Question about Coleman Air Tools & Compressors
Can I find out from a serial # on a coleman air compressor what model# it is. The serial# is z31410070 and the model # on the front says L7006017 and 80Gal but according to the parts manual, the 80 gal model # should read L7008017. I need to get a new pump assembly and want to make sure I get the right part. Thanks
  • jillw64 Aug 30, 2010
    Thank you, I finally got hold of Powermate, Inc.
    Problem Solver:
  • 10 Answers
To the best of my knowledge Coleman never made a L7006017. After years of wear and tear the 8 probably appears to be a 6 on the tag.
You need a Coleman 165 pump or an equivalent. If you need pricing or availability let me know.
Hope that helps,
under_psi
Posted on Aug 30, 2010
How to change oil in sandborn compressor?
Coleman/Sanborn Compressor Owners Manuals - Air ...
www.aircompressorpartsonline.com/coleman-powermate-and-sanborn-ai...
Coleman/Sanborn Compressor Owners Manuals. Download to your computer and keep it handy. - Air compressor parts for most makes and models of air ...
Sep 12, 2015 | Air Tools & Compressors
Coleman POWERMATE Lo502710. Compressor runs and builds up pressure and then keeps on running even when 100 PSI. It will not shut off. I do not hear a leak when I pull the electric plug to make it stop...
There is a problem with your pressure switch. You should have a little black box with a red lever to turn your air compressor on and off. This housing contains your pressure switch, the pressure switch sends an electrical signal to the switch to make your air compressor run. When enough pressure builds up the pressure switch activates, and breaks the signal until the pressure drops below a certain point. I will do some more research on your compressor and find out which pressure switch you need to order. i need you to find any numbers on the compressor you can, serial number, model, stock number, anything you can to help me find the part number.
Thank you for patience,
Calvin Smith
Nov 19, 2011 | Coleman Powermate 27 Gallon Air Compressor
Can,t find replacement parts for this lemon thanks
ww.ppe-air-compressors.com/coleman-powermate-air-compressor... - CachedColeman Powermate Air Compressor Parts, Breakdowns & Manuals. Choose Your Model # Below to find Breakdowns & Repl.
I just browsed the net and found several sites that sell coleman parts. Above is just one I copied and pasted. If your unit is older, if you know the type of pump you can search for that. eg. (debilvius) A lot of compressors have the same pump under a different name like Coleman, Sanborn etc. I have found some units that are just so old they are obsolete and parts just aren't available.Hope this helps. Good luck!
Aug 16, 2011 | Coleman Air Tools & Compressors
I want a operators manual for a coleman powermate air compressor 20 gal tank
You should be able to download a manual from this site:
http://www.powermate.com/productmanuals.php?cat_id=1
The VLF1582019 is a 20 gallon model but you should confirm if this is the model number of your unit.
May 23, 2011 | Coleman Powermate 02 - Gallon Air...
Coleman air compressor Model # MLO503013 what kind, type of oil is used in the compressor crankcase. The owners manual has been lost or misplaced. Thank you!
If it takes oil, you should use air compressor oil or, if you cannot find this product at your full service auto parts store, use SAE 30 non detergent.
Thanks for your visit today.
Dec 28, 2010 | Coleman Air Tools & Compressors
Air conditioner blows the breaker when starting up
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Jul 27, 2010 | Coleman Mach III Air Conditioner
Need a manual for a Coleman Powermate air compressor Model #VP0200608 Elec.
I'm looking for a owners manual for a colman powermate air compeser modle cl0502710
Apr 18, 2009 | Air Tools & Compressors
Need replacement brushes for Coleman Air Comp L0552709
you can try at mastertoolrepair.com they have parts just have to see if your model is in there system
Jan 14, 2009 | Coleman Powermate 27 Gallon Air Compressor
Coleman compressor no build up of pressure
Parts for coleman are available at www.mastertoolrepair.com your compressor is listed as L0502710. If however you like to tinker, you can make a pretty good reed valve out of aluminum can material or other (any ideas?). It is fairly easy to cut, does not last as long as factory stainless steel, but for short term, why not? Good Luck
Jan 10, 2009 | Coleman Powermate 27 Gallon Air Compressor
Air Tools & Compressors Logo
54 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
