Question about HP PSC 1210 All-In-One InkJet Printer
How do I change the ink cartriges? - HP PSC 1210 All-In-One InkJet Printer
  • HP Master
  • 4,737 Answers
While the printer is On, open the Front access door, and wait for few seconds, the cartridges will come to the center with the carriage, now reach your hand, keep your thumb on the front of the cartridge and your point finger on the top and press down with the finger while the thumb pushes in slightly. It'll come out like you plug out something. After both the cartridges are removed, open the new cartridges box and remove the protect plastic coat from the cartridge pulling from the pink (usually pink, i am not sure if it's been changed..) towards the bottom and remove it completely. Hold the cartridge and install it in the reverse direction as you uninstall is. Color cartridge should be on the left and black should be installed on the right carriage.
Close the front access door and check if it's properly installed or not. If it's installed, a test print may come out or if it's not properly installed, the cartridge error light will blink and you'll not be able to do anything with the printer. In that case, you need to reinstall them.
If you have problem following my instructions, you can refer to the HP Tutorial on how to replace the cartridges.. (click here).
If you need further help, let me know so that I can assist you further.
Good luck.
Thanks for using FixYa.
Posted on Aug 30, 2010
Testimonial: "Thank you it worked just like you said it would. Tomzu"
Where is the ink cartrige located at
lift top of printer and underneath is the ink cartridge assembly.
Jan 17, 2015 | Canon Office Equipment & Supplies
Not detecting ink cartrige
blink means that the ink is near end not finished.See which ink is ended and change it
Apr 08, 2014 | Office Equipment & Supplies
My friend had a problem of his printer, cause the printer didnt recognize the ink... it has 6 colors epson ink. we dont know how to fix it... all the cartrige shows x
Is your friend use CISS. If so
Move Ink cartrige holder to cartrige change station.
Put off cartrige ( genuin or CISS) from carrage
Take a soft erager try to remove dry in or dust or waste everything smothly
reassemble the cartrige again
push top of the cartrige gentaly sothat it struck acurately.
Turn on printer.
I think you will get rid from your pprinter problem.
Thank you
Aug 21, 2011 | Office Equipment & Supplies
Epson C63 will not print despite having changed all the inks. It tries but the paper is blank
I think there are 2 causes epson c 63 printer not print problem.
First one is: Your ink cartrige are not install properly.
Solution: Try to install ink cartrige properly, in this time please clean ink cartrige chip as well as connector.
Secoundly: printer main board problem. Print data does not pass through main board.
Solution: Please replace new one.
I think you will relive from the problem.
Thank yoou.
Feb 28, 2011 | Epson Stylus C63 InkJet Printer
My Epson c88 was working fine. I changes ink cartridges and now the black will not print.
Your printer head may be closed.To remove the problem jast open ink cartrige from the cartrige chamber. set a seringe with full of black ink into the plustic pin which are tidely insert in the ink cartrige. After push 2/3 time your printer work fine again.
Thank You .
Shohagtush
Oct 20, 2010 | Epson Stylus C88 InkJet Photo Printer
Canon MP 610 printer. Cartridges half full when forced to replace
well printers calculate ink, with printing jobs. If you exchange cartriges in the middle of these ( ex:you exchange cartriges about after 100 print jobs and the cartriges is 500 top) the printer dont know excatly the ink level, so gives these error on calculation, not exact ink level. so you need to take out and place again to reset cartridge counter.
Jan 16, 2010 | Office Equipment & Supplies
Epson rx595 changed to cartriges everthing fine
Try cleaninig the ink before reinstalling it again,if problem pesist,clean the surface contact on the printer and put back the ink,if pops up again,replace the ink.
Jul 13, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Printer dont print without one of color ink
u should use all cartrige for printing with your printer
Apr 24, 2009 | Office Equipment & Supplies
HOW DO i CHANGE THE INK CARTRIGES
open the top or lid and wait for the ink to slide to the middle. if there is a clip then unclip it. install new ink.
also provide the make or model so we can send you to the manufactures website for a quick install guide.
Jan 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
No printing
If you brought new Lexmark cartridges please change it as it comes with one year warranty but before try to perform a self test, (i.e make a copy) if it works then try printing , if get the error then change the cart.........................
May 13, 2008 | Lexmark X4270 All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
148 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
