Copy is black when copy done on feed through - Office Equipment & Supplies
    Problem Solver:
  • 16 Answers
Give details of your fax machine like make and model, then problem with cis or scanner of that machine we can solve by setup.
Posted on May 09, 2008
Black vertical line down the middle of my copies? This only happens when using the feeder.
theres a good chance that excess toner or Rubber degredation is what is causing your Black line/band,
The Manual feed tray Uses A feed roller and a Seperation Pad
If toner has spilt on to the top of the manual feed Roller Housing theres a good chance it may be Seeping on to the print paper Via the Feed roller
Instructions:-
open tray One at the front of tray one is a Closed Hatch which can be opened Upwards using the finger release catches on either end. Once lifted upwards the Manual feed roller should be clearly Visible - Rotate the feed roller until you can see the blue lock plate ho;ding the fed roller in place, insert a flat blade screw driver an d twist gently until you hear the lock plate release , remove the feed roller. You should now see the Offending Seperation pad. Cleaning the Seperation pad should be done using a Rubber restoration Liquid and LintFree Cloth. Use the same on the Feed roller . refit roller to tray and close and lock the Blue plate .
close down the Service Hatch and return to machine -
You may need to run several pages through tray one before all tread marks Dissapear
Sep 13, 2013 | HP Color LaserJet 5500 Printer
What causes the copy to be lopsided when using the feeder
I'm not sure what lopsided means??? Are you saying that the image is crooked? If you feed the paper 180 degree then the way you are feeding it now, are they still crooked? Also, do the pages get jammed? Also, look to see if one of the hings are broken? If one is broken, it's a dead give away for your problem. If that is not the problem, I would loosing up the screw that hold the adf on and move the adf a bit till the copies come out straight. Once the copies are coming out straight, tighting the adf hing screws and you are done...... Good Luck
Dec 07, 2012 | Ricoh Aficio 3025P Black and White Copier
I have a Dell V105 and i don't know what the buttons are for, i know which one the scanner is but i don't understand the others... help?
1st - color copy
2nd - black and white copy
3rd (up arrow) - # of copies
4th (4x5in) - prints a 4x5 of what is in the scanner
5th - scan
6th (x) - cancel current action
7th - feed paper
8th - power button
For me, the buttons do not perform a function and all functions of the printer I've done on the computer through printing and through the Dell Imaging Toolbox program.
Hope this helps!
Aug 16, 2010 | Office Equipment & Supplies
Black line down center of paper while using manual feed
I had this issue once before on a Canon Multifunction printer and when I talked with Canon they said it was a malfunctioning scanning bed. They sent out a new one and I replaced it and had no further problems.
Jun 18, 2009 | Dell 1600n All-In-One Laser Printer
Automatic feed gives a white line in copy or scan
Although this problem would normally show as a black line on the copy, it's quite possible that there is something white (i.e. a piece of tape or paper) stuck on the scanner where the page feed passes through. Clean this area carefully with a soft cloth.
Jun 01, 2009 | HP LaserJet 4345mfp Printer
Black line down page when coping from copy feed
The small glass surface at the top of the scanner bed had some gunk on it. I scrapped it off and the line went away! Yay!
Jan 01, 2009 | Brother Multi-Function Center MFC-240C...
I have black vertical lines on copies from automatic feed
Good luck. I've tried everything. The stupid thing jams on me 9 of 10 times so I guess the good news is I don't get a lot of black lines since it won't even print.
Jul 07, 2008 | Samsung CLX 3160fn All-In-One Printer
Copies have black vertical line down center of the page when fed through automatic feeder, but it doesn't happen if you place them inside manually.
Check your glass and rollers where the paper feeds through the machine. Most like they just need to be cleaned. Can be done with a q-tip or tissue and a little rubbing alcohol.
May 09, 2008 | Office Equipment & Supplies
48 people viewed this question
jasbo
jasbo
