Question about Garden
Do I mix the gas with 2 cycle oil for the homelite mighty lie 26vt gas grass trimmer and what is ratio I need?
  • 183 Answers
Your MightyLite trimmer requires a 50:1 fuel mix. Use a high quality 2 cycle oil that is made for lawn equipment. Do not use outboard boat oil...it will cause your trimmer to run too hot. If you use the mix that has fuel stabilizer in it, then the bottle will be 3.2 ounces. Use one 3.2 ounce per gallon of gasoline.
Posted on Aug 30, 2010
What is the gas to oil ratio for a homelite cs-40 chainsaw?
Hi gnapplegate...
Use a 50:1 oil to gas ratio
1 pint of 2 cycle oil to 6 gallons of gasoline
Please take time to rate me
Aug 31, 2011 | Homelite Mighty Lite Lawn Trimmer
What is the correct fuel oil mix for a homelite whipper snipper
I believe Homelite calls for 40:1 (2.6oz. oil to 1gal gas) mixture, but if you are using a good current brand name two cycle oil, 50:1 (3.2 oz. oil to 1 gal gas) would be safe also.
Feb 08, 2011 | Homelite Mighty Lite Lawn Trimmer
Need to know gas /oil ratio of a homelite d725
All 2 cycle engines recommend 1 can of 2 cycle engine oil to 1 gallon of gasoline. It's pretty universal.
hope this helps.
Aug 13, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite gas trimmer ut20602 from 1998 need oil mix ratio...is it 40:1 or 50:1
Use the 50:1 ratio oil mix.the oil bottle will tell you how much oil that you will need to mix with how much gas you have,40:1 will make the trimmer smoke too much and it will foul plugs prematurely but won't hurt the machine.
Jul 30, 2010 | Homelite Mighty Lite Lawn Trimmer
Fuel mixture ratio
50:1 with fully synthetic 2-cycle oil, 25:1 with semi-synthetic or mineral oil.
I use synthetic oil at 50:1 - more power, no smoke, and no fouled plugs.
Jun 16, 2010 | Homelite Mighty Lite Lawn Trimmer
What type of fuel mixture do I use for 20760 Homelite gas trimmer?
Most likely not the answer you are looking for but here is a shot:
Pick up a bottle of the Echo brand 2-cycle oil. It will say "Extended Life" on the labeling. This is meant to run in Echo products, but it is a very FINE and well engineered oil. Mix it according to label directions for 50:1 ratios. (2.6 Oz. to 1 Gal. Gasoline)
When mixed at this ratio it provides MORE than adequate engine protection for ALL 2-Cycle engines, including those that run in 40, and 30:1 ratios.
I mix one 2-cycle tank to label instructions on the Echo oil for 50:1. It handily runs in my Echo chainsaws, non-echo trimmer, Poulan Pro leaf blower, etc. They all run different ratios, but THRIVE on the Echo mix without as much oily residue and smoke to boot!
CAUTION: I do not know of ANY OTHER MAKE of 2-cycle oil that CAN DO THIS *SAFELY*.
Remember:
Always mix your 2-cycle fuel starting with *fresh* gas.
Mix only that which you can use in 30 days.
Use 89 Octane fuel to make your mix in small piston 2-cycle engines.
Clean and re-oil intake filters @ every 10 hrs. operation time. Check and re-gap your plug when you service your filter!
DRAIN unused fuel from tank back into gas mix container. Restart and let engine idle to run any remaining fuel out of engine and carb. Storing fuel in ANY 2-cycle longer than two weeks is going to gum them up and nothing short of a carb rebuild will get them sputtering back to life again!
May 08, 2010 | Homelite Mighty Lite Lawn Trimmer
Correct gas to oil ratio for Homelite Mighty String Trimmer Model
most trimmers are 50:1. or 40:1. i would use synthetic 2 cycle oil and use the 50:1 ratio. i know guys with trimmers that require 50:1, and they use synthetic at 80:1 with no problems for years. they say the engine runs cleaner. i am a part-time lawn care operator.
Jun 18, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
182 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
