Question about Dewalt DW745 10" Compact Job Site Table Saw
I cannot remove blade guard assembly from my DeWalt ( DW745) table saw.
rowdy45176
  • 2176 Answers
SOURCE: dewalt 10 inch portable table saw blade height adjustment very st
What I would do is clean area with air (wear safety glasses) then I use a spray type of dry lubricant on the threads and also the plates that the motor slides on. You can also use WD-40 in a pinch. Hope this helps
Posted on Dec 10, 2008
  • 8 Answers
SOURCE: Dewalt Table Saw
I don't know about Cleveland, but a while ago I replaced the bearing on my Sears Craftsman saw, and it wasn't a hard fix. I would expect any competent repair shop could do the repair easily. If you can get the arbor off and take it to the shop, that would be ideal. It only takes loosening a few bolts to get it off. I first removed the cast iron top from the sheet metal base so I could turn it over, but it can be done from the bottom, too. Just be prepared to eat some sawdust. The most specialized thing the shop would need is a bearing press to get the bearing in and out of its seat, and many shops would have these; they aren't very expensive. Maybe a good machine shop which does small jobs could do it for a small fee. A good place to find these is at your local auto parts store, such as NAPA or O'Riellys (here in MIssouri, anyway, but you get the idea). Your auto repair shop probably knows one or two they use for 'turning' brake drums, etc. BTY, I didn't have a bearing press and I did the job with carefully tapping the bearing back on with a sleeve made from a piece of scrap pipe. Tauton Press makes a great DVD on tuning up your saw after this fix, as you want to make sure
it is square with the table in two dimensions - parallel to the miter saw slots and perpendicular to the top. Good luck.
dcm
Posted on Oct 01, 2008
  • 80 Answers
SOURCE: How to change blade on 10" Craftsman table saw?
you need to grab the blade with something.maybe some pliers(if you are not going to refurbish blade) and loosen the nut in the center of the blade. i think it is a left hand thread(cw to loosen) because of the rotation of the blade. if the nut is on the left when looking from the front it is probably left handed. make sure it's unplugged and wear leather gloves so you don't get cut. install in reverse...
Posted on Jan 20, 2009
  • 59 Answers
SOURCE: old craftsman table saw parts?
most sears stores have a dept. that refurbishes and sells these tools. if it can be had, they can help.
Posted on Apr 25, 2009
Editor925
  • 285 Answers
SOURCE: Blade Alignment?
ok yep your blade is out of alignment with the fence. It is closer to the fence at the rear than the front. You need to make the modification or adjustment to your fence, if it allows that, and then worry about the miter slots later (which should be adjusted miter slot to blade, not miter slot to fence). You might be able to adjust the miter slot to blade by moving the actual table and then securing witht he table mount bolts. Check your manual for how to align the fence.
You do want to fix that though as it can be potentially dangerous and result in kickback of the workpiece which is a rather SCARY thing, and very dangerous.
Posted on Jun 03, 2009
I have a dw745 10" table saw. I'm having a problem with the rail lock. it won't fully lock down. has anyone else experienced this problem and if so how can I fix it
I bought this saw and had this issue at the start, but it sorted out itself. I don't know how, but it now fully locks down without any issue.
Jan 13, 2015 | Dewalt DW744S 10" Portable Table Saw with...
How to replace brush holders on dewalt table saw dw745
There is a small allen screw in the field housing holding the brush holders in.
Most often I have found, if the brush holders are needing replacement the motor housing also needs replacement - they heat up and the plastic cracks.
Dec 26, 2012 | Dewalt DW745 10" Compact Job Site Table...
How to change the blade.
UNPLUG tool, there are 2 wrenches usually on the side of table, remove the throat plate and place the spanner wrench on the flats of the spindle and the hex on the nut. WEAR gloves to help protect hands. The nut is standard threads. It also helps if you raise the blade. Let me know if you need more assistance.
Feb 10, 2012 | Dewalt DW745 10" Compact Job Site Table...
I have a Dewalt model 7730 radial arm saw. When the on button is pushed the motor starts off real slow as if it is under a bind or load but after a few seconds it picks up speed and seems to turn at full...
most probably it is bit of timber on the bottom of the saw assembly...
1. switch off the saw
2. remove power plug
3. remove screw and clear protector assembly
4. remove centre panel (as to changing the blade)
5. remove blade and clean dust furrow below it from all debris
6. re-assemble in reverse order
7. mount safety protector assembly
7, connect power cord
8. start in shor burst and switch immediatelly off, after blade stop spinning, check blade assembly if not wobbly.
this should solve your problem.
if you find this advice useful, please do not hesitate to leave comment and give me your vote4 fo rme, thanx!
Aug 02, 2010 | Dewalt DW744S 10" Portable Table Saw with...
My combination saw D27105 is making a bad noice when attempting to start and is not running up to normal speed. can anybody help here ?
Jul 31, 2010 | Dewalt DW745 10" Compact Job Site Table...
Hand crank binds
The bearings may be packed with sawdust. Clean it out, look for any place where there could be movement and squirt WD40 in those areas, while cranking. This may free it up.
Apr 04, 2010 | Dewalt DW745 10" Compact Job Site Table...
How can i get a guard for this table saw the dw 746
You can order them at www.dewaltservicenet.com.
The DW746 and DW744 use the same guard assembly, if you're talking about the hinged guard over the blade.
Mar 29, 2010 | Dewalt DW746 10" Woodworker's Table Saw
New Dewalt 745 saw, blade not parallel with Miter slot
Either take it back, or take it apart and make the holes bigger. For that kind of money, you should be able to adjust it dead-on. I thought I had the same problem on an old Craftsman, but I found that I just hadn't loosened things up enough. It's hard to see how much wiggle room you really have under the washers. And if there are aluminum castings involved, there can be a burr raised by the initial setting that it gets stuck on.
Dec 28, 2009 | Dewalt DW745 10" Compact Job Site Table...
Table saw Types
Portable table saws perform many of the functions of larger stationary table saws but have a decided advantage in their mobility. High mobility makes them the perfect choice for framing and deck building. They're also a good choice for small shops with limited space. Stationary saws added power enables the saw to run knives and cutters designed to mill and remove large amounts of stock and usually accept more accessories than portable saws.
Aug 27, 2008 | Dewalt DW745 10" Compact Job Site Table...
Dewalt DW745 10" Compact Job Site Table Saw Logo
284 people viewed this question
Top Dewalt Saws Experts
JOHN LAPIER
Craig Butler
Craig Butler
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
