Question about Whirlpool ED2FHEXN Side by Side Refrigerator
My side by side refri w/ice and water in door makes ice but cant ice from tray to door
Mine just started doing the same. I purchased this one on Nov 08, 2008. If I take all the ice out of the tray I can see the auger turn and if I put back just a few cubes the system delivers ice thru the door. But, put too many cubes in and the auger won't turn. Piece of junk - out of warranty and and now I pay more to get the buggar fixed. I need to try another company next time.
Posted on Sep 10, 2010
Water Shute freezing up in ice maker
freezer maybe turnedup to high ck manufacturing recommendations
Feb 06, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Tenant called. Ice machine not working on a side-by-side Samsung (RS2555SL). The tenant removed the tray and there is a white silicone rubber piece, apprx 1.5 X.25 X.25, dangling from two wires. Any...
I'm not sure what the rubber piece is but there are a few reasons that the Ice make will not function. I will list them for you.
  • Water is not on.
  • Door is not shut, or door switch is not being pushed in all the way when door is shut.
  • Faulty door switch.
  • Ice tray not in all the way.
  • Ice maker function not turned on.
  • Water reservoir in fridge is frozen. Set a warmer cooling setting.
  • Water line is frozen. Set a warmer temp, or let it defrost.
  • Solenoid is not opening to fill ice tray.
Make sure that the tray is all the way in, and seated correctly. If the tray is out of alignment it will not make ice. Make sure the water is on. Check the freezer setting. If your tenant has it on really cold, they may have a frozen water hose, or water reservoir.
Find the door switch. Press it in to make sure it is functioning. You will know it is if the light turns off when your press it. The fridge is designed to turn off water functions if door is open. If the switch is failing, the fridge thinks the door is always open.
This rubber piece may be some sort of protective cover or a grip to something. It may have fallen off something, and is in the way of the tray seating correctly. If you can remove it with out damaging anything, take it out, and see if the ice make will function after you put the tray back in.
Oct 25, 2010 | Samsung RS2578BB Side by Side Refrigerator
Ice maker doesn't make ice anymore. The water works and dispenser levers on the door work for both ice (use store bought ice dumped into tray) and water. I replaced the filter after it quit making ice. Not...
you've already done the first thing i suggest, and that is to change the water filter. But if you still cant get ice made, you have a problem with either your ice maker or your water valve, or an electrical issue in the ice maker system.
Apr 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I just installed a new ice maker and the tray doesn't fill with water, but the ejecter cycles. Water dispenses at the door.
i dont think its getting cold,, if the ice tray is full of water but not making ice try turning up the thermostat ,,,but if no water it reaching the ice tray then its a fult in that part
Nov 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice freezes into one solid block and won't dump out of the tray
remove cube tray from ice maker. clean with limeaway adn rinse. Spray with a light coating of PAM cooking spray. wipe dry and reinstall. be careful not to damage the sensor ( in center of tray)
Aug 26, 2009 | Samsung RS2578BB Side by Side Refrigerator
Ice stuck in ice cube tray
get a hairdryer to melt the cubes unless hot water can get poured in to mold to do the same
Aug 22, 2009 | Whirlpool Refrigerators
KITCHENAID MODEL KSRJ25CNST-00 FRIDGE QUIT MAKING ICE WITH OUT ANY WARNING. WTER IS WORKING.
I have this model and it has stopped making ice for two different reasons. These solutions may not fix your particular problem, but they worked for me.
Problem #1: the water inlet to the ice tray is frozen shut.
Solution #1: Raise the door that hides the ice tray. The water inlet is the black rubber nozzle on the right-hand side that points down into the ice maker. Squeeze the rubber nozzle between your fingers to break up any ice that may have formed inside the nozzle. This will clear the water path into the ice maker. Lower the ice tray door.
Problem #2: an ice cube is stuck in the ice tray.
Solution #2: Raise the door that hides the ice tray. Look for any pieces of ice that were not completely ejected from the ice tray - they are usually partially ejected and are very easy to see. Carefully (but it may require a good deal of force) remove ice cube from tray. Lower the ice tray door.
I hope this helps.
Aug 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice maker not working
check to see if your on/ off switch is green on the im 1st. 2nd make sure that you have properly seeded the dispenser tray by using the cross method. the auger arm at the back of the tray turn vertical and the auger mtr gear in the rf turn horizonal then insert the tray in the machine
May 31, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
63 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
