Question about Dometic Rooftop RV Air Conditioner
Compressor runs for only a moment the circuit breaker trips
  • Dometic Master
  • 6,674 Answers
Lights dim, moaning from AC, just before it trips breaker? Have you checked incoming voltage? What type of plug are you hooked up to, 30, or 50 amp?
Posted on Aug 31, 2010
  • slynch261 Aug 03, 2011
    30 amp and yes lights dim
  • Mike Butler
    Mike Butler Aug 04, 2011
    I'd be looking at replacing the compressor start capacitor. The capacitor supplies a high voltage "Kick start" to get compressor going. If you give me your model number off bottom of upper (roof) unit, I can get you a part number. Be Real Careful with capacitors, they can give a real dangerous, if not fatal shock of 300-400 volts, even when power is turned off !! If not experienced in that area, get back to me for instructions, or ask someone who is experienced to perform the job. New Capacitors run,$20-$40. and take about 20-30 min to change.
What is causing breaker to trip? Compressor runs fine until tank pressure is built up but it trips the breaker at high pressure shut off.
Never try to fool a security breaker. You could damage the compressor, if something is wrong. It could over heat and burn out. Try to fine what is wrong or if you don't mind to buy a new one, kill it with a 30 Amp circuit breaker.
Jan 16, 2015 | Cars & Trucks
What causes caravan aircon to trip circuit breaker on start up
My first guess would be that the compressor has seized. If not the compressor seizing, then I would look for a short to ground in the wiring. If you pull the cover of the AC you will most likely find that the compressor motor is plugged into a receptacle. If you can unplug or otherwise disconnect the compressor motor from its' power source and activate the thermostat to run and the circuit breaker does not trip, it is the compressor motor. If the circuit breaker trips, then it's in the wiring.
Aug 30, 2014 | Dometic Rooftop RV Air Conditioner
Circuit breaker trips after water supply cycle
check the condensor fan in the compressor area and make sure its running if not the compressor will overheat causing high head pressures on the compressor causing it to draw too much current to operate the compressor and kick the breaker out,also make sure the condenser coils there are clean and it has ample air movement away from the wall
Apr 21, 2013 | Kitchen Appliances - Others
Compressor trips breaker on startup or quickly after
The breaker may be too small. Check the amperage requirements against the breaker size.
May 31, 2012 | Craftsman 33 Gallon Vertical Portable Air...
My Campbell Hausfeld 30 gal 6.5 hp oilless compressor, WL611201 trips the breaker when I switch it on auto. But will not trip the breaker if I use the breaker as an on off swithch. However, it somtimes...
not likely as your pressure switch is pneumatic, What else operates on that same breaker, perhaps replace the breaker as they sometimes get "tired"
hope this helps
Let me know
Dec 18, 2010 | Campbell Hausfeld Air Tools & Compressors
Trips circuit breaker
If the unit is new then the unit may be over-sized for the electrical circuit. If the unit is not new then the compressor may be failing
Apr 19, 2010 | Amana PTH153B35AJ Air Conditioner
My heil heat pump has been tripping circuit breakers. It might run 8 hours to two days before it trips. I replaced the breaker. They put a hard start on the compressor. Now they say the next step is the...
Have you noticed what the outdoor temperature is when this unit is tripping the breaker? Does it seem to be at a higher outdoor temperature or at all outdoor temperatures day and night?
Did they check the run capacitor to see if it's good and the proper microfarads?
Did they check to see if the breaker trips when it's starting up or after it has been running awhile.
If it's tripping on start up then it's possible the next step is the compressor replacement.
If it's tripping after running awhile then it could be dirty indoor coil or filters,blower not running at full speed,low voltage, loose wire connection, points burnt on contactor and even a weak run capacitor.
Dec 30, 2009 | Heating & Cooling
My craftsman conpressor is a 5 gal type oil free. problem is when I plugged it in to operate it the moment I turn on the switch, it would run a few seconds and tripped my circuit breaker in the house for...
First, the simple answer - check the AMP draw on the compressor. It should be on the motor or compressor nameplate/tag. Even a small compressor can use alot of power, and blow the breaker if there are other things on a circuit.
Does it seem to run OK for as long as it runs?
Oct 26, 2009 | Craftsman Air Tools & Compressors
Air conditioner will trip breaker when trying to cycle back on
The compressor motor , once warm is grounding out due to wear and is going bad.Have the compressor replace while it is still clean is cheeper and easier that doing it after a burn out,which  will eventually happen,if the compressor is tripping the brreaker as I suspect..
Apr 22, 2009 | Dometic Rooftop RV Air Conditioner
Ruud heat pump outside unit trips circuit breaker
Check your wiring between the contactor and compressor for a short to ground, or check the compressor windings for short to ground.
With the Tstat off, the contactor should be open so the only way for the compressor to be trying to do anything is if the 110 volts from the unbroken side are traveling through the compressor to ground. Since 110v is not enough to run it, the overload is kicking it out, cooling off, and repeating the cycle. When you kick on the Tstat, the contactor is supplying voltage directly to ground without going through the resistence of the compressor windings and kicking the breaker.
Post back and let me know what you find.
Nov 20, 2007 | Ruud Central System Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
163 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
