Question about Nokia 6126 Cellular Phone
Screen Saver When I close my phone, sometimes it takes forever for the screensaver to go off even though I've got it set to go off quickly. It seems to run my battery down when it does this. Any suggestions? Thanks in advance. Julie
    Problem Solver:
  • 7 Answers
Well, i had the same phone and i found it best to just turn the screen saver off. then it doesn't pop up at all and the battery shouldn't get run down as fast.
Posted on Jul 15, 2008
How do you get Windows 10 free update from Windows 8 to operate the screen saver?
How to customize Screensaver in Windows 10
RECOMMENDED: Click here to fix Windows errors and optimize system performance
There were times when computer monitors used to suffer from image burn-in issues caused by showing the same image for a long period of time and people used to install a screen saver to avoid the issue. The computer screens today no longer face the burn-in issues, but people still use the screen saver on their computer systems for fun's sake. Windows 10 comes with a six built-in screensavers. Let us see how you can customize screensavers in Windows 10.
Read: Are Screensavers necessary and still needed.
Screensaver Settings in Windows 10 You can get to your screen saver settings directly by typing 'Screen Saver' in the taskbar search box in the lower left corner of your system. Click on 'Change Screen Saver' and it will take you the Screen Saver settings right away where you can adjust the settings according to your own preferences.
Alternatively, right-click on your Windows 10 desktop, and select Personalize to open Personalization settings. Next click on Lock screen in the left pane.
Scroll down the Lock Screen settings and click on Screen Saver Settings. The following window will open. Here you can adjust the settings according to your preferences.
By default, Windows 10 offers the following six screensavers - 3D Text, Blank, Bubbles, Mystify, Photos and Ribbons - nothing new here. Select the screensaver from the drop-down menu and change its defaults Settings, if any are available.
For instance, the 3D Text screensaver lets you customize the text as well as a few other options.
The Photos screensaver lets you display your favorite photos as a screen saver.
Once you are done, click on save and exit.
Create Screen Saver Settings Shortcut
If you access the screensaver settings frequently, you can create its desktop shortcut as follows: However, it is easy to change the settings but if you change your screen saver often, it would be better to create a Screen Saver Settings shortcut on your desktop.
To create the shortcut, you have to right-click on your desktop and click on New > Shortcut.
Type control desk.cpl,,@screensaver in the location space in the wizard.
Click Next and give a name to your shortcut. Click Next and you are done. Give it a suitable icon of your choice.
Use this shortcut to change or adjust your screen saver settings whenever you want, quickly.
You can also create a shortcut to launch or change Screensaver state for a specific screensaver.
Nov 29, 2015 | Microsoft CompuRegister POS-1000 POS...
Disable screensaver LG PB66** series plasma
This should not happen, you can go into settings and alter the screen saver time out delay or disable it, select "none" in screen saver type.
Sep 28, 2014 | Televison & Video
How to set screensaver?
hi
first of all u need to right click on empty space on desktop and then select properties,once u have done that u will get a screen named display property ,,,,,,on the top u will find the tab screen saver.....click on to that and then select the desire screensaver and click apply and close ..........
Aug 31, 2009 | Computers & Internet
Screensaver 4 n72
go to galleries ,select graphics & then screen saver .from here u will get screen saver provided by & if u want ur file as screen saver ,go to that picture open it , open options->use image->set as screen saver
Aug 05, 2009 | Nokia N72 Cellular Phone
Screensaver not working
just go in setting there will b optin of screen saver click it then you should click on the screen saver it will b on..
May 23, 2009 | Nokia N95 Cellular Phone
Getting frequent black screens on 1501 Inspiron Laptop
Black screen is probably a screen saver or the screen is turned off by power management software.
Check your screensaver setting. Change the screensaver to None to disable screensaver.
I assume you are using Windows XP.
If the LCD is turned off by power management, on the same screen with screen saver, on the lower part of the box there is a Power button. Click to open Power Options Properties. Set your monitor power properties there.
When the screen go blank and you have to push power button, probably the computer is set to go to stand by mode after some idle minutes. You can also set it here in system standby setting.
Regards,
Dapid Candra
Dec 08, 2008 | Dell InspironTM 1501 Notebook
Screensaver won't work
Hi...there,
Well, It's seems you guys are new at this... In order to work you need to setting it. Closed all programs and right click go to properties. Then click on Screen Saver and chose the disired screen saver you wanted and set the minutes you like and click Apply... And that it!
Nov 30, 2008 | Hannspree HW191D LCD Monitor
Screensaver will not activate...
I would remove the software for your keyboard. This will hand control of the screen saver back over to windows. Some keyboards come with third party software that conflicts with windows. If you want a functional set of "extra stuff" on your keyboard, then your best bet is to try one from another manufacturer.
Jun 16, 2007 | Logitech Cordless Laser Desktop MX 3000...
Nokia 6126 Cellular Phone Logo
47 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
