Question about HP Pavilion DV6449US Notebook
Just had a repair done under warranty and they replaced the motherboard. Now the laptop woorks in Safe Mode, but in normal mode I just get a black screen. Do I need a new graphics driver installed?
  • 808 Answers
Update ur bios and then use reginout it will dix ur problem
Posted on Aug 31, 2010
Nls error
Step 1:
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer also Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
Feb 21, 2013 | Acer Aspire One PC Notebook
I had to launch start up repair and the battery died half way through... The laptop now says "Computer build error. File exception failed to find c:/ (etc)" and it won't turn on, just...
Step 1:
Enable VGA mode
Reboot
Feb 07, 2013 | Computers & Internet
My Hp compaq PC showing problem about HDD - Disk Read Error . But This HDD was run very good to another PC ?
Test all leads that attach to your hard drive power and data cables IDE SATA the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty Make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty. Computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error. Even something as small as a faulty electrical or fan lead can cause you problems Motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail. b> 1: Download a disk read error repair tool,install this error repair tool.
2: Open disk read error repair tool and scan you computer for free
3: Then click the Repair All Button again and your done! It is very easy to repair disk read error.
Here are the url of disk read error repair tool:http://www.RepairErrorInstantly.com/ttfi... or rather than doing this try the alternative which is windows own repair Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Enable VGA mode
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice Select safe mode with networking to download http://www.RepairErrorInstantly.com/ttfi... Then restart again into safe mode with command prompt. Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer Hope this helps. b>
Jan 05, 2013 | HP Compaq dc7700 PC Desktop
My PC acer 5542G, win 7, laptop, after an upgrade programm on the ACER site for the driver sound (realtek), the screen become all black. But some fonction as light on the board and the cd-dvd driver are...
AFTER YOU ON THE SYSTEM BEFORE WINDOWS STARTS KEEP PRESSING THE F8 KEY CONTINUEOUSLY. A MENU WILL APPEAR. SELECT SAFE MODE AND ENTER. WINDOWS WILL LOAD IN SAFE MODE. THIS WILL SOLVE SOME OF YOUR PROBLEMS. NOW RESTART THE SYSTEM IN NORMAL MODE. IF THIS DOES NOT WORK SELECT "LOAD WINDOWS WITH LAST KNOWN GOOD CONFIGURATION " AND THEN RESTART. THIS WILL SURELY SORT OUT YOUR PROBLEM.
PLS REPLY OR COMMENT. THANKS
May 15, 2011 | Computers & Internet
Keep restarting every 5-10mins. was inf motherboard bad
Restarting loop in your computer can be caused various reasons.
1. Overheating of the processor.
2. Problem with your operating system
3. Motherboard failures
While restarting your computer you should be seeing the Sony logo and then the windows logo, post which you will go to your desktop background. If your computer is restarting immediately after the windows logo before loading windows desktop, then the problem can also be with the windows operating system. For this situation while your computer is restarting keep tapping the F8 key as soon as you see the sony logo, then choose safe mode and hit enter, This should load safe mode, in safe mode wait for some time and see if your computer is restarting. if not then the issue is with some recently made change or recently installed software or hardware. If it restarts even from safe then the issue is with the hardware of your computer
Mar 05, 2011 | Sony VAIO VGN-CS110E/Q Widescreen Notebook...
The dell inspiron 1318 shows the windows logo shortly after the screen goes black and I cant see the anything its like the screen is turning off
This sounds like a video driver problem. To find out reboot the laptop and press F8 to goto Safe Mode. If you can see the screen in Safe Mode then you have a video driver problem in normal boot. If you still have no video the you may have a bad motherboard and will need to take it to a repair shop
Apr 16, 2010 | Dell Inspiron 1318 Notebook
Dell Inspiron 1525 Laptop..the screen goes almost black after 5 minutes.
The screen goes black while in normal mode right? So try to boot in safe mode (power on then keep tapping F8 then select safe mode). Check if still happens in safe mode.
If screen does not goes black in safe mode it means there might be a software or driver causes problem when running in normal mode. You can try the following (update your anti virus software then run a full system scan, uninstall the video driver then download and install the latest one, uninstall any previous windows update or you can system restore to the time when it was working fine).
If the screen goes black even in safe mode they try connecting the laptop to an external monitor if still goes black, if yes then absolutely no issues with the LCD panel. You can try (uninstall and reinstall the video driver if still persist then this might end up replacing video card or motherboard, but before doing that update the BIOS first).
If does not goes black in ext monitor then the LCD panel might causes the problem. Reseat the LCD cable or inverter if you can.
Oct 22, 2009 | Dell Inspiron 1525 Laptop
Computer randomly shuts down in Safe Mode only
I can't think of any reason why you would want to run in safe mode except if the computer crashes your system. If you have a heat problem in safe mode it is shutting down to protect you CPU and GPU which are two things you won't want to replace. If you are over clocking you CPU that could cause this problem as the power management system is not active in Windows when you run safe mode. If your system is under warranty and you are concerned about this problem ask them to do a warranty repair. If it's not under warranty you can take it to Best buy and explain the problem and ask for a PC health check. Last I heard they were still doing those for free. At this point though I would avoid running the PC in Safe Mode
Sep 08, 2009 | Acer Aspire 7720 Notebook
Computer not booting -> Blue Screen
You can try running a repair on the operating system, but the hard drive could be damaged. If so, the repair will fail. Hopefully the hard drive is the only thing broken.
Jun 05, 2009 | Dell Latitude D600: Pentium M 1.6GHz,...
HP Pavilion DV6449US Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
