Question about Meade ETX-60 AT Telescope
My telescope is only slewing at the max speed. as soon as i change it to another speed it will now slew??
  • 3,186 Answers
Either the buttons are STICKING on your hand controller, or the hand controller cable is defective.
Contact Meade customer service:
http://www.meade.com/support/index.html
Posted on Aug 30, 2010
Meade LX90 GPS - When the telescope slews to a new location (tour or manual slew), the telescope then slews up a few degrees. I have to manually slew the scope down several degrees and hope I've...
Calibrate motors and then TRAIN the drives-- this sets the gear backlash.
You should Calibrate motors every time you take it outside and Train drives at least once every year. The symptom you describe is called "rubberbanding".
Train the drives.
Mar 03, 2011 | Meade 8" LX90 Schmidt-Cassegrain Telescope...
CG5 is brand new-not 30days old yet. Mount slews before a star is selected for alignment and continues to slew about the RA until power is cut. What is wrong. Tried 2 different power sources and factory...
You should return the scope under warranty-- however a bad power supply-- and or a bad hand controller cable can cause these symptoms called a "runaway slew".
Get a separate 12 volt power supply and the proper cigarette lighter style power plug.
Feb 12, 2011 | Celestron CG-5 Mount Telescope
Sirs: I'm the party with the "Rate Control" issue I have a new NexStar 8se.
The Rate Control only works for moving the telescope using the arrow keys. It does NOT work while doing an alignment, and GOTOs always slew at the max rate of 9.
For any other issues I would suggest you first RESET the hand controller and see if this corrects the problem and if NOT then reload the latest hand controller and or motor controller firmware, using the Celestron update cable and a computer.
Jan 26, 2010 | Celestron Optics
RA will not track on Orion Atlas mount
Are you sure it's not actually working (tracking)-- can you hear the motor running?
I would contact Orion and make sure you have a manual for the hand-controller-- it may have a setting that turns tracking on or off.
http://www.telescope.com/control/main/
Nov 14, 2008 | Orion Atlas Mount GoTo Upgrade Kit...
Celestron nexstar 8 i series alignment trouble
use the rewmote that came with the telescope and go into setup under telescope and push enter when it says calibrate motor
Nov 06, 2008 | Celestron NexStar 11 GPS (660 x 279mm)...
GOTO ERRORS MEADE LX200 10" CLASSIC
Most problems tend to be mechanical. Have you 'trained' the drive and set the backlash values? Those 2 can have dramatic effects on pointing accuracy. Also, if the optical tube is not in alignment with the mount, then nothing will work correctly. To check that, have the telescope in Alt-Az configuration, inside the house, loosen the RA lock, and shine a laser pointer on the corrector plate. as the telescope is rotated about the RA, the reflected spot should be steady. Adjust the DEC to minimize the diameter of the circle that is drawn. What is left, is the out-of-true on the DEC axis. That can be adjusted with the tube cradle alignment bolts.
Oct 17, 2008 | Meade Optics
Azimuth motor gearing problem
Sounds like it could be that the worm gear is not meshing
Look here for guidelines in the internals
Oct 15, 2008 | Meade ETX-125EC (500 x 127mm) Telescope
Slew problem
You did tighten the DEC knob? If you did the altitude gears (a worm gear) is not engaing properly. You can either return it to Meade for repairs or attempt them yourself.
I would also check that you have fresh batteries and that the UP button on the hand controller is not broken.
Dec 28, 2007 | Meade ETX-70 (240 x 70mm) Telescope
Meade ETX-60 AT Telescope Logo
105 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
