Question about Cullmann Magic 2 2722 Tripod
A mall piece of plastic broke within one of the legs which seems jammed. Can you supply advice and or repair service for this Cullmann Magic 2
jessee007
  • 310 Answers
SOURCE: plastic tabs on leg locks broke
yes with the original plastic locks. "junk" go to ace and you will find some differant lock slides. I did and they are not plastic!
Posted on Dec 31, 2007
SOURCE: VGB3 leg lock broke
On the velbon vgb 3, the leg locks consist of a lever, one or two pieces of metal and a plastic piece. The metal and plastic pieces rest in a depression against the lever. When the lever is pulled out, pressure against the smaller leg section is released. When the lever is pushed in, pressure against the smaller leg section is exerted, locking the legs in place. On the back side of each joint, there is a phillips head screw which acts as a stop to keep the leg section from coming all the way out. When the screw is backed out, the leg section can be removed, exposing the latching mechanism. If the only problem is that the latch mechanism came apart, it can simply be reassembled. If, however, something broke and allowed the latch assemby to come apart, that will have to be dealt with as well. My guess is that the phillips screw may have become loose, and the latch came apart.
Posted on Oct 24, 2008
SOURCE: Leg lock broken
Assuming you still have the female part with the treads in tact, you can do what I did. I used a hose clamp, the kind used on radiators, but larger. First, take off the lock down knob, then put the hose clamp over the broken plastic housing and mark where the knob would screw through. Then remove the hose clamp, placing it on a sturdy surface and use a 5/16 drill bit to make a hole where the lock down know will pass through. Place the hose clamp over the plastic housing, insert the knob, tighten the hose clamp (but not so much that it restricts the tripod leg from moving) and you are done! I can send you pictures of the process and the final result. It saved me from buying a new tripod! I can be e-mailed at boingsplatplop@yahoo.com if you have questions.
-Spencer
Posted on Nov 17, 2008
SOURCE: Tripod Sunpak 7575 plastic piece inside leg
does anyone know were you can buy spareparts for a sunpak flash?
Posted on Oct 20, 2009
  • 685 Answers
SOURCE: Think its call cullmann magic tripot. The one you can make
it can, if ou don't feel qualified or have the parts you can send it back to: http://www.rtsphoto.com/html/dlrslnks.html
Posted on Jun 25, 2010
Hp fake paper jam
Usually if it says there is a paper jam, there is. Remove the paper trays, look at the rear, and also open the rear of the machine. If you had a jam and removed the paper, make sure the piece of paper is whole. A mall piece in the sensor will give the error. I had that on a large Dell network printer. Also try removing the power to the machine for 10 seconds.
Apr 14, 2017 | HP Office Equipment & Supplies
We have a Krups FBC4 1600 Watts Toaster Oven. The door hinge seems to have disconnected from some kind of spring mechanism within the left wall, is there any way to take apart/repair it or have it...
Here is a Krups website address that helps you locate service by state or contact the Krups company.
http://www.krupsusa.com/Consumer+Services/Service+Centers/List/CentersList.htm
Apr 08, 2011 | Krups FBC4 1600 Watts Toaster Oven with...
Dear sir this product once on green indication within seconds going to red indication.
There are five fans in the projector.
2 for LCD cooling
2 for lamp cooling
1 for power supply and lamp drive unit
if any one is not moving, faulty, broken, than the problem occur.
Experience: many times a broken piece of plastic or self removed screw to stop the fan moving or jam to dust.
Solution: service your projector and fans
Jan 21, 2011 | Panasonic PT-LB51U Projector
The lowest section of one of the 'legs' of my Linhof tripod suddenly fell out. I retrieved the clip, rectangular black plastic piece and a flat 'silver' piece and that is all. Cannot replace the section...
Linhof photographic equipment is sturdy and robust, designed for use by busy professionals. I cannot understand how you can break this item not once but twice. Take it to your local repair facility and get them to repair it for you.
May 05, 2017 | Linhof Photography
Cannot unscrew leg for unipod off with plastic piece included.
I carefully used a needle nose lock pliers on the plastic part with channel locks on tripod leg and was able to loosen the part.
Mar 25, 2009 | Cullmann Magic 2 2722 Tripod
VGB3 leg lock broke
Aug 14, 2006 | Velbon Chaser EFL-4 (A) Tripod
Cullmann Magic 2 2722 Tripod Logo
Top Cullmann Photography Experts
Tony
Are you a Cullmann Photography Expert? Answer questions, earn points and help others
