Question about Protron PLTV-4250 42 in. LCD Television
When i go to miscellious mode it turns the tv off picture is red trying to auto set the settings
  • 4,889 Answers
Does it work in stable manner in other modes?
Posted on Aug 31, 2010
Update tv
Go to settings on the TV menu. It should be under picture and you can change the picture mode and auto dimming setting from ON to OFF...if you want to do an update.. then go to Sonys website .. key in your model number ..look for firmware updates then download this file onto a formatted USB flash drive.. remove and insert into TV and when turned on the set should pick up the update automactiaclly
Jan 09, 2014 | Sony BRAVIA KDL-32S5100 32 in. LCD HDTV
How do i turn the flash off
Welcome to FixYa.
The FORCED OFF mode is the setting where flash is not activated in any recording condition. this mode used when taking pictures in places where the use of the flash is not permitted.
There are other 5 different mode/setting in using photo flash.
1. AUTO - flash automatically activated according to the recording condition.
2. AUTO/Red-eye reduction - flash is automatically activated according to the recording condition. It reduces the red-eye phenomenon by triggering the flash before actually recording the picture. After that, the flash is activated for actual recording again.
3. FORCED ON - use the when your subject is back-lit or under fluorescent light.
4. FORCED ON/Red-eye reduction - use this when you set the camera to PARTY MODE
5. Slow sync./Red-eye reduction - use this when you take pictures of people in front of a dark background.
I hope this solution will help you. Just send us you comments or suggestion if this solution was helpful.
Thank you for using FixYa.
Apr 08, 2011 | Panasonic Lumix DMC-FX8 Digital Camera
I have no picture.
Just a thought from out of date tv user. Make sure there is power at outlet. If you have cable or antenna connected, make sure it is set to the right mode. One mode is all the tv channels, another is simply a second imput like vcr, and may have a third mode for games etc. On mine, each mode is specific to a set of terminals (yell/red/wht) on the tv back side (3 sets of terminals back there with each used with one mode), if in the wrong mode won't connect with input signal. Switch tv on then find the mode switch and try each one to see if you can get a picture or even snow. May also have some auto feature that if signal isn't detected, it won't startup the big screen (so you don't get blast of loud sound and snowy picture), try a spare tv on the input signal to see if the input signal is there and working. Hope that helps.
Jan 13, 2011 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
My EOS 400D takes blue hued pics
You may have the white balance set incorrectly. If so, set it to "auto white balance".
Sep 25, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
When I turn on my camera and its in shooting mode
In your menu settings, there should be a setting for auto-focus or focus notifications.
All cameras have this setting, but you can google it and find one for free download.
Mar 09, 2009 | Nikon COOLPIX S5 Digital Camera
Nikon S210 flash not working
The flash has been working fine until last night when I tried to take a picture and the flash was set to auto. When I press the button the little red light beside the flash sign lights up, but the camera does not take the photo. When I set it to flash mode, it still won't take a photo. When I turn off the flash, then it does. What could be the problem? Is it in the settings?
Dec 12, 2008 | Nikon Coolpix S210 Digital Camera
Pictures are red during the day.
U might need to change the mode in which u are taking the pics. Try setting it to Auto mode.
Mar 18, 2008 | Samsung Digimax D53 Digital Camera
Wont take photos outside
The symptoms you're describing could be caused by either the "Fireworks" special scene selection mode, or manual mode with too much exposure compensation. Look at your mode selector (back of the camera, upper left hand corner). Is the mode set to the still image setting (pointing at the liittle red camera)? Or is it set to special scene selection (SCN)?
If you are unintentionally in SCN mode, to get it out of "Fireworks", just turn the mode selector dial to select "still image" (pointing at the little red camera). Or you can also select an SCN mode more appropriate for outdoors. Just turn the dial to SCN, press the FUNC button, then press the left/right arrow buttons to select Portrait, Beach, Snow etc...
But if your mode selector is already in still image selection, then check to make sure that you're not in "Manual" picture mode. Turn the mode selector dial to "still picture mode" (pointing at the little red camera), then press the "FUNC" button. Now look at the bottom of the screen. If it says "Manual", press the "left" button controller once to select and put the camera in "Auto" still picture mode.
Feb 29, 2008 | Canon PowerShot A400 Digital Camera
Canon 20D strong blue cast to pictures
You probably have the White Balance set to a setting other a
than "Auto White Balance" (AWB). On the top of the camera, above the exterior LCD panel, there is the "AF-WB" button. Turn the camera on--past "on" to the bent line. Press the AF-WB button once. On the left side of the exterior LCD panel there is a vertical, reticular box with the symbol of the selected setting for WB. Normally, the setting should be set to AWB. If it is not, turn the command dial at the back of the camera until "AWB" is showing. Try shooting again-the color should be better.
In the "auto" modes (green box, portrait, landscape, etc) the AWB is automatically set. In the "advanced" modes (P,Tv, etc) the WB is manually set for whatever light source you are using. The command dial may have been accidently turned to different setting. Hope this helps.
Jan 23, 2008 | Canon EOS-20D Body only Digital Camera
JVC convergencehas to be adjusted everytime the TV is turned on
You will need to enter servicer mode to do the alignment then
save changes.....info is in service manual........
Does your set have an auto-focus selection ? Try that first...T.
Dec 26, 2007 | JVC AV-48WP30 48" Rear Projection...
Protron PLTV-4250 42 in. LCD Television Logo
19 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
