Question about Amana AER5515QA Electric Kitchen Range
Kitchenaid range model # kdrp467ksso can't operate oven
KitchenAid Gas Range Model KGRT: Oven temp won't go past 260 degrees. When a higher temp is typed into keypad, it gives me an "err" mesage.
replace the oven safety sensor located in the upper left corner of the oven cavity,its merely a thermocouple and cycles the temp in the oven and is easily replaceable,its a whirlpool part # AP3083985 available from most appliance parts stores that handle whirlpool parts,as this unit is produced by whirlpool corp. for kitchenaid corp.
Mar 27, 2011 | KitchenAid KGRT607 Gas Kitchen Range
Kgst3078wh2 need oven manual for kitchenaid
The model number is actually KGST307BWH2.  Here you go:  http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209751683.pdf
Jan 08, 2010 | KitchenAid KGST307 Gas Kitchen Range
I have a Kitchen Aid range model KGST307GBS0. The
The door light switch was broken (upper right face of oven). The door switch is automatically activated when the door is opened to turn on the oven light. When the door is closed the switch is depressed to turn off the light. It seems the switch position is detected by the oven and if it is in the open position it will not allow the oven to function properly (reach temperature or allow the cleaning cycle to run). I temporarily locked the broken switch in the closed position, which allows the oven to function. A new switch was ordered for replacement.
Jan 02, 2010 | KitchenAid KGST307 Gas Kitchen Range
PUT THE OVEN ON SELF CLEAN AND IT DIED
the operating feature i that it will not let you open untill the oven has either fineshed cleaning or the oven has cooled off
Oct 29, 2009 | KitchenAid KESC307 Electric Kitchen Range
Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Sep 04, 2009 | KitchenAid KGRT607HBS Gas Kitchen Range
Model KEDT105V F-2 and F-3 flashing and beeping then turn the oven off? MOlson
Hi
The error code F-2 means that oven temp is too high; you need to :
1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor
Error F-3 means you need to open oven temperature sensor/thermal fuse and replace oven temperature sensor/thermal fuse.
Please revert for any further assistance and Do rate this solution as "FixYa" if found useful.
Thanks
Rylee
Mar 25, 2009 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid Electric Range Model KESC307HB56
Electronic control has probably failed.....Self clean on many ovens can be a self destruct mode. Door latch motors, sensor probes and even the electronic controls can be destroyed by this operation. Suggest oven cleaner method next time.
Jun 12, 2008 | KitchenAid KESC307 Electric Kitchen Range
Oven not working
F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean 2. Test relay contact operation 3. High resistance in oven temperature sensor
Sep 05, 2007 | KitchenAid KESC300 Electric Kitchen Range
Oven/Broiler Igniters for KitchenAid range KGST307
Guy, your missing some letters at the end of the model but I compared 4 different gas slide in's starting with KGST307 and the part numbers are bake ignitor 9751123 and broil 9751784. Catriver..post back
Apr 02, 2007 | KitchenAid KGST307 Gas Kitchen Range
Amana AER5515QA Electric Kitchen Range Logo
119 people viewed this question
Top Amana Kitchen Ranges Experts
Sal De
Ismael Rodriguez...
Oloyede Monsuru
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
