Question about Garden
I have a blue rhino model #GBT611B,the regulator # 55-15-248 will not ajust flame, I have low flame only, turn knob and it does not effect flame at all.Pleas help me to find a new regulator, i purchased grill frow lowe's hoe builders they have no parts. thank you.. Henry Burnett.
burzerko
  • 254 Answers
SOURCE: low flame
This problem most likely is with your regulator. if you decide to replace it please make sure you get the right size replacement. Some salespeople dont know the difference there are four common sizes from class 1 to class 4. If you take the old one with you make sure you match the numbers up with a new one.
Hope this helps You
please rate me.
Posted on Jul 20, 2008
Treefrog15
  • 127 Answers
SOURCE: low flame on burner...
Remove the burner and check the flexible tubes for kinks or blockages. The flexible tubes usually just slip over the backs of the valves. Spiders love to get in there and block them. Also check that the holes in the burners are not clogged. Be careful when reseating the flexible tubes to be sure that they are properly seated on the back of the valves. Failure to properly seat the flexible tubes can cause leakage there, and the gas can ignite at the back of the valves and not reach the burner. Be certain that the replacement burner is designed to use with your grill and the flexible tubes mate properly with the back of the valves.
Posted on Jul 07, 2009
  • 8 Answers
SOURCE: Can not adjust flame.
It sounds like the grill just needs a good cleaning, plus when you do clean it check that the burner tubes and orfaces are free of any debris.
The orface is a tiny hole inside a small brass threaded insert where the gas blows through into the burner tubes, it is very critical that this is clear as well as the burner tubes.
Posted on Jul 29, 2009
SOURCE: just bough weber Q200 grill. Is it normal that the
I have used the Q-series for 2 years. The blue and low flame is absolutely normal. Weber's philiosophy is of avoiding flare ups when grilling for best taste. I love this grill - very easy to clean, uses less gas and makes great food.
Posted on Aug 23, 2009
radar001
  • 1051 Answers
SOURCE: low flame
Next time you use the grill turn the gas on slowly. For some unknown reason when turned on quickly the regulator reduces the gas flow.
Another problem with some gas fittings is an auto shutoff if detects the slightest leak. Sometimes the shutoff is not 100% and allows a small amount of gas causing the weak flame.
Posted on Apr 27, 2010
Pilot light won't stay lit when I let go of the igniter knob. Flame is yellow and long.
Sounds like the Thermocouple has failed and needs to be replaced. It's not difficult to do. But, finding the part may be. Blue Rhino, is the manufacturer for Endless Summer Patio Heaters, so start there.
May 19, 2011 | Endless Summer 2009 Open Flame Patio...
I have an endless summer patio heater the pilot lights but the does not stay on when you turn the knob to start the heater. Got it on once but then the flame blew out and could not start again
You need to replace the Thermocouple. Endless Summer Patio Heaters are manufactured by Uniflame, which is owned by Blue Rhino. You can order the Thermocouple direct ly from either company. Just make sure you have your Model Number handy.
Mar 06, 2011 | Endless Summer 2009 Open Flame Patio...
I have an Endless Summer (Blue Rhino) patio heater with model number 153100 and the pilot flame is not strong enough to keep the thermal coupling open. What has to be done to fix that?
The pilot jet may be clogged. If there is a flame, it must be small and blue. A large flame that is orange or yellow tipped means that there is a partial blockage in the pilot assembly which needs to be cleared. The pilot flame must also touch the thermocouple in order to heat it correctly. Make sure that the pilot jet and thermocouple are positioned correctly. If you have an extremely small pilot flame, try repalcing the regulator and hose as the regulator may be failing.
Sep 02, 2010 | Endless Summer 153100 Open Flame Patio...
Low flame
Apr 27, 2010 | Weber Genesis Silver B Grill
Blue rhino endless summer patio heater
Try replacing the regulator, easy fix. If it is not the regulator, the thermocouple could be bad, or the pilot flame may not be strong enough to heat the thermocouple. Take apart the head, if you are comfortable with it, and see if there is a blockage in the pilot assembly.
Jun 28, 2009 | Blue Rhino Portable Patio Heater
1st burner goes out when 2nd burner is turned on
I had the same problem. They original regulator and hose were poorly designed for this model. There isn't enough room underneath without crimping the hose. I bought a standard regulator and shorter hose combination a Home Depot for about $20. It makes a 90 degree turn coming out of the tank and does not kink the hose.
It was worth the $20.
Mar 29, 2009 | Grilling
Oven will not respond
The knob won't have any effect on the flame size.  The knob controls temperature.  If you're referring to the pilot light staying on and then the main flame not going on...that's another problem.  If the main flame will not go on, the assembly that controls the main flame is likely defective.  If the unit has a thermocouple, you might change it out first.  Sometimes, that's all that is needed and they're cheap.
Nov 23, 2008 | Rangemaster 110 (Gas) Kitchen Range
My ventless gas heater has an uneven flame with orange tips, the flame toward the outer edge is higher than the flame in the middle, and also,when I light the heater, it doesn't just give me a piolot...
This sounds like your gas valve is weak. An orange flame has to much gas and not enough air mixture. Have you trie to ajust the air mixture. If it won't ajust then you will need to replace the valve.
I hope this helps.
Oct 24, 2008 | Heating & Cooling
Garden Logo
186 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
