Question about GE (PSS26MSRSS) Side by Side Refrigerator
Does freon have an order, how do you know it is leaking into the frig?
  • GE Master
  • 43,501 Answers
No odor unless there is a flame present then it will make a really caustic smell and burn your eyes...
You will know where the leak is by the oil that it leaves behind...the gas goes away, but the oil says at the spot or even drips...
heatman101
Posted on Aug 31, 2010
Avanti 308ywt compressor keeps running but frig will not get cold
Nataly if there is not any cold air anywhere and compressor is running that indicates a Freon leak and worth very little due to repair cost. You must be sure that compressor is running not the fan noise
Appliance 911 Sea Breeze
Nov 12, 2015 | Avanti Refrigerators
My LG refrigerator is not cold anymore, what can I do?
And don't forget to check the thermostat. when the motor is running and it is not cooling, think of the cooling fluid, but when the motor is not running think of the thermostat.
Feb 16, 2015 | LG Refrigerators
Samsung RS2630SH Side by Side Refrigerator not cooling down frig or freezer
Is the compressor running? If so, feel the discharge line is the line cold? If not the unit is probably out of Freon, which means it will have a leak somewhere in the system.
Aug 25, 2014 | Samsung RS2630SH Side by Side Refrigerator
Freon gas leaking from frigidaire refrigerator
Hello nmatthews748 - Once you have experienced a gas leak, I highly recommend unplugging the unit. For safety and liability reasons we do not suggest that you troubleshoot this yourself any further and to contact a professional to move forward accurately
Nov 22, 2012 | Frigidaire Refrigerators
GTS22kbp leaking from refrigerator ceiling
may be low on freon or gaskets not sealing properly
Oct 11, 2012 | GE GTS22KBP Top Freezer Refrigerator
Frig/freezer Side-by-Side GE TXF27PF is not cooling. I purchased it used a year ago, and when we got it, it had to be repaired then as well. It had the same problem - not cooling, it was determined to be...
R 134A is for automobiles not refrigerators call a certified repairman. if it is leaking off they need to test for where the leak is and fix that first .
Mar 15, 2017 | GE Refrigerators
Refrigerator is blowing air but no longer cold.
It is possible that if the compressor is running that it is either low on freon and not cooling or in some instances low on freon and evaporator is froze up - in which case frig will cool again once all the ice has melted on your floor,) Or maybe your compressor is not running - in which case its cheaper to get a new frig for sure. Listen to tell if the compressor is running. If it is, then your frig probably is low on freon. (I don't know if yours is new enough for a timer) Hope this helps you, Rick
May 05, 2009 | Refrigerators
Problem with frig
What makes you think the freon came out? How old is it? What is the model#? You need specialty tools in order to put freon back in, and you must use the correct amount.
Nov 14, 2008 | KitchenAid Refrigerators
Sub zero 532
you might have a few problems,, make sure to check the condensor is clean, also make sure the condensor fan motor is going... you might have a bad Condensor fan motor, and Ref Control or a Freon Leak @ the Evaporator... I would call a tech to check it out...
Sep 27, 2008 | Sub-Zero 690 Side by Side Refrigerator
GE frig cooling problems
This Refrigerator was charged with leak dye about 4 month before it leaked out again. Got service call, there was sticker dated 4 month ago, thats what honest company do, even if other company will come out they able to see when it was charged with freon and if they add leak dye. Got my blue flash light - found right away dye, spayed with soap - bubbles right on the spot, replaced piece of copper tube - leak fixed! call right service man at first!
Jun 17, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
226 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
