Question about Maytag Atlantis MDE6400AY Electric Dryer
My daughter pulled the knob off the timer and every since then, the dryer won't shut off on it's own and will continue running non-stop.
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 12, 2010
Dryer intermittently not starting.
The rat chewed up the power line and caused it to short out. Kill the rat!
Jul 14, 2013 | Whirlpool Dryers
Mr Webster, have a Kenmore 500, mod 110.78522700, Whirlpool timer 3976577. Timer continues to run at all off positions. If moved by hand to off position, timer knob stays put but timer is still running,...
You can unplug one of the motor wires and tape it off, so it won't be powered. Then you can time the clothes yourself till you can get another timer.
Oct 05, 2012 | Dryers
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
Whirlpool Ultimate Care II gas dryer won't turn off.
Dryer Won't Stop Running
  • Ultimate Car II Dryers are fitted with a mechanical timer that sends an impulse to the control circuit board to stop running once the set amount of drying time has elapsed. This is because, should an electronic timer fail, this would necessitate the replacement of the entire circuit board. Confirm that the mechanical timer is indeed broken by opening the dryer's door. If the dryer stops, the circuit board is working fine and is not the problem. Simply slide off the protective faceplate of the dryer, unscrew the control board beneath, and flip it over. Connected to the back of the timer's knob should be a small round device with two wires running to the circuit board within the body of the dryer. Unscrew this device from the back of the knob and disconnect the wires. A replacement timer costs a few dollars and should screw into place without trouble. Reconnect the wires and put the dryer back together. It should work fine now.
  • If you need a new timer the best place ti get it is from Rough River Appliance Repair
  • Phone number is (270) 230-1818 his name is Charlie and he is the best!
Nov 16, 2011 | Dryers
I have a maytag dryer and when you start it the timer doesn't move - it will run for hours unless you stop it. now when you pull the knob to start it doesn't respond
Sounds like the problem is in your timer contacts, in which case you would have to replace your timer. A no heat scenario on auto dry could also cause a dryer to run continuously.
Hope this helps _MJ_
Jan 29, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Not heating/timer knob not turning . the dryer works but is not heating and i noticed that the knob is not turning therefore it does not shut off just keeps running.
HI. The timer device is responsible for initiating the heating cycle. If the dial plate is unable to advance, the heating circuit will not operate correctly, thus, preventing proper heating. Another indication of timer mechanism failure will be an un going cycle. You have stated that the unit Will continue to run, without stopping. This is caused by the defective timer device.
In most cases, the actual timer motor will Fail. This motor is , essentially, responsible for the forward motion of the dial plate.
I recommend to replace this damaged timer device, asap.
Jan 19, 2010 | Whirlpool Dryers
My dryer does not shut off! continues to heat
HI. This is a defective, or damaged timer control module. It must be replace asap. If this continues, it will damage the element. Replace the timer, if possible. Once replaced, the issue will be solved.
Oct 15, 2009 | Kenmore 62602 Electric Dryer
Kenmore electric dryer won't stop running / no heat! 110.62512101
Without anymore info. is sounds like the timer motor on the setting controller (the main knob) is bad. The entire timer/control part is usually pricey but if its made to where you can just change the timer motor that will be less. If possible check the timer motor with a meter for continuity to be sure. the parts supplier will usually help you with this, if they are worth a shit.
Dec 19, 2007 | Dryers
Maytag Atlantis MDE6400AY Electric Dryer Logo
57 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
