Hotpoint Aquarius WF740 is my draw for the fabric conditioner meant to drain after cycle. mine stays full of water.
zeusfaber
  • 247 Answers
SOURCE: Fabric conditioner still in draw after wash cycle
This is usually a matter of pulling the drawer right out (it is designed to let you do this) and taking it to bits (it's designed for this too). Most front-loaders have a bit of a design weakness in that the bit that gets blocked with conditioner isn't immediately obvious without a little bit of prior dismantling. Once you get the top off the drawer, you'll almost certainly find the siphon tube gummed up with old conditioner. Clean this up under a hot tap, then reassemble and all should be well. A.
Posted on Apr 25, 2007
  • 641 Answers
SOURCE: Fabric Dispenser
The detergent dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distributed to drawer's cells (following the programmed cycle) by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next test !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Posted on Sep 04, 2007
SOURCE: hotpoint Aquarius WF740
Hello again update on error f05 was a sock blockage in the black rubber tubing that connects from bottom of drum to the pump it was a easy fix just plastic clips holding it on make sure you turn off electric first lol !!!! all working fine now.
thanks daddonk
Posted on Jan 20, 2008
  • 1314 Answers
SOURCE: Fabric conditioner drawer full of water!
actully its considered normal the washer flushes the detergent,soap,and bleach with water when it overflowes it goes in the washer some water remaining is normal its in the owners manuel
Posted on Jan 25, 2008
  • 108 Answers
SOURCE: hotpoint aquarius wf740
Sounds like water pressure could be low or inlet pipe is kinked.
F04: possible filling or water level problem. Check water inlet pipe (or shut-off valve), or the outlet pipe, or the pump or pump filter if accessible (check for blockages or foreign objects). Also could be the water valve solenoid weak, causing filling to be too slow.
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Don't forget to rate!
Posted on Feb 28, 2008
Fabric softner not draining away on my hotpoint aquarius
take out your soap draw and in side there on the top you will see all black gunk that need cleaning i use a toilet brush with hot water ok
Oct 19, 2012 | Hotpoint Aquarius WMA42 Front Load Washer
Not emptying conditioner compartment conditioner
This video will show you how to keep your soap draw clear and how to service the parts
a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 20, 2011 | Hotpoint Aquarius WD63 Front Load...
When a cycle is complete in my Hotpoint Aquarius washing machine, the conditioner drawer is full of water. Do I need an engineer?
When a cycle is complete in my Hotpoint Aquarius washing machine, the conditioner drawer is full of water This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
And don't forget to like us on facebook
Jan 11, 2011 | Hotpoint Washing Machines
MY PROBLEM IS THE FABRIC CONDITIONER IS NOT BEING WASHED AWAY THE WATER GOES INTO THE COMPARTMENT BUT WHEN THE CYCLE IS FINISHED THE CONDITIONER AND WATER IS STILL IN THE TRAY?
a 4 THUMBS rating is appreciated for answering your FREE question..
Jul 30, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
The fabric softner release has stopped working
Most likely the fabric soft dispenser is clogged . this happens when you wash alot in cold water the left over fabric softner get very pasty and can clog it up. You can try filling the dispenser with hot water and run a cycle with hot water this should unclog the dispenser .
Nov 26, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WF740 My washing is coming out with dirty marks and bits of slimy dirt. I wonder if it is from the door seal as this is dirty or could it be something else? I used the persil gel filled...
Your pipe to the water pump exit is probably blocked with bits of old fluff or missing sock, i found that the clothes had slimy bits on mine, i tilted it up and removed the rubber water exit pipe from under neath, cleaned out all the rubbish and works a treat now.
Oct 19, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Fabric conditioner stays in the dispenser tray
the holes above the fabric softener tray that shower into it may be blocked. use an upturned washing up brush to scrub them with a little fairy liquid and see if that works, it does for me. also could be a water pressure issue.
Jan 23, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF000 Washer
make sure you have both water valves working and check your water pressure is good too hope this helps
May 06, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Jan 24, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
