Question about Dell Inspiron XPS M140 Notebook
The volume control wont work and i went to the control panel and went to volume and sound and it said there was no audio device attached i'd love to figure out whats wrong with it
  • 808 Answers
Syptoms u have identifies are most probably linked to registry errors on ur computer it is wise to run a registry repair scan with reginout registry cleaner....
Posted on Aug 31, 2010
Wont play sound on my gateway model 6332
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer:
hope this helps you:
Sep 20, 2011 | Boston Acoustics BA7500 Computer Speakers
Speakers wont work
also
hope this helps you
if you dont have a motherboard disc you will have to download the drivers
Aug 24, 2011 | Bose Companion III Computer Speakers
My speakers wont work
also
if you need more help with this post a reply
hope this helps
Aug 17, 2011 | Logitech S120 2 Speakers
Everything is pluged in correctly. And when i go to the control panel> Sounds, speech, and audio devices> sounds and audio devices> volume, it says that their pluged in and work, but i dont here...
also
hope this helps you
Aug 16, 2011 | Dell A215 Computer Speakers
No sound
also
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 02, 2011 | Compaq Audio Players & Recorders
I had my harddrive reformatted on my desk top pc and now my altec lansing avs200 speakers wont work on my computer
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume adjustment you will need to right click on the volume icon depending on your operating system select adjust volume
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps you
Jul 25, 2011 | Altec Lansing Multimedia Computer Speakers
I moved my husbands computer and now his speakers wont work hes really mad and i would love to know how to fix them
also
Jul 14, 2011 | Logitech X-530 Computer Speakers
My speakers don't seem to be working. Yes I checked for mute. Yes I went to control panel...I don't know what's wrong..it works on another computer..
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 01, 2011 | Insignia 2.0 Speaker System (2-Piece)
I had reformat my PC .. because it wasn't working out .. i was not able to save all the drivers .. as in ALL .. when i finished reformatting my PC .. I discovered that it had no sounds at all .. My PC is...
also
hope this helps
Apr 13, 2011 | Computers & Internet
I have the Pulse 424 speakers and they are like 8 years old. The speaker with the power and volume knob is out. It works to turn on speakers and control volume but no sound. The woofer and the other...
if you are having problems with your sound
also
hope this helps
Mar 31, 2011 | Labtec Pulse 424 Computer Speakers
Dell Inspiron XPS M140 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
