Question about Acer AL1716 17" LCD Monitor
Power light blinking, blank screen - Acer AL1716 17" LCD Monitor
  • 11,361 Answers
Try it another PC and check the cable first, if still does not work, then you will need to open it up and look for bad caps with leaking/bulging tops/or bottom seals.
See failed ACER monitors here:
Failed TV and monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Aug 31, 2010
4 Suggested Answers
benwabnick
  • 2404 Answers
SOURCE: Light on power on switch keeps blinking, screen blank.
Definitely a problem with the monitor. If you can get the back open then look at the main board and the power board. You will want to look for puffy capacitors. Instead of a flat top it will look puffy like its pregnant.
If you find any like that then you need to replace them with new capacitors that have the same Uf rating and at least the same voltage or higher.
This will take some unsoldering and soldering skills. Make sure the stiped edge gets aligned with the striped edge on the board.
If you replaced them then the monitor should turn back on. If it doesn't then its a screen problem and you'll need to get a new monitor.
Posted on May 01, 2010
  • 38 Answers
SOURCE: Screen is blank. Green LED power light is
Might be your graphics card, try swapping it out for a new one and see if that works
Posted on Oct 09, 2009
SOURCE: green light blinking screen blank
It is not a computer issue. It is a power issue with the monitor. A tiny capaciator needs to replaced which requires soldering.... better just buy a new monitor if not under warranty
Posted on Mar 17, 2008
Samsung 906vw blank screen
if the power light indicator is just blinking with no display, you must checked the power supply the common cause bulging electrolytic capacitor. just replace with the same value and rating then the problem solved.
Jul 22, 2012 | Samsung Computers & Internet
Good day.. my compaq presario cq40..is powering on but blank on the screen and caps lock and num lock blingking only..thanks
Hello good day,sir
My compaq presario cq40..is powering on but blank on the screen and caps lock and num lock blingking only.I try ready so many time but everything are not meaning for me that's why i need your help,sir.please,give me some advice for power back.
Thank sir.
Feb 18, 2011 | HP Compaq 6735s Notebook
How can i fix my blinking power light. and i have blank screen. everytime i switch on it keeps on blinking
on some pc's a blinking power light denotes the batteryy is in the process of charging.The blank screen means your operating system is not loading properly try F2 to go into bios and set boot options use the "tab"key to navigate.then "enter"to select and change boot sequence play around with the settings untill you are familiar with these pages--this is of course if you havent totally corrupted you os in which case your best bet is to reinstall os from disc--good luck!
Davey Snake!
Oct 20, 2010 | Computers & Internet
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Oct 09, 2009 | Dell E173FPb 17" TFT LCD Monitor
Blackberry pearl 8100 blank screen & green blinking light
Try performing a hard reset: remove the battery from the device while it is still powered on, leave it out for 30 seconds, then reinsert.
Sep 28, 2008 | RIM BlackBerry Pearl 8100
Power indicator light blinking
Check soldered in micro fuses...F850, F851 etc.....
1) solder jumper wires on signal board = 008,010,017,048,600
2) Check / replace STK392-110 convergence IC's with Toshiba
part # 23135090 or upgade to Hitachi part # CZ01341
Let me know....................T.
Jan 04, 2008 | Toshiba 65HX81 65" Rear Projection...
Blank screen, no sound
If ti blinks three times, then it may be an issue with the flyback transformer. It's called "three strikes"...it tries three times to come on, and after that enters a safety shutdown mode to protect the TV. Might need to have a professional shop take a look at it.
May 02, 2007 | Durabrand DWT1905 TV
Acer AL1716 17" LCD Monitor Logo
429 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
