Question about U-Line Icemaker
I HAVE A ULINE CLR 60 Iice maker which was working fine until I let the condensr get too dirty. i cleaned the condenser and cona't get it to make ice. If I leave it run for a few days it will begun to make ice right away the cubes are thin eventually it comes close to normal but after a few days the ice does not continue. Ice well gets cold and everthing sounds good, i adjusted the ice thickness taking the 24 hrs to let it normalize and thought it was fixed but afeter 48 hours the bin was em[ty and the ice mold was not cold . Any ideas
  • fnfreddy Aug 30, 2010
    steady led and conderser fan runs predictibly, The only thing might be is the hot gas bypass valve, I ssume this is pressure operated, but it does show up on the sxhematic. Thanks Fred
  • fnfreddy Aug 31, 2010
    Thanks for all the informatoin. I'll do some troubleshooting and see if I can pinpoint the problem. The condenser was heavily clogged so that may have been the start of the problems. What is the adjustment on the temp switch for the bin? It was pegged in one direction with no indication of temperature setting..
  • 3,740 Answers
I need to ask if you have any LED light indications other than steady per these indications:
1. Steady light - The control board has power to it. There are no sensing problems and operation is normal.
2. Slow flash - The control board has detected a sensor problem. This will happen if the thermistor’s plug is disconnected from the control board. This will also happen if the thermistor fails open.
3. Rapid flashing - This indicated that the control board is receiving a high heat signal from the thermistor. This can be caused by a dirty
condenser, inadequate air flow (unit installed behind closed doors), failed condenser fan motor, etc.
Since you stated that you cleaned the condenser before this problem manifested I would once again check to see that the condensor fan is running at full speed or is even running at all.
- If the condensor is super hot.... you have an airflow problem.
If the bypass valve is stuck open it can also keep the tray warm.
Just a note.. if you have a small floor fan and you need ice direct it toward the bottom of the unit and see if ice production returns to normal. You may have an intermittent condensor fan. (loose connection?)
If you re-check the fan and still have problems there are other things to check. Just respond here and we can go from there. I do have the service manual hard copy.
Kelly
Posted on Aug 30, 2010
  • 3 more comments
  • Kelly
    Kelly Aug 31, 2010
    Hi Fred,
    I should have asked this the first time but at this point I am assuming if the condensor fan is running that the compressor is also running.
    The therory of operation is this:
    7. When the freeze cycle is completed, the control de-energizes the water pump and
    the condenser fan motor. The compressor remains running during the harvest cycle.
    The control then energizes the hot gas solenoid valve and water solenoid valve for the duration of the harvest cycle. The hot refrigerant gas warms the evaporator causing the cubes to slide, as a sheet, off the evaporator and into the storage bin. At the same time, the water trough is being purged with fresh water.
    8. At the conclusion of the harvest cycle, the machine returns to a new freeze cycle. The compressor continues to run. The water pump and condenser fan motor are energized. The hot gas solenoid valve and water solenoid valves are de-energized (closed).
    The symptom your describing with the compressor running (assumption end of harvest cycle) is that possibly the hot gas solenoid is not closing. This could have been your problem all along when you decided you needed to clean the condensor.
    These are the resitance checks for all windings and coils:
    FF7.5HBK Compressor Start Winding 12.0 OHMS
    FF7.5HBK Compressor Run Winding 2.9 OHMS
    CLR60 Water Valve Coil Resistance 280 OHMS
    Bypass Coil Resistance 380 OHMS
    Pump Motor Winding Resistance 71.5 OHMS
    Here is a note about the stand pipe:
    4. No Ice Production
    Cause Remedy
    - No water supplied to unit Check that water is connected and
    turned on.
    - Stand pipe not inserted in water trough Insert stand pipe securely into water
    trough.
    - Re-circulating pump is defective Replace re-circulating pump
    I still think we are dealing with a bypass valve problem. HINT: It is de-energized closed. You can unhook it for a brief period just to see if the tray gets cold. If not... give it some good strong taps with the handle of a hammer and see if the tray gets cold. If it does then your certain the bypass valve has failed / is sticking. The sticking hot gas bypass valve would have to be de-energized for the condensor fan to run per system operation. So again.. it may not be closing when it is de-energized.
    Kelly
  • Kelly
    Kelly Aug 31, 2010
    Forgot to mention the hot gas valve and the water inlet valve both have red and while wires on them.
    Kelly
  • Kelly
    Kelly Aug 31, 2010
    Fred disregard this post. There seems to be a fixya site issue and I am trying to sort it out. You post is part of the issue but will not effect your service. Kelly
  • Kelly
    Kelly Aug 31, 2010
    Fred if you don't have a parts listing the part number of the Hot gas bypass valve is 2749-S60 The cost will run anywhere from $71.00 to $143.00 depending on source. Average is about $103.00 + shipping.
    Kelly
  • Kelly
    Kelly Aug 31, 2010
    The bin temp switch should be at the 10 O'clock position. The ice thickness factory setting is +1.
    Just so you can add this to your troubleshooting checks if you ever need this info someday:
    Compressor Pins
    To measure start winding resistance, measure across the C - S pins.
    To measure run winding resistance, measure across the C - R pins. These pins should never measure any resistance to ground. This would indicate a shorted compressor.
    12. Unit Not Freezing (compressor and fan operating)
    Cause Remedy
    Little or no cooling:
    1. Check sealed system for leak or restriction / NOTE: See chart of suction pressures in manual.
    2. Bypass valve stuck in open position / Replace bypass valve
    2 more part numbers:
    Bin Thermostat is PN 2708
    Bin Thermostat Tube is PN 11841
    I do need to correct a spelling error... the hot gas bypass valve and the water valve both have RED and WHITE wires on them.
    ----Just in case you have not figured this out... the hot gas bypass valve is part of the sealed system and will require the sealed coolant system be opened (i.e freon. pressure gages, vacuum pump and torch required)
    I guess that is about it at this point.. I will watch for any future reponses.
    Good luck Fred.
    Kelly
I'm trying to get my ice maker to produce ice. Power comes on, condenser coil is clean, fan is moving air. Green light on the control panel, and water is running. But after running a few minutes, t
Scottsman Ice machine? I just learned this trick. You need CLR or something like that to remove hard water deposites. open the front then top and the right side. on the bottom in the back on the right side there is a wire going into what looks like a rubber boot. Gently tug on that plug and you will pull out the electric eye sensor. Clean that with CLR, then gently wash and reinstall. The emitter is located where the control panel is in the back on the bottom. You can't see this very well but you can feel it. Same thing gently tug on the wire and the boot pulls out. Then Clean with CLR and wash off with clean water and reinstall. What is happening is this the light or sensor is dirty so it thinks it's already full of ice.
Jan 12, 2015 | Refrigerators
Ice machine not making ice
You will have a 60-90 fill cycle, then circulate, then another 60-90 fill, then on to ice making. When Ice making starts all remaining functions come on, such as the condenser fan, and compressor. Check for these functions after the initial fill/rinse/fill has finished. if the condenser fan comes on but the compressor does not, you very well may need a control board located behind the on/off switch panel. With constant heavy loads/usage, and or a dirty condenser coil the compressor relay solder joints often become weak and short open on the board, this can sometimes be fixed by just cleaning and re-soldering the relay joint on the board. Pleazer Appliance...
Feb 02, 2014 | GE Monogram ZDI15C Automatic Icemaker
Uline under the counter icemaker not making ice. Fed from RO water and had filters replaced to help but didnt. All is running fine, but not making ice. Dups one tray every 12 hours then stops
Is the condenser fan running? Is the condenser clean? (condenser is the "radiator like" coil outside of the ice box. It cools the hot refrigerant.
Sep 07, 2012 | U-Line Icemaker
Uline 75rfb runs continuously, slow to freeze but refrigerator part keeps things cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 30, 2011 | Refrigerators
ULine CLR2160S00 was making ice then the icemaking started to slow then none at all had refrigerant replaced last year and everything else seems to be working fine,,, just no ice
Does the ice maker get water? Could the fill line be blocked? I found on my freezer ice had formed at the end of the tube and once I removed the ice it has worked fine since.
Jun 22, 2011 | U-Line ULine CLR2160S00 Echelon Series 15"...
The refrigerator is not cold.
compressor not work check power and relay. evap fan and condensr fan not work? check power ,if power ok . replacement moter .condensor dirty? cleaning up
Jan 11, 2011 | Jenn-Air Refrigerators
I have a Uline CLR 2160 ice maker. I am trying to
Your display will only show ice or off. There is no temperature settings.Now when I give the directions to put it into clean make sure the green led above the symbols is on steady. If you hold down the on/off key and hit the light key 3 times then release the on/off key last.(give a 1/2 second delay from releasing on/off key. It should go to CL. If led lights dont comeon then let me know.
Aug 08, 2009 | U-Line Refrigerator Ice Maker
DOES NOT GET COLD AANY MORE, BUT COMPRESSOR RUNS
is the condenser clean? Is the fan running? If so and the condenser is not getting hot then you need a service tech to look at the sealed system
Jun 25, 2009 | U-Line Uline Origins Series...
U-Line Icemaker Logo
497 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
john h
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
