Question about KitchenAid K5SS Heavy Duty Commercial Stand Mixer
It run on high speed only - KitchenAid K5SS Heavy Duty Commercial Stand Mixer
  • 185 Answers
Replace the phase board (small circuit board with wires).
Posted on Aug 30, 2010
Sunbeam mixmaster 12
There's a governor assembly inside that is bot working any more.
Sep 15, 2016 | Sunbeam 1957 Mixmaster Model 12 Kitchen...
How come my Hobart d340 mixer is only running on high speed
Because either the low speed windings or low speed control is kaput.
Mar 03, 2016 | Hobart Food Mixers
What is the rpm of artisan 300watts
On low speed roughly 1 rotation of the planetary per second. On high speed it should be the maximum speed that motor can run at, too fast to count that's for sure.
Oct 05, 2015 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid Hobart K45SS when set at 1-2 accelerates to high speed when making dough. How can I fix this?
Usually when the mixer runs only on high speed it is caused by the control plate adjusted incorrectly or the control plate spring unhooked. Remove the trim & end cover on the mixer and check the control plate spring, if unhooked, attach to bottom of the control plate and squeeze the spring end, also check the speed control plate screws,there are 3 screws on this plate, one at the bottom two at the top, see if adjusting the top screws slows your mixer down.
Next check the wiring of the mixer, Insure everything is wired correctly, to get wiring diagram go to the last page of the service manual. Here is a link to the service manual: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
If neither of those fixes the problem it is probably a bad phase control board, or a shorted phase control board. With the line cord disconnected, pull the t-bar contacts to open and insert a piece of paper between them so they cannot close. Reapply power-the mixer should just run or buzz trying to run, if it operates at full speed the phase control is defective and needs to be replaced.
Use the service manual to aid you in taking apart the mixer, trouble shooting the problem and putting the mixer back together, based on the mixer only running at high speed some of the time I would assume it is the speed control phase board.
If you have any questions let me know.
Thank you,
Colleen
Customer Service
MendingShed.com
Apr 24, 2013 | KitchenAid Food Mixers
Mixer only runs at one speed
if it runs only at high speed it needs a new phase control board if the mixer is post 1978, if the mixer is pre 1978 then you will have to replace a capacitor on the end of the power cord inside the mixer. if the mixer only works on one speed that is not high speed then you need to adjust or replace the speed control plate on post 1978 mixers and the capacitor on pre 1978 machines. Hope that helps
Jan 30, 2013 | KitchenAid Food Mixers
My kitchenaid mixer run on high at all times
If your mixer only runs on high speed there are 3 things that can cause that. The first thing to check will be the speed control plate, Remove the trim and end cover on the mixer, the first thing you should see is the speed control plate, this has 3 screws on it, try adjusting the top two screws 1/4 turn, this should slow the mixer down, do not over tighten. Also check to see if the control plate spring is unhooked. If the spring is unhooked, attach to bottom of the control plate, and squeeze the spring end.
If this does not fix your mixer, check the wiring of the mixer, you can locate a wiring diagram on the last page of the service manual.
If the speed control plate is adjusted correctly and all the wiring is correct it will be your speed control phase board. You can test the speed control phase board to see if it is shorted. With the line cord disconnected, pull the t-b ar contacts to open, and insert a piece of paper between them so they cannot close. Reapply power-the mixer should just run or buzz trying to run. If it operates at full speed, teh phase control board is defective and needs to be replaced.
This will aid you in taking the mixer apart, troubleshooting and putting it back together, remember the wiring diagram is the very last page.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Jan 07, 2013 | KitchenAid K5SS Mixer Speed Control Plate...
KitchenAid 2671 onmly run Stir and Second at high speed
Hi. Goto kitchenaid.com and download the parts catalog for your mixer model, these drawings will assist you in the disassembly and reassembly of your mixer.
You'll need to replace the speed control in your mixer. This is a common problem. Be prepared to wait at least a month for your parts to arrive. Unplug your mixer before you open it up.
If you're still under warranty call kitchenaid!
If this solution has assisted you, please rate it. Good luck! ricardok45
Jan 28, 2009 | KitchenAid KP26M1X Stand Mixer
Kitchen aid KSM90
If you can unplug the mixer and test resistance between leads of the selector switch. The resistance should vary from high to low as you move the selector from low to high. If cord and all else looks good and switch is bad replace the switch.
Mar 23, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
49 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
