Question about Samsung SyncMaster 931B 19" LCD Monitor
LCD Monitor went Dark
After minimizing a game, my monitor went dark and the color looks weird. I have restarted my computer - I also did a system restore to the day before. I went into the display properties and i changed the contrast / brightness / gamma and got it to look decent on the desktop, but the game still looks so dark, and the games display settings have never been changed before. They did not change, but i did mess with them, and the game still looked like ****. I don't know what to do now.
  • Anonymous Jan 17, 2009
    I've had my Samsung Syncmaster 931b about 2 years. Recently it went dark with the computer idling and the screensaver running. Returning to the monitor, I saw clearly that the display was a lot more dark, too dark. I wonder if it might be the hard drive or the os, since I don't know why the monitor itself should suddenly change, unless it's dying . . . .
  • eser Apr 06, 2009
    The color on the monitor went dark. I have tried to manage the color through settings but it has not improved it much. I have attached it to other PCs to test if it is specific to the current graphics card, but it did not change the color. I have read two other postings which this same problem was observed but I have not seen a solution yet? Any suggestions?
    Scholar:
  • 45 Answers
Hi bear2243055
I suggest reinstalling your graphics device drivers and maybe the game as well.
Posted on May 08, 2008
Screen is too dark and unreadable fix it
The screen on what make and model device?
Jul 10, 2013 | Computers & Internet
My monitor went dark for no visible reason. I
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 21, 2010 | Dell E173FP 17" LCD Monitor
Monitor suddenly went dark. Switched it to another system but still dark. Power light on. V9s S1901D S/N T34F501728
Disconnected Data cable from the monitor to the back of the CPU. Do a self test on monitor if u get colors on the monitor it is working fine.
check for loose cables. Try to do factory reset on monitor using buttons on monitor.
Aug 17, 2009 | Scanport JTX V9S (Black) 19 in. Flat Panel...
Dell LCD Monitor Pictures, Dark Colors Course, Fuzzy, Pixelly
You might find a BACKLIGHT FLUORESCENT BULB on eBay.
Jul 04, 2009 | Dell E173FP 17" LCD Monitor
Wierd color issue
hello! it would be good if you will inform the company wherein you had puirchase that gadget right away. there might be some technical problem with it. companies always provide a warranty, you consult it to them right away..thanks! feel free to contact me for more inquiry.
Apr 10, 2009 | Acer X193W LCD Monitor
I have a blue line in my monitor
line driver element defective. no repair possible, to my knowledge. replace LCD or ignore line.
Mar 31, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Dark screen
reset your monitor settings with deafaults with menu.u see some buton on lcd or monitor.
Dec 29, 2008 | ViewSonic VG900 19" Flat Panel LCD Monitor
Monitor Barely readable and dark but display is correct
We have about 20 of these at work. Four of them went dark, to varying degrees, in the two years they were covered by warrantee, and were sent back to the factory for repairs. Since then, eleven more have gone dark. I finally got around to looking at them a few days ago. I have repaired five so far, and in every case it has been the same cause.
The capacitors on the inverter board are burning out. There are two 470uF, two 1500uF and a 1000uF that are not holding up.
Costs about 4 bucks for replacement parts at digikey; qtys and Part numbers are:
2 PN #493-1561-ND
1 PN #565-1664-ND
2 PN #P13124-ND
It takes about an hour, and minimal skill with a soldering iron to fix.
Jul 23, 2008 | ViewSonic VE710b 17" Flat Panel LCD...
Monitor dark only when display PC, normal TV
hi have you checked your PC output? check it with another screen (whichever) and see if the output signal is good if soo check the cable and connections to your LCD check your PC for software configuraitions: 1) TV output 2) good resoulotion 3) media borad is strong enough to handle this LCD if all is good then maybe the TV borad is sending a low voltage/current then the LCD can see good luck
May 01, 2006 | Samsung SyncMaster 1701MP (Silver) 17 in....
Samsung SyncMaster 931B 19" LCD Monitor Logo
191 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
