Question about LG WM1812C Front Load Washer
I am having a problem with an LG washing machine. The model number is: WM1812CW and the issue is with the "dispenser panel". Basically this is the assembly into which bleach, fabric softener and detergent are placed prior to starting the washing cycle. On my original part one of the tabs at the rear of the unit broke enabling the panel to easily slide out spilling the contents. I ordered what I thought was the correct replacement part thru sears parts direct but had a problem with the function of the new part. The new part has the correct model number imprinted (WM1812) and fits into the space of the original part. However it does not dispense bleach. When looking at the two parts side by side a difference is obvious. For images see the page on my web site: http://www.colemanwoodworking.com/LG_WM1812CW.html I've talked to sears parts direct and they want to ship me another part but they cannot guarantee that the part will fit or work any differently than the one that they've already sent. I'm wondering if there was a redesign of the dispenser panel during the run of this washing machine model and if so how can I make sure that I get the part that will work properly with my washer.
  • 2 more comments
  • NJed Aug 30, 2010
    Thank you for the quick reply. I'm a little confused about your statement
    "...I would say both the parts should work until the part shipped by Sears is not faulty..."
    I would think you are indicating that, in your opinion, the new part (even if it was a redesign) should work. The original part still functions, with the exception of being able to be pulled out completely. If I swap the two parts, with all other things being equal the original part dispenses bleach properly and the new part does not dispense bleach at all. If you could clear up your statement I quoted above I would appreciate it. Once again, I also am thankful for the quick reply.
  • NJed Sep 01, 2010
    Jahn:
    Thank you for the reply. I may have been a little unclear in my original post...the dispenser does not come out on its own, it stays in place fine during a wash. The only time it comes out is when the "drawer" is opened to add more detergent, bleach, softener. Originally the drawer would hit a "stop" and not come out all of the way, this is the part that is broken on the original part. Other than that it functions fine. However, I did check the machine for level anyway and it is dead on. I've also checked with filling the compartments with water as you suggested and that shows that the machine is level also. When I use the original part all fluids are dispensed properly, when I use the "new" part everything works with the exception of bleach. When I began to investigate the problem I found that the new part was a slightly different design. I have contacted LG directly and their answer was that, since I purchased the part from sears I would need to deal with them. When calling sears they offered to send me the same part again. I was hoping that someone with experience with LG washers would be familiar with whether or not this part has been redesigned part way through the product cycle and, if so, how I could specify the earlier part. Thank you for any reply you can offer.
  • NJed Sep 04, 2010
    Jahn:
    I performed the bench test as you described. The original part works as you described, when the fluid level reaches the dispenser port height then it begins to flow and continues (I assume thru a siphon action) until all the fulid is exhausted. The new part, when tested in the same way, does not do this. However, if you "loosen" the "cap" of the bleach dispenser section (refer to the exploded part diagram that I originally posted, see part number F226) and repeat the test the fluid flows as expected. The problem is, when the part is installed in the washer the "cap" cannot be positioned as in the bench test. It seems to me that this part is somehow restricting the siphon action. Thank you for your help. At least now I understand how the part is supposed to function and why the new part does not.
  • NJed Sep 04, 2010
    Yes, this expert's advice illustrated what the problem was with the part I received. His test proved to me that the part I have received is defective and needs to be replaced
    President:
  • 1,554 Answers
The new dispenser assembly should work as designed. The problem is not likely in the dispenser assembly itself but rather with the leveling of the machine. It sounds like the machine is slightly leaning forward as the original dispenser assembly with broken locking tab slides out easily spilling the contents. It should slide put easily when the machine is level.
Since the bleach dispenser port on the new assembly is positioned at the rear of the compartment, a slight leaning of the machine forward causes the water level at the rear of the compartment to be shallower and eventually do not dispense through the port.
Make sure the machine is level and not leaning forward and the ports both on the cap and dispenser fit together perfectly. Use a leveling tool to level the machine. You may perform a bench test by placing the two dispenser assemblies on a level surface then slowly pour water on the bleach compartments until they are full. Water should start dispensing through the ports when it reaches the level of the dispenser port.
Please accept the solution if you find it helpful. Failure to do so will automatically give credit to the first solution no matter it is. Accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Aug 31, 2010
  • Jahn27
    Jahn27 Sep 02, 2010
    "I've also checked with filling the compartments with water as you suggested and that shows that the machine is level also."
    "You
    reaches the level of the dispenser port."
    Performing a bench test is done not to determine the leveling of the machine but to determine whether the bleach compartment of the new dispenser drawer cannot really dispense. Redo the bench test on a level surface and make sure the compartment tubes fit properly and the end of the cap tube is not touching the cavity.
    Your problem is rare and this is the first time I knew someone who experienced it.
    Brigadier General:
  • 3,513 Answers
After veiwing the pics you have put up and the type of confusion you are facing its very difficult to comment on this. I would rather suggest that the best and the accurate way to do this is to talk to a support guy from Lg.
http://www.lg.com/us/appliances/washers/LG-WM2101HW.jsp
They can suggest the correct part number and whether they have reworked on the designing part. As far as me as a technician I would say both the parts should work until the part shipped by Sears is not faulty.
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Posted on Aug 30, 2010
My LG model WM1812CW washing machine is leaking water and says FE in the display
problem with the inlet valve or oppressor switch,because of the overfilling water, sawing FE ERROR
Jan 26, 2014 | LG Washing Machines
How do install the door hinge to a LG Washer Model WM1812CW? What is the size of the screws and do you need a nut to secure the hinge to the frame of the washer?
No nuts required, but the original screws are installed with lock tight, and are very difficult to remove. Taking the entire front panel off the machine and then heating the screw with a pencil thin torch generally helps. If I remember correctly, the screws are 10 mm.
Jun 11, 2010 | LG WM1814CW Front Load Washer
Leaking in the bottom during wash . Model lg wm1812cw
Handyman here-
Could be anything... First off I would check the gasket for splits, tears and breakage. As the clothes are washed, it could splash water out that normally would not get out.
Good Luck!
Apr 03, 2010 | LG WM1812C Front Load Washer
LG WM1812CW washer smell
Usually caused by doing all low temperature washes. Every 2-months do the hottest wash, with a good suirt of qualuity bleach. Also check the waste pipe of the wahing machine is high enough, so it does not **** dirty water back from the drain.
May 26, 2009 | LG WM1812C Front Load Washer
Fabric softener not draining
Remove the dispenser drawer by pushing down on the tab at the center back and pulling drawer out. Now, remove the top of the fabric softener compartment and the parts of the soap dispenser and clean them all out. An old toothbrush often helps. Reassemble and replace. They should siphon out now.
May 23, 2009 | LG WM1814CW Front Load Washer
Drum will not spin
I unplugged the machine for 1 hour and the computer reset, and it is working fine
Jan 04, 2009 | Washing Machines
First, clean out the filter behind the access door on the lower left front of the machine. Residue left in the filter can contribute to odor issues. Second, buy a package of AhFresh or Whilaway and run a cycle with that, hot water, longest cycle. (unfortunately you do not have the sanitary cycle or the tub clean cycle on your model) Third, and most importantly, USE LESS DETERGENT. Top load washers use up to 45 gallons of water per cycle. Your machine uses 12. Use one tablespoon of HE detergent and one teaspoon of fabric softener (if you use softener) per cycle. My personal LG washer is now over 5 years old, and have only had an odor issue one time. I leave the door closed after I wash. (the tub is vented) Never have had any mold or mildew issues with my washer. Was doing several loads per day when I had 7 at home, now only doing 3 loads a week with all the kids, their spouses, and grandkid gone. Still no odor problems. Great machines if used properly. Note: the odor / mold / mildew issues are basically the same with any front load machine, regardless of brand, and most can be solved following the above advise. Good luck.
Oct 22, 2008 | LG WM-2077C Front Load Washer
My LG Tromm washing machine WM1812CW keeps coming up with error 0E. how can I fix it.
what do the letters UE mean on my Tromm front load washing machine?? PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I P
Jun 01, 2008 | Washing Machines
LG WM1812C Front Load Washer Logo
148 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
