Question about HP Compaq Business Notebook NX9010
I cant open the laptop
Hi i have problems with the freaking power supply too, but i need to get to it first i took all of the screews off but i cant get the laptop open is there any where that i can see all what needs to be taken off so i can open it??
  • 21 Answers
You can download the maintenance manual from the following link
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&locale=en_US&docIndexId=179111&taskId=101&prodTypeId=321957&prodSeriesId=321850#2
Posted on May 11, 2008
Why burning 44608p40 power supply k2645
Check ground screew , also disconect and re conect conector .
Jan 17, 2015 | Power Computers & Internet
Power up problem
Did you try taking out and then putting back in the RAM?
Mar 25, 2008 | Computers & Internet
How to remove rocketfish rf-700wps2 fan ?
Remove screew and tilt back , watch for suply line .
Aug 18, 2014 | Rocketfish 700-Watt ATX CPU Power Supply...
Power button on my laptop does not always work
I actually solved my problem a couple months ago. I thought it was the power supply, and took it to the Best buy, where for free just plugged in a different power supply with no change to the computer. That left the internal connection, so I opened the case (which was quite easy to do) and the place where the power cord connects to the motherboard has a small silver housing. I just kinda wiggled mine around until the light of the power supply came on again, and put it all back together. No problems since.
Hopefully that might work for you.
Jul 13, 2011 | Computers & Internet
My laptop has a problem of not start once i switched on the on button
Hello Sir, Hi, if your laptop fails on power on, here are possible culprit.
  • definitely there is a power supply problem, these power supply modules are not really serviceable, you need to find a replacement, but if you cant find one, bring the power supply module to a reputable electronics service center, a TV tech. shop will do.
  • there is a possibility of battery problems, but you should see some LED lights on your laptop, to confirm battery is bad, have it replaced, or swap out a new battery,
  • there is a slim chance its the power switch, usually they don't response, if this is the case, replacement is needed, but this goes with the motherboard.
  • if everything else does not solve the problem, its the motherboard. if this is the case, there is not much more else to do, but replace the whole laptop, and but a new one, your dealer may help to contact the supplier if buy any chance may repair the laptop.
Jul 27, 2010 | Computers & Internet
Samsung T220HD unreliable power-on and freak volume turn-down
Good news. These monitors come with 3yr warranty. Contact Samsung.. I just did.
Jan 12, 2010 | Samsung T220HD LCD Monitor
How do i replace my keypad on my acer aspire 5920 laptop
hi
you have to remove the panel which is found above the keyboard. the two small speaker is found just under that. there is no screw, take something falt, like a screwdriver, pull and it will come out. you have to open the screen 180 degrees.
once that panel is removed you will see 3 screw which hold the keyboard, remove all screws, lift the keyboard slowly, u have to remove the data cable connected to the keyboard, which is found just under the keyboard
hope this will help you
Oct 24, 2009 | Acer Aspire 5920-6727 Notebook
Toshiba Tecra S1 'Display freaks out' Iserni hello, your help with my display problems for a toshiba tecra s1 was helpyul with one exception... What/whenre is the 'Berg Strip' I took the thing apart...
if it is a single wire ,pls check it and connect to wireless card , id it has cover ,don't need to connect. also it has multi wire connector pls connect to display connect on the mother board.
Mar 07, 2017 | Toshiba Tecra S1 Laptop Notebook
Not working
Remove bottom plate by unscreewing the 7 screews (for one of them you must open the viewfinder) and make sure the ribbon cables are connected securely . You just need to push genty the ribbon cabbles and reposition the plate, this should solve the problem.
Mar 12, 2008 | Panasonic NV-DS65 Mini DV Digital...
HP Compaq Business Notebook NX9010 Logo
46 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
