Question about Garden
While cutting the lawn a couple weeks ago myleft front wheel came off. I re-installed it with a cotter pin but now the mower makes real wide left turns and when I cut it the left wheel kind of sticks in a sharp turn ,then straightens out but wobbles. Can you help me.It is an 8 speed 17.5 hp 42inch cut troy bilt pony
    Brigadier General:
  • 3,911 Answers
You are going to have to take the wheel off and take it to a small engine/mower repair shop. They will sell you a new one the same size with a new bushing in it. Put it on, make sure you are using the correct holder, many of these are C-clips and not cotter pins but then there would not have been a cotter pin hole? You may well have mangled up the axle and will need a new part there which is most likely going to be much more expensive and harder to replace.
Posted on Aug 30, 2010
How do i remove rear rim from alko ride on lawn mower
I was unable to find your exact mower, however, most rear mower wheels come off as follows: remove the black rubber cap in the center of the wheel hub. A channel lock plier and one of those paint can lid removers generally works well for removing the flexible cap. You should then see a flat metal horse-shoe shaped retaining ring. One should ideally remove that with a pair of hog ring pliers. These pliers have two pins that fit into the holes on the retaining ring and pull them farther apart. However, if you do not have the right tool, you can usually pry a retraining ring off with a couple of flat blade screw drivers. Look to be sure there is no cotter pin that may need removed. To remove a cotter pin, use a pair of pliers and an ice pick or screwdriver. When you take off the wheel, there will be a piece of metal approximately one and half inches by 1/4 inch on the axle that slides into a little groove directly on the axle. Be careful not to lose it. When you put the wheel back on, you will need to slide that pin which I think is called a "key" back through the hub of the wheel. Good luck.
Jan 04, 2015 | Garden
How do I drop the lawn cutting attachment from under the tractor for inspection and lubrication?
It' pretty easy to do once the pins are removed. Make sure cutting deck is flat on the ground, on a piece of plywood. Once disconnected, raise mower deck height adjustment handle to highest position, and slide deck out from under tractor. If it's a wreck, try SearsParts online... I got a whole new deck for my LOYTH20F42T for about 125.00 delivered.
Oct 23, 2014 | Husqvarna Garden
Rear tire gets loose and stops moving
Push mower: remove wheel, clean and lube axle, replace wheel, secure with washer and cotter pin or lock nut.
If this is a riding mower not enough info given.
Oct 10, 2013 | Garden
Front wheels on manual mower lock when pushing for awhile.
1 Locate the height adjustment lever on the inside of the left rear wheel.
2 Kneel next to the mower and push the left height adjustment lever toward the center of the mower. This will unlock the lever from the locking pin on which the height is currently set.
Read more: How do I Adjust the Height on a Great States Reel Mower? ' eHow.com http://www.ehow.com/how_6834215_do-great-states-reel-mower_.html#ixzz21NOr1e8d
3Rotate the lever toward the front of the mower to lower the height of cut, or toward the rear of the mower to raise the height of cut.
4 Release the lever over the locking pin closest to the desired height of cut.
5 Repeat these steps with the adjustment lever on the right-side rear wheel. Be sure to set the right wheel lever to the same position as the left-side wheel's lever for an even cut.
Jul 22, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I need a cotter pin for my Lawn Boy 824E Tecumsah snowblower. Can't find the manual. How do I know what to replace with.......
You can get a cotter pin at any hardware, auto parts or big box store...just look in the hardware section.
Dec 12, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Hit fence and right front tire is towing out. how do you get the alignment right?
kevin plumag, you may have bent the tie rod. It's an easy fix: each end of the tie rod connects to the axle, keeping the wheels at the right distance. Each end of the tie rod has a small cotter pin. Remove the cotter pin (a washer will fall off), lift out the bent tie rod, and put a new one back in, reinstalling the washer and cotter pin on each end.If your tie rod is straight, something else is wrong (which is why I'm searching the boards!). You can order a tie rod from Sears; check your manual for the part number.
Aug 30, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
How to remove and replace rear wheel tire on my mtd self propelled lawn mower model #126-478n134 part #634-0020 tire sized 8 inches.
Part # 634-0020 is listed for the FRONT wheel. Your post asks about the rear wheel. I was unable to determine if the same part number fits the rear.
FRONT
1) Remove plastic hub cab with a screwdriver around the outer edge.
2) Loosen the shoulder bolt in the center of the wheel (My guess is that you will need a 3/4 inch socket).
3) Leave the bolt and all washers/bushings together and remove the entire wheel assembly as a unit (the bolt serves as the axle).
4) Note the component locations and install the new wheel exactly as the old came off. Do one side at a time to be sure the reassembly is in correct order.
Working from the bolt-head to the mount hole, the assembly should go as follows: Shoulder-Bolt, Wave-Washer, Wheel-Bushing, Wheel, Wheel Bushing, Bell-Cone Washer, Mounting-Hole.
REAR
2) Straighten and remove 1/8 inch cotter pin from center of axle and slide ratchet-spur off the axle while making note of the tooth direction.
3) Slide the remainder of the wheel assembly off the axle.
4) Remove the small shoulder bolt from the ratchet-pawl and note the direction. Remove the ratchet-pawl and ratchet-plate from the wheel. On the inside of the wheel is a "pem-nut" which may need to be held with pliers.
5) Reassemble Ratchet-Plate, Pawl, Pem-Nut, Spur and Cotter Pin in the reverse order.
As was mentioned before, doing one at a time will help keep the parts in the proper order.
Hope this helps!
Sep 30, 2009 | Mtd 22" Yard Machine Push Mower
Can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Aug 22, 2009 | Garden
Garden Logo
108 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
