Question about Cycling
I have a typical 21 speed hybrid- a GT Timberline. My chain is frequently jumping off the sprokets and getting caught between the sproket and the frame of the bike. The chain seems to have too much play in it, but I have been unable to adjust the tension on the derailier. What would you suggest?
  • 718 Answers
You need to readjust your derailleurs if you do not know how take it to your local bike shop they will be glad to help.
Posted on Aug 30, 2010
Howdo i get the caseing off the front sproket 1992 750 nighthawk
Hi,I think you are talking about the front drive chain sproket casing.
well if this is what you meen,you just have to disconnect the linkidge for the gear lever undo the allan key screws and it should just pull off,hope this helped.
Apr 17, 2015 | Motorcycles
Honda unicorn drive chain is jumping with extreme knocking sound.
Try checking the gearbox oil level and adjust the chain.
Apr 03, 2017 | 2005 Honda Unicorn
How do I remove the inner timing chain cover on a 1998 Nissan maxima 3.5L
it's extremely difficult,you need to remove the timing chain,all sprokets and then remove all the bolts,some of these are behind the timing sprokets
Dec 21, 2014 | 1998 Nissan Maxima
Greenfield mower chain tension
take chain off -- lay on floor --pull taught end to end push together --if it flexes more that one quarter of a inch --chain is worn --replace chain--also see how deep chain sits on sproket--- if sits too deep sprokets are wore and need replacing
Dec 27, 2013 | Garden
Knocking noise of chain in honda dream yuga bike when accelerating after shifting the gears. i have tightened the chain but still it happens.
That knocking noise could be that the teeth on your main drive are worn out and chain is jumping them on acceleration.Pull th primary cover and check the drive gear for chain on motor sprocket.Replace it if worn to that point.
Oct 02, 2013 | Honda Motorcycles
How do i get the sprocket off
If you mean a front sproket, it is likely to be held on by 4 or 4 bolts to the crank arm.
If you mean the rear cassett, you will need a chain whip and a lockring tool. Hold the sproket still with the chain whip then undo the locking with the tool.
Feb 28, 2011 | Cycling
Popping noise coming from front sprocket when wheel is turned on 01 suzuki gsxr 600
hi it sounds like your front sproket is really worn and hooked when you turn the chain its not releasing the links smoothly ,replace it with a new one and check the condition of your chain it may be worth replacing a complete chain and sproket set as running a bike with a worn front sproket could lead to a back wheel locking up at speed if the chain jams
Feb 22, 2011 | 2001 Suzuki GSX-R 600
Cant find sproket number 76695
Super Deluxe ? Do you mean a Poulan chain saw. Check here they handle all brands of chain saw parts.
By the way Poulan is owned by Husquvana, which is owned by Electrolux.
sales@mfgsupply.com
Feb 04, 2010 | Garden
Need to replace timing chain on 2005 cavalier
I'm doing this myself, and there are some annoyances. Yes, a service manual is good, however, I consulted 2 manuals and got two different answers. Here is the real deal for the 1996 2.2 vin 4 cavalier.
Remove the right tire and platic sheilds. Remove the tensioner pully, (2 bolts).
Remove the harmonic balencer on the crank shaft, 3 bolts first then the center.
Use a pull hammer with correct thread to pull off the "crankshaft thing" on the end of the crank shaft. Be sure to pull it off evenly. I had to find a bolt with the same threads, cut that off, and tap a fitting for my **** hammer. It's on there good.
Remove 7 (8mm) bolts from around the chain cover. Remove the 2 (10mm) bolts from under the cover. Those two studs also have to come out with a small inner tourqe socket. These are very very easy to strip, be careful. The cover is now free.
It is sealed on tight. There are a couple good places to get a bite on the rear facing edge. You will also have to work from the top and bottom to get it free. It pulls strait out, it is positioned by pins. Be patient, that cover will break.
There is silicon that seals the bottom of the cover. Clean that all off with a scraper and wire brush. Pull off and clean where the gasket seats all around the cover. Clean the cover. Replace the gasket and the outer oil seal that goes around the crank shaft. The only way to get that seal out is to break it. Press the new one in with a vice, do it evenly and slowly.
I've found a good method to get the cam shaft sproket off.... There are 3 slots and a hole. Rotate the cam sproket clockwise till you get the hole to about 9o'clock. Put drill bit or short piece of hard metal (something that won't bend) in that hole and apply some pressure while you rotate another 10 degrees or so. The bit will drop into a hole. Now rotate counter-clockwise and the bit will bind the sproket so you can remove the bolt. Nice huh? I get it unbound by putting a screwdriver between teeth and prying against the crank shaft. Use your imagination.
The timing **** is retarded. And I still havn't found a deffinate answer for everything. The crank shaft makes two rotations for every one that the cam makes. The first crank shaft rotation is the compression stroke, the second is the power stroke. I don't know how to tell the difference.
To get the sprokets aligned, re-install the cam sproket, don't worry about getting it tight. Rotate it clockwise until the hole in the sproket lines up with the ear on the chain tensioner. Now, bind the gear right in that spot and remove it. Now, take that "crankshaft thingy" and push it on by hand as far as you can. Notice the key, and dot on one of teeth. Put the bolts partially in the thingy and rotate it by using a bar or screwdriver between the bolts. Move that sproket until the dot on the tooth lines up with the ear on the chain adjustor. The key will point directly up. Good job. Tap that thingy off the shaft now.
Compress the chain adjustor and put a pin through it. With the cam sproket removed, put the chain on it. Work the chain onto the crankshaft sproket. Slide the cam sproket onto the camshaft. Easier said than done, but it is possible. If you are having a hell of time, use a mirror and check that you are lining it up properly with the pin/key in the crankshaft. I found that leaving a little slack at the top, as opposed to the bottom helps. FYI, when i say little, i mean it. There is very very little slack, but the chain does buckle slightly.
Remember me saying that I have no idea how to tell between power and compression stroke. Now you will hate me. To get mine right, I had to tighten the cam sproket then replace my spark plugs and attempt to start to start the car. I guessed mine right the first time and it ran fine. However, if it ran rough or not at all. I would have had to remove the cam sproket again, remove the chain and rotate the crankshaft sproket one full turn.
When you put this all back together, use plenty of slicon on the bottom of the chain cover. Re-assembly is a snap, or at least is was for me.
Jul 28, 2008 | 1998 Chevrolet Cavalier
Cycling Logo
85 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
