
Para solucionar el mensaje de error que indica que se ha producido un error en el estado del sistema (c?digo de error 3807):
  1. Desconecte el adaptador de alimentacion de la impresora.
  2. Espere 30 segundos para que se reinicie la impresora.
  3. Conecte el adaptador de alimentaci?n a la impresora. Si fuera necesario, encienda la impresora.
Si el error continua:
  1. Abra la puerta de acceso de la impresora.
  2. Retire e instale el cabezal de impresion dos veces.
http://support.es.kodak.es/app/answers/detail/a_id/31546/selected/true
  1. Cierre la puerta de acceso de la impresora.
  2. Espere a que la impresora est? lista para su uso.
Si el error no se soluciona, pongase en contacto con nosotros:
http://support.es.kodak.es/app/answers/detail/a_id/22432/selected/true
Si necessita mas asistencia, permita que sepa. Si esto ayuda o resuelve el asunto, por favor lo valora y da una recomendaci?n para mi respuesta. Gracias, Jose
Feb 25, 2011 | Kodak ESP 5 Printer
Tengo una impresora cannon mx 320 La impresora no imprime y me da el siguiente aviso en pantalla; ERROR DE IMPRESORA 5200
tengo canon mx320 y no imprime correctamente si es una linea recta sale torcida las letras tambien que puedo hacer
Feb 22, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Mi impresora canon mp150 prsenta error 6500 y no encuentro solucion agradeszco su opinion
Un error 6500 hace referencia a un error de la placa l?gica en la impresora. Con el fin de solucionar el problema, le recomiendo lo siguiente:
1. desench?felo y desconecte la impresora del equipo. desenchufar la impresora de la toma de corriente.
2. Pulse y mantenga presionado el bot?n "On" durante 30 segundos, luego deje la impresora solo por 10 minutos. Esto permitir? que alll corriente el?ctrica para ser dado de alta de la impresora.
3. conectar todo de nuevo a la computadora y toma de corriente. Encienda la impresora.
4. eliminar los dep?sitos de tinta de la impresora, a continuaci?n, volver a asiento. Aseg?rese de escuchar cada "clic" en su lugar a medida que los puso pulg
5. Apague la impresora y, a continuaci?n, de nuevo, prueba para ver si funciona ahora.
Si no es as?, tendr?s que ponerte en contacto con Canon para la reparaci?n de la impresora / una junta nueva l?gica para la impresora.
Dec 28, 2010 | Canon PIXMA MP150 All-In-One InkJet...
LA MÁQUINA INDICA ERROR E000805-001
1) Desconecta el poder de la impresora. 2) Quita el ladrillo/bloque negro del poder por detr?s de la m?quina. (Puede ser un malvado peque?o de sacarlo la primera vez usted lo quita.
3) Abre la cima de la impresora/multi unidad de funci?n.
4) tira Suavemente la cinta para centrar el portador de cartucho de impresora.
5) Abre o el lado de izquierda o derecha y quita el cartucho. (Depende de cu?l lado el error ocurre en, negro a la izquierda, el color a la derecha)
6) Verifica que toda la tira pl?stica que cubri? los nuevos contactos en el cartucho tiene de hecho fue quitada.
7) Toallita tanto los contactos de cartucho como impresora con una seco, hilas libertan tela.
8) Enjuga el fondo del cartucho con una h?medo, hilas libertan tela para verificar que la tinta fluye y los vistazos corrigen.
9) se Asegura de que no hay agua que queda en el cartucho.
10) Reinserta el cartucho en el portador y se asegura de que es profundizado y es insertado completamente al trasero de la ranura de portador.
11) Reinserta el ladrillo/bloque del poder.
12) Conecta de nuevo el cable de energ?a el?ctrica de impresora.
13) el Poder en la impresora y el error debe ser resuelto.
14) Corre la alineaci?n de impresi?n e impresi?n o copia varias p?ginas para asegurar el problema ha sido resuelto.
Dec 19, 2010 | Office Equipment & Supplies
No puedo escaner con esta impresora en Windows 7, alguien me puede ayudar por favor
el problema es que no hay controladores para Win 7. Hay una manera, es utilizando el plug & play de windows. Lo que tienes que hacer es conectarla mediante USB (en red no sirve el escaner) una vez que windows reconozca el dispositivo vete a el panel de control y busca impresoras y dispositivos y veras un icono con la impresora. Si le das click secundario tendras una opcion de escanear, tambien puedes ir a Paint y en la esquina superior izquieda en el boton azul tienes una opcion que dice desde escaner o camara
Aug 26, 2010 | HP LaserJet 3055 All-In-One Printer
ROS failure
Hola buen dia OKI B6500 la falla que presenta es ERROR DE ROS crei que era el laser scaner pero le puse el de otra impresora en buen estado y nada siguio al poco tiempo igual de hecho el que le quite lo puse en la impresora que esta en buen estado y sigue funcionando, este error OKI B6500 lo hacen muy comunmente este tipo de impresora,En OKIDATA me comentaron que lo provocan varios sensores sobre todo el de tapa superior pero aun que lo corrijas funciona pero al poco tiempo lo vulve hacer que mas puede ser si ya le cambien el sensor de tapa sup.,laser scaner,sensor de deteccion de toner., en OKI no especifican cual es el provoca este error nada mas dicen que son varios sensores.
NOTA: de hecho un colega hizo lo mismo y no le la corrigio lo que hace es la apaga varias veces sacando y poniendo el toner y a veces bingo funciona de hecho tiene una impresora que inicia bien pero al poner el toner se apaga o marca error que hacemos las tiramos tienen menos 80,000 paginas alguien tiene un buen TIP
Aug 19, 2010 | OKI B6500 Led Printer
Getting error 0xc18a0206
Aquí es el contenido de la charla, espero que te ayuda también! Christina es la persona de soporte técnico.
Cristina: Vamos a realizar algunos pasos para aislar el problema y encontrar una solución para ello.
Christina: Por favor siga los siguientes pasos y que me haga saber el mensaje que se mostrará en la impresora.
Christina: A. - Mantenga pulsado el "*" tecla.
B. - Presione la tecla "#" y suelte ambas teclas.
La pantalla debe decir "Intro Especial clave Combo"
C. - Presione y suelte en la secuencia de "1", "2" y "3" botones.
CustomerName: ok
CustomerName: pantalla dice "apoyar" R0631M
Christina: Fine.
Christina: 2. Oprima y suelte el botón de flecha derecha hasta que la pantalla dice "Menú de configuración del sistema".
Christina: 3. Oprima y suelte el botón "Aceptar".
Christina: 4. La pantalla debe decir "estado de error de hardware". Si no existe ya, tecla de flecha a "estado de error de hardware",
Christina: 5. Oprima y suelte el botón "Aceptar".
Christina: 6. La pantalla debe decir "estado de error de hardware: Despejado. Pulse OK para borrar ".
CustomerName: yup
Christina: 7. Oprima y suelte el botón "Aceptar". Mensaje a los cambios "estado de error de hardware Resueltos. Pulse Cancelar para continuar ".
CustomerName: ok
Christina: 8. Pulse y suelte el botón "Cancelar" tantas veces como sea necesario, de modo que, o bien el "Bienvenido a Photosmart Express" aparece la pantalla, o, el "fallo del sistema de tinta" aparece la pantalla. POR FAVOR, NO intente imprimir en esta etapa.
CustomerName: ok
Christina: 9. Utilizando el botón de encendido, apague la unidad y desenchufe el cable de alimentación de la parte posterior de la impresora y la pared.
CustomerName: hacer
Christina: Fine.
Christina: 10. Espere 30 segundos para obtener el poder de vertido y, a continuación, enchufe el cable en la toma de corriente y, a continuación, en la parte posterior de la impresora
CustomerName: hacer
Christina: 11. Encender la unidad. La impresora puede mostrar mensaje "BOTóN PARA PODER UTILIZAR LA IMPRESORA SHUTDOWN" seguido de "Pulse OK para continuar". Pulse Aceptar. La impresora comenzará la "TEMNE UNA TINTA proceso de inicialización". Permitir que este proceso para completar y no interrumpir. Una vez que el proceso de inicialización se ha completado, la impresora imprimirá una página de diagnóstico.
CustomerName: hizo una buncha ruido, y no imprimir una página de diagnóstico
Christina: Bueno.
Christina: ¿Es todavía el mensaje de error que se muestra en la impresora?
CustomerName: No
Christina: Bueno.
CustomerName: debo intentar imprimir algo?
Cristina: Vamos a imprimir una página de prueba libre, para comprobar la funcionalidad de la impresora.
Christina: Pulse sobre el menú de configuración "todo en uno" luego desplazarse utilizando la tecla de flecha y seleccione la opción Imprimir a continuación, seleccione Informe de Autoevaluación Informe de ensayo.
Oct 22, 2008 | HP Photosmart C5180 All-In-One InkJet...
TENGO UNA HP 4355 Y ME MARCA UN ERRO EN CART.
Para empezar, quite el enchufe de la corrente como unos diez minutos
Si sigue tenendo el problema quite los cartuchos y los vuelva a poner.
Si todavia tiene el error limpie con algodon y alcohol la superficie del contacto de metal donde se pone el cartridge.
Si sigue non funcionando el cartridge puede ser defectuoso, intente cambiarlo, posibilmente con uno original.
Sep 06, 2008 | HP Officejet 4215 All-in-One Color Photo...
HP Color LaserJet 3500 Printer Logo
247 people viewed this question
Seeker5211
Seeker5211
