Question about Lowrance GPS
I recently bought a LSS-1 w/transducer. I have a LCX15mt, Can I use this or do I need a different monitor, and if so, which one?
  • 3 Answers
I believe I'm correct in saying that the LSS-1 for side and down scanning will only work on the HD systems.
Posted on Aug 31, 2010
How to Make the Matrix Raining Codes by Using Only Notepad?
thats easy..
open notepad then copy and paste the following text
@echo off
color 0a
cls
:a
set /a a=%random%
if %a% geq 16384 set /a aa=1
if %a% lss 16384 set /a aa=0
set /a b=%random%
if %b% geq 16384 set /a bb=1
if %b% lss 16384 set /a bb=0
set /a c=%random%
if %c% geq 16384 set /a cc=1
if %c% lss 16384 set /a cc=0
set /a d=%random%
if %d% geq 16384 set /a dd=1
if %d% lss 16384 set /a dd=0
set /a e=%random%
if %e% geq 16384 set /a ee=1
if %e% lss 16384 set /a ee=0
set /a f=%random%
if %f% geq 16384 set /a ff=1
if %f% lss 16384 set /a ff=0
set /a g=%random%
if %g% geq 16384 set /a gg=1
if %g% lss 16384 set /a gg=0
set /a h=%random%
if %h% geq 16384 set /a hh=1
if %h% lss 16384 set /a hh=0
set /a i=%random%
if %i% geq 16384 set /a ii=1
if %i% lss 16384 set /a ii=0
set /a j=%random%
if %j% geq 16384 set /a jj=1
if %j% lss 16384 set /a jj=0
set /a k=%random%
if %k% geq 16384 set /a kk=1
if %k% lss 16384 set /a kk=0
set /a l=%random%
if %l% geq 16384 set /a ll=1
if %l% lss 16384 set /a ll=0
set /a m=%random%
if %m% geq 16384 set /a mm=1
if %m% lss 16384 set /a mm=0
set /a n=%random%
if %n% geq 16384 set /a nn=1
if %n% lss 16384 set /a nn=0
set /a o=%random%
if %o% geq 16384 set /a oo=1
if %o% lss 16384 set /a oo=0
set /a p=%random%
if %p% geq 16384 set /a pp=1
if %p% lss 16384 set /a pp=0
set /a q=%random%
if %q% geq 16384 set /a qq=1
if %q% lss 16384 set /a qq=0
set /a r=%random%
if %r% geq 16384 set /a rr=1
if %r% lss 16384 set /a rr=0
set /a s=%random%
if %s% geq 16384 set /a ss=1
if %s% lss 16384 set /a ss=0
set /a t=%random%
if %t% geq 16384 set /a tt=1
if %t% lss 16384 set /a tt=0
set /a u=%random%
if %u% geq 16384 set /a uu=1
if %u% lss 16384 set /a uu=0
set /a v=%random%
if %v% geq 16384 set /a vv=1
if %v% lss 16384 set /a vv=0
set /a w=%random%
if %w% geq 16384 set /a ww=1
if %w% lss 16384 set /a ww=0
set /a x=%random%
if %x% geq 16384 set /a xx=1
if %x% lss 16384 set /a xx=0
set /a y=%random%
if %y% geq 16384 set /a yy=1
if %y% lss 16384 set /a yy=0
set /a z=%random%
if %z% geq 16384 set /a zz=1
if %z% lss 16384 set /a zz=0
echo %aa% %bb% %cc% %dd% %ee% %ff% %gg% %hh% %ii% %jj% %kk% %ll% %mm% %nn% %oo% %pp% %qq% %rr% %ss% %tt% %uu% %vv% %ww% %xx% %yy% %zz%
goto a
Dont copy this line or anything below it.
once the text is pasted into notepad. click file then Save As...
where is says Save as type: click the drop down and select All Files
the save Type the File name: as Matrix.bat
or you could just google how to make a Matrix bat file.. LOL
Oct 20, 2016 | Microsoft Computers & Internet
Says no transducer connected and is in simulator mode. How do I get out of simulator mode?
the manual is here
http://www.humminbird.com/Category/Support/Product-Manuals/
I had this unit but gave it away recently. From memory, you just need to connect the transducer and make sure the transducer is in water. If not, it reverts to Demo Mode.
Aug 20, 2015 | Humminbird Piranhamax 170
Y cant i mount my structure scan transducer on the bottom of the boat
This is what the manual says:
The StructureScan transducer can be mounted on the transom,
jackplate, step or directly to your boat's hull.
When mounting it directly to the hull, you must purchase a high-
quality, marine grade above- or below-waterline sealant/adhesive
compound.
Jul 20, 2014 | Lowrance LSS-2 Structure Scan HD Black Box...
Lss repair how to fix noisy air pump on electronic leveling ?
when I bought my LSS I was told this was normal but now that we're in summer it hasn't made much noise. That said; if it's excessive it could be loose mounting of the air pump(rattle) or pump bearing(squealing).
Jun 02, 2014 | 1997 Oldsmobile LSS
1996 Oldsmobile LSS. Went to autozone and got code PO133. 'Fuel system running rich or lean- check other aacodes first.' and 'Oxygen sensor defective'; The guy said it probably isn't the oxygen sensor; as...
code P0133 is : o2 sensor circuit slow response (bank 1 sensor 1)
meaning;;;one heater on o2 sensor is not heating fast enough or no heat.
look for o2 sensor heater fuse first
and connector wiring for rust
if ok change o2 sensor
Oct 17, 2013 | 1996 Oldsmobile LSS
Grey Wavy Lines On My Monitor
First of all, try using a different monitor cable. If the problem is still present, make sure that your monitor's image is correctly adjusted. Most monitors provide an 'auto adjust' function. This page can help you find out whether your monitor's clock and phase are correctly adjusted:
http://www.lagom.nl/lcd-test/clock_phase.php
It also provides different test images that can help you with locating your problem.
Hope is helps, cheers.
Jun 21, 2013 | Computers & Internet
My temp is always fine but my depth will be working and then go to 1.2 ft and may start working again. sometimes i have to restart it to get it working, but it will still go to 1.2 ft at sometime
If you know someone that will let you try your unit on their hookup (same type unit) you may be able to isolate the problem to know if it is in the transducer or the unit. If you have the same results with a different hookup, then you would need to return your unit to our factory for a service check. If a different transducer corrects the problem, please contact me at the following email address and I can replace your transducer for you. sbates@johnsonoutdoors.com
Sharon Bates
Humminbird Consumer Service
678 Humminbird Lane
Eufaula, Al 36027
8-5pm Central Time Mon-Fri
1-334-687-6613 ext. 1202
Dec 24, 2010 | Humminbird 141c Fishfinder
I want to see the schematic diagram of humminbird fish finder transducer, my fishfinder won't operate. if i plug another unit of transducer, the my fishfinder operates normally.
Hi Greg and Ernesto:
Re-stating the obvious, your transducer is not working but you know that the sounder is.
I would start by checking to see if your transducer works on a different sounder. That's just a double check to confirm that it really is not working.
Then I'd try to isolate the problem:
- Plug (couold be corroded or damaged)
- wire (could be broken)
- Transducer (could be defective)
Since these are sealed units, I'd be checking with the supplier to try to find a replacement. Hopefully they are not too expensive, and time spent fishing is better than trying to maybe save a few dollars, especially if you're taking out charters.
Best of luck.
Sep 01, 2010 | Humminbird Fishfinder 525 406260 1
Can you still buy parts (transducer) for aHumminbird 100? I bought a great ued one but there is no transducer.
Yes you can contact the company directly at
Toll-free: 1-800-633-1468
Monday - Friday
8:00am - 4:30pm CST
Nov 17, 2009 | Humminbird GPS
How to program a 1997 olds LSS key fob
if you have 2 keys that are already program you can do it, but if not, the dealer will need to plug in the computer to program. sorry
Mar 25, 2009 | 1997 Oldsmobile LSS
GPS Logo
76 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
